Hasselblad X
Всего 14852 сообщ. | Показаны 9481 - 9500
RE[Alexander Fedin]:
FIRMWARE 1.1.8.6 FOR HASSELBLAD X2D II 100C (2025.08.26)
Visit the Downloads section on the official website to download the latest firmware file:
https://www.hasselblad.com/my-hasselblad/downloads
WHAT’S NEW
 Supported to zoom in to 100% to view image details in Browse Mode during image processing.
 Supported to configure most of the camera settings in Main Menu during image processing.
 Supported to temporarily disable the HDR effect when previewing HDR images. Tap and hold the HDR
icon to achieve this.
 Supported RGB histogram and luminance histogram display when previewing HDR images.
 Supported automatic exposure lock (AE-L) when HDR is enabled or the exposure mode is set to Full Auto.
 Supported to set the image format to "RAW" only when the exposure mode is set to Full Auto.
 For Autofocus Continuous (AF-C):
 Supported detection and focusing on smaller faces.
 Improved focusing performance and reduced exposure delay.
 Added option to enable or disable "Touch to Move AF Point" in the Focus settings.
 Added "Reset Connection Settings" function in the Connection settings.
 Improved highlights performance of HDR JPG and HEIF images.
 Improved shadows performance for image preview.
 Improved human eye detection success rate and focus accuracy.
 Reduced smudging in high-ISO (ISO ≥12800) images captured in Continuous drive mode.
 Fixed accidental parameter changes caused by overly sensitive front/rear scroll wheels.
 Fixed occasional failures to focus after the camera exits Standby Mode when used with the XCD 2,8 -
4/35-100E lens. (latest firmware of the lens required)
Интересно даже
RE[SVAM_H]:
SVAM_H, как Вам HDR в этой камере? Или не пользуетесь? Я бы только из-за него взял 😄
RE[ZVA2016]:
от:ZVA2016
Только как превьюшка, что бы кадр быстро глянуть
RE[SVAM_H]:
от: SVAM_H
Они постарались, внедрили первыми, а вы только как превьюшку используете ))
Пришёл ответ:
Благодарим вас за обращение в Hasselblad. Камера X2D II 100C оснащена внутренним SSD-накопителем. Если вы планируете продать камеру и хотите быть уверены в невозможности восстановления данных, рекомендуем выполнить следующие действия: Отформатируйте SSD-накопитель в камере. Перейдите в меню камеры и выполните полное форматирование внутренней памяти. Это приведет к удалению всех сохраненных изображений и данных. Многократная перезапись для повышения безопасности. Для дополнительной безопасности рекомендуем форматировать SSD-накопитель несколько раз. Каждый процесс форматирования перезаписывает таблицу размещения файлов, что существенно затрудняет нормальное восстановление. Надеемся, это поможет. Пожалуйста, свяжитесь с нами, если вам потребуется дополнительная помощь. Хорошего дня! С уважением, Служба поддержки клиентов Hasselblad (Европа)
Ну или...... Залить сверху видео!! Фильмы .... Типа бонусом в подарок :)
На крайняк - камеру как SSD просто тупо подключить к другой видеокамере как внешний носитель и Записать каку-то лабудень шумную! в ProRes. Быстро засрет ее терик :)
RE[SVAM_H]:
от:SVAM_H
Спасибо за лайфхак.
Владельцы X2Dii утверждают, что XCD 80/1.9 фокусируется на новой камере в режиме AF-S на 70% быстрее, чем это было на X2D. И это зэр гут )
Hasselblad X2D II Meinung und Test mit alten Objektiven, XCD 80 1.9 usw..
RE[Aleksandr]:
от:Aleksandr
Спасибо за лайфхак.
Да уже понятно что камера удалась. Хороший автофокус, шикарная картинка, широкий динамический диапазон и высокая детализация. К тому же просто сумасшедший стаб. Ещё и HDR воткнули. И всё это в стильном, красивом корпусе, да ещё и за вменяемые деньги. В общем прогресс на лицо. Что ещё нужно? А маленьким бонусом идёт то, что подходят старые батарейки. Мелочь, а приятно.
RE[SVAM_H]:
от: SVAM_H
В Стамбуле глухо с Хасселем. А вот с Фуджиками - там реально найти ....
Понятно. Жаль, конечно.
RE[Alexander]:
от:Alexander
По множеству мелочей!
Например авто ISO в M!
Тот факт что с старой оптикой быстрее это хорошо. Не факт что увидим новый 80, но текущий старый 80ый- у текущего рисунок оч близкий к отусу. Не отпускает мысль сделать себе подарок :)
Вячеслав, а вы не пробовали 80 к х2д2? Как оно?
RE[Максим]:
от: Максим
Так авто ISO в М на X2DII работает. В X2D - вроде нет!
80-ку попробую завтра (вернее уже сегодня). Я только снимать ей хотел.
А чего в ней пробовать то?
Скорость, точность? Следящий (Его не уверен, что попробую)....
Вообщем все равноберу с собой - а там по ситуации!
RE[Максим]:
от: Максим
Да там много ещё чего улучшили. Я просто не стал всё перечислять. Список достаточно большой. Даже тот же более яркий экранчик или джойстик.
Начитался этого форума и купил кубик 907Х&CFV100С
Пока через переходник с никоновскими ФФ-стёклами
Полтинник f/1.4 кроет, и 180 мм f/2.8Ai (1979 г.в.) тоже кроет.
Зумы виньетируют, ДИХСН.
Завтра заеду за XCD 4/45P и на этом всё.
Буду таскать штатив или монопод, щёлкать от пуза, познавать дзен среднего формата
RE[Lks]:
от:Lks
Поздравляю! Какой переходник для никоновских стекол используете?
RE[Lks]:
от:Lks
Поздравляю!!!
Крутая штука!
Я думаю однажды созрею до CFV + 500ка хасселя для пленочных зайцев ))
p.s. у никона строго рекомендуют 105мм стекло на СФ - сенсор покроет! Оч хороший портретник
Адаптер Peipro N/G-X1D.
Какой был в магазине, такой и взял.
Кстати, на полной матрице полтинник все-таки уголки подтемняет.
А 180-й почти нет.
RE[Максим]:
от: Максим
Поздравляю!!!
Крутая штука!
А там глядишь и кассету с пленкой примостите к 500-му )
Главный недостаток кубика - кнопка спуска не оранжевая!
RE[Lks]:
от: Lks
А 180-й почти нет.
Piepro вроде норм переходник. В свое время после покупки камеры, тогда еще X1 с базовым 45p, первым делом озадачился закупкой всевозможных переходников. Под Vшки взял родной Хаселёвый. Ну и слегка прифигел от люфта, с которым ходили на нем цейсовские зайцы. Потом поштудировал вопрос. Оказалось у Хаселя на V так себе переходник сделан и в этом плане надо брать Novoflex. Поэтому когда проскочил на Авито новофлексовский переходник для Nikon, взял его не торгуясь…Ну почти не торгуясь )). Берегу его как зеница оку. На Vшки у них тоже есть в линейке, и на Лейку-М. Если увижу в РФ сразу возьму впрок.
RE[Lks]:
от: Lks
А 180-й почти нет.
Виньетка на телевиках уходит, начиная с где-то с 75мм фокусного. На своем 85-м цейсе с апертурой 1.4 правлю ее в автоматическом режиме через Lens Correction в Phocus. На более широких фокусных приходилось играться со слоями по углам, потом бросил эту затею в пользу родной оптики.
