от: kitano
На руморсах появилась информация про размеры 12-40.
Чуть меньше 400 грамм.
Чем меньше времени до презентации, тем больше знаем :)
Digicameinfo updated the E-M1 spec list (specs via google translation):
Olympus OM-D E-M1
- 16.28 million pixel LiveMOS sensor with 37 phase detection pixels
- “DUAL FAST AF” hybrid autofocus (hybrid means contrast and phase detection AF).
- Greatly improve the tracking performance of the C-AF
- 6.5 frames / 10 frames with fixed exposure.
- 200-25600, LOW ISO range (ISO100 equivalent)
- The shutter speed -1/8000 seconds up to 60 seconds
- New TruePicVII Image processing engine
- Adopt image processing technology “Fine detail II”, magnification chromatic aberration correction, Moire Reduction
- EVF is 0.029 seconds time lag, High magnification 2.36 million dots of 0.74 times 35mm conversion,
- touch panel LCD monitor 1.04 million dot 3.0-inch, movable,
- 5-axis camera shake correction
- Video Full HD (1920×1080 30p, 24Mbps)
- -10 ℃ Low-temperature performance dustproof drip-proof,
- Wi-Fi Built-in
- Dimensions: 130.4 x 93.5 x 63.1mm
- Weight: 497g (including battery media), 443g (body only)
- Kit with 12-40mm will ship in early October and 12-50mm kit in late Ocotber
M.ZUIKO DIGITAL ED 12-40mm F2.8 PRO
- Linear motor, MSC mechanism, AF inner focus
- Manual focus clutch mechanism
- 20cm minimum focusing distance (maximum magnification of 0.3 times, 35mm equivalent 0.6 times) throughout the entire zoom range
- Dust-proof drip
- I squeeze seven feathers (circular aperture)
- Filter size: 62mm
- Total length: 84mm, maximum diameter 69.9mm
- Weight: 382g
- late November release
