Официальная информация от Yongnuo:
Версия для Nikon ожидается после 20 апреля.
Подтвержден функционал частично объявленный в марте:
• Like the Canon version, they are transceivers – any unit can be placed on the camera to become a commander/trigger. When on camera, the unit is referred to as “transmitter”. Other units are “remotes”.
• A flash can be mounted on top of the transmitter. If the flash is in Master mode, its settings (flash mode, output level, flash compensation, etc) will be used. The flash provides the settings interface. The on-top flash can be in TTL, M or RPT mode.
• Alternatively, an SU-800 can be mounted on the transmitter.
• If a Master device is not installed, i-TTL, Flash compensation, manual levels in groups are still available..
• Smart triggering (“mix mode” on Canon version) gives priority to on-flash settings, rather than to Master settings (remote mode).
• Syncs: First, Auto FP and Rear.
• Red-eye reduction, Modelling flash, Focus-assist illuminator (target light) are all supported.
• In TTL mode, CLS is implemented, including separate metering for each group.
• Three groups are available, in 7 combinations
Nikon does not yet have in-camera menus that provide full control through the hot-shoe (i.e. not the pop-up flash). A master flash or SU-800 on-top can provide the on-camera interface the YN-622N needs to implement a full set of controls
Рекомендовали следить за обновлениями :)
