RICOH GXR
Всего 39958 сообщ.
Показаны 2501 - 2520
Re[Arsuchelsy]:
У нас в restor'ах одни выходные в месяц скидка ок. 10%
Re[Костау]:
Нашел, изучаю ...
Круто, круглосуточные звонки, уже созвонился в час ночи с магазином! Есть в наличии!
Re[Arsuchelsy]:
Кто-нибудь слышал о новом мониторе eizo ev2335w,на IPS,написано делают для бизнеса, обзоров ещё нет. У нас его продают, а рекомендованных на форуме - не продают.
"23-inch full HD (1920 x 1080 native resolution) monitor for trading rooms, back offices, and other business environments, the FlexScan EV2335W .
The FlexScan EV2335W uses an IPS (in-plane switching) panel with 178° horizontal and vertical viewing angles. This makes it ideal for trading floors and other multi-monitor environments where the screen is often viewed from an acute angle. The FlexScan EV2335W has an overdrive circuit for a gray-to-gray response time of 6 ms to ensure real-time stock data and on-line videos are displayed without blurring or ghosting.
Monitor have 250 cd/m2 brightness, 1000:1 contrast ratio, and D-Sub and DVI-D for analog and digital connectivity also comes with a DisplayPort input for support for this increasingly popular digital display interface.
Two original EIZO features are included to obtain the optimal screen brightness . Auto EcoView measures the ambient brightness and automatically adjusts the screen’s brightness accordingly. A new function EIZO is introducing for the first time called EcoView Optimizer tempers changes in the white level (brightness) of the displayed contents by further adjusting the screen’s brightness accordingly. These two features together trim power usage while reducing eye fatigue that would otherwise result from a screen that is too bright or too dark.
A preset called “Paper” mode simulates the look of printed paper and helps prevent eyestrain when reading documents. In addition, a function called “EyeCare Filter” that is available with the bundled ScreenManager Pro for LCD (DDC/CI) utility software1 software offers several filter patterns that resemble different types of paper. By adjusting the monitors’ brightness and contrast the density of the filter patterns can be set to the level preferred by the user.
Other preset modes are sRGB, Movie, and two modes with user adjustable settings. With the bundled ScreenManager Pro software, any preset mode can be assigned to an application so that when the application is opened, the screen automatically changes to its assigned mode. This software can also be used for adjusting the monitor’s color settings with the mouse or keyboard instead of the on-screen display menu.
For viewing comfort, EIZO has outfitted an ergonomic stand it designed in house. The stand features 165 mm height adjustment, 30° tilt, and 344° swivel. The screen can also be rotated 90° for portrait mode viewing.
Скорее всего не подойдет, сделан для бизнес приложений ,да и для презентаций, чтобы все вокруг видели контекст.
Re[Arsuchelsy]:
Приветствую коллеги!
Вот и я теперь в Ваших рядах-принимайте, за что отдельная пре-огромная благодарность уважаемому Arsuchelsy за поддержку, уделенное время и помощь. Так что теперь буду выкладывать свои с Рико (а не с сигы и Пня - как несколько ранее. За что извиняйте если что не так). Сейчас осваиваю, а с пнд улечу в Сибирь по работе-там проведу полевые, так-сказать, испытания. Может с погодой повезет.
Re[Некрасов Андрей]:
До -11 С проверенно, сильнее мороза пока небыло.
В центральной Сибире сейчас чуть холоднее, думаю выдержит, это не Якутск, где под -40 С уже! Смотрю, некоторые и под - 50 С умудряются снимать! )))
Бедные батарейки!
Сказали зима должна быть холодная, я даже масло в машине поменял на более жидкое.
Бедные батарейки!
от:Некрасов Андрей
Вот и я теперь в Ваших рядах-принимайте, за что отдельная пре-огромная благодарность уважаемому Arsuchelsy за поддержку, уделенное время и помощь. Так что теперь буду выкладывать свои с Рико (а не с сигы и Пня - как несколько ранее. За что извиняйте если что не так). Сейчас осваиваю, а с пнд улечу в Сибирь по работе-там проведу полевые, так-сказать, испытания. Может с погодой повезет.Подробнее
Поздравляю!
а по морозам фотик главное в тепло быстро не вносить, чтобы конденсат не выступил
а батарейку отсоединять и в тепло
Re[Ganzilla]:
Да ерунда это тепло - главное успеть и не забыть сунуть в пакет полиэтиленовый на морозе. Тогда конденсат выпадет на нем, а не на фотоаппарате.
GXR Zoom module
Похоже, что дождались ;)
ЗАВТРА СОСТОИТСЯ АНОНС НОВОГО RICOH GXR ZOOM Module
Re[Voigtlander]:
от: Voigtlander
ну вот! очень интересно какие параметры
по аналогии с 50 и 28 жду очень симпатишный объектив
Re[Arsuchelsy]:
[quote=Arsuchelsy]Беру! Всё беру!
:D
Подозрение, что будет что-то серьезное!
Ладно, поехал за ...
... а то пока маленький ноут не могу и с фото нормально работать.
Заходил в гости, снял кошака на лейку, серьезный кроп. Резкость чуть-чуть добавил, и баланс поправил, больше нечего.
а можно снимков с GXR увидеть, для лейки все-таки своя ветка существует...
:D
Re[]:
Техническая проба новой камеры на цветность:
А 50 . Зачетно на мой взгляд
По резкости - шевеленка, т.к. бегают охранники с передатчиками
"Снимать ни-зя-я! Запресчено!"
Re[тор]:
от: тор
Замечательные фотографии, харАктерные, классное ЧБ у рико, породистое :!:
Спасибо
Re[Valis]:
от:Valis
Замечательные, очень мягкие, теплые снимки. А мы тут все резкость, резкость.
:D
Voigtlander, так все же, за чем продали, или отдали, M-модуль? На форуме вроде как проскакивало... Или я не что то не так понял. Купили то одним из первых. Не понравился? :DПодробнее
Спасибо, Valis
Понравился, просто выручил сильно страждущего сотоварища, а свежеиспеченный едет где то, жду не дождусь. Куча линз уже приехала под М.Модуль М супер, теперь на а12 почти не снимаю.
Re[Voigtlander]:
Прошу прощения за постоянные вопросы.
Некоторое время назад мой старенький принтер ушёл в небытие.
Что купить, чтобы фотографии, сделанные на ещё не купленном Рико,получались неплохо? :?:
Re[Voigtlander]:
Сегодняшнее. Был в лесу. Точнее на Учинском водохранилище. Последний раз в этом сезоне. Там можно снимать бесконечно... Это "запретка" идет водозабор в Москву питьевой воды.
Посты милиции-полиции. Людей мало, поэтому сохранилась почти нетронутой - природа. Одно из красивейших мест Подмосковья.
Умудрился потерять там крышку от Цейса, час целый искал, но нашел. :D
Вот отчет. Рикох и М-модуль.
Панорама из трех кадров.
Re[тор]:
у Броники картинка лучше ;)
Re[serg_gera]:
от: serg_gera
Да, это понятно, но ведь не броникой единой :)
Re[Valis]:
просто песня!
