от: GAN
Да похоже так же, как и предпоследняя :) Ничего нового не появилось, наверное просто исправление каких-то багов.
Список изменений
Changes since the last build 4.0.12.23:
- Install rtengine/camconst.json in ${DATADIR} not in ${BINDIR} (See issue 2244).
- Optimization for Vignette Filter (Exposure tab), Issue 2243
- Optimization for RawImageSource::getRAWHistogram, Issue 2238
- Vignetting Correction bug makes hard transitions for positive Amount values, Issue 2241
- CIECAM Dancing pixels issue2234
- Enhanced lens identification with Canon cameras, Issue 2228
- The opened/closed state of the left and right panels of the file browser is now remembered when restarting RT (no issue).
- Solving issue 2235: "JPEG subsampling parameter is missing in the command line"
- Revised default and updated all language files. Issue 2188
- Avoids invalid reads which occured with Pentax K100D, patch provided by Hombre, no Issue
- Optimization of RawImage::get_colorsCoeff, Issue 2227
- Solving issue 2221: "Specifying the Settings and Cache path through environment variables"
- Black and white channel-mixer new algorithm for orange Yellow Cyan Purple Magenta
- Update to dcraw 9.20 Revision: 1.461
- [PCVignette] and [Gradient] Strength=0.6, issue 2162
- Solving issue 2197: "Pentax K-3 support"
- changed misleading error message, no Issue
- USM's halo control behaves oddly, Issue 409, on behalf of Martin Burri
- Removed Hot/Dead pixel filter from Default.pp3
- Added compareRT Bash script, to help compare images developed with pre- and post-patch RT
- buildRT updated. Now menu handles long branch names correctly. Formatting improved.
