Цитата:от:Grafov Sergej
И тут встрял Я.
Кстати, тот винтик под шестигранник в боковой стенке шахты - он подстраивает основное зеркало? То есть при замене родного фокусировачного экрана на Катцай не нужно юстировать его "полосками скотча" как предлагают многие форумчане, а можно тем винтом "подвигать" вверх-вниз основное зеркало и это подкорректирует ручной фокус?
И вместе с тем эта операция не затронет маленькое зеркало и модуль автофокуса? Т.е. автофокусировка не собьется?Подробнее
Вот цитата из письма, которое мне прислали из Катцая вместе с картинкой, которую я тут выложил, когда я сообщил им, что с их экранчиком фокус не попадает:
The adjustment of the manual focus calibration screw is a simple procedure that will require only a 1.5mm hex wrench (sometimes called an 'Allen Key'). The adjustment screw is located on the left side of the mirror chamber, just ahead of the main mirror. It looks basically like a circular recess in the side wall of the mirror chamber, but is actually a hex-shaped recess to fit the wrench mentioned above. I have attached a photo that shows the location of the MF adjustment screw. You may be assured that adjusting the MF by this method will not affect the calibration of the AF system or any other camera functions.
To correct a back focus problem on the D700 will require turning the screw anti-clockwise (tip of the wrench moving toward the top of the camera) approximately 5-10 degrees. The wrench is only a moderately tight fit in the screw and there will be a little 'play' or loose movement of the wrench. Just take up the play in the wrench, turn the screw approximately 5 degrees, shoot off a few throwaway shots to make sure the mechanism is seated, and repeat your focus test. If there is still back focus, adjust the screw an additional small amount and repeat. If you have traveled too far and you get front focus, simply turn the screw back the other way a small amount. In this way, you can adjust and test until satisfactory results have been obtained. It should take no more than 20-30 degrees of total travel at the very outside. It usually takes less than that, but any amount up to 30 degrees is acceptable. If you have traveled that far and have not reached the correct calibration, we may need to increase the thickness of the shim above the focusing screen before proceeding.
То есть, на автофокус эта операция не влияет вообще, а "полоски от скотча", точнее, специальные прокладки могут понадобиться только когда требуется значительная коррекция, что бывает редко - обычно хватает винтика. Но если и понадобится, Катцай, вроде, обязуется выслать такие...
Да, если что, то все сказанное верно для тушек д200-д300-д700. В младших, возможно, такого винтика нет...
