ФОВЕОН-кухня: как его варить.
Всего 2812 сообщ.
Показаны 1481 - 1500
Re[Михаил Мосейко]:
а точечный экспозамер не пробовали в этих условиях?
Re[andreiginepro]:
от: andreiginepro
не пробовал
Re[идущий вслед]:
Получил мишень Wolf Faust. Вещь серьёзная. Помимо индивидуальной замерки мишени с серийным номером приложили ещё значения для различных источников света:
The "Extras" directory contains files for illuminants other
than D50. It also contains data for the CIE 1964
10 degree observer. Color data for even more illuminants or
observers can be calculated using the spectral data
(ColorShop can easily do this for you).
Following illuminants/observer files are available in "Extras":
R130103A.txt - Illuminant A, 2 Degree Observer,
Illuminant A was intended to represent the
illumination from incandescent/tungsten
light sources (approx. 2856K) used in general
lighting and in projectors.
R130103A10.txt - Same as R130103A.txt but 10 degree observer
R130103C.txt - Illuminant C, 2 Degree Observer,
Represents average daylight with correlated colour
temperature of about 6800K.
R130103C10.txt - Same as R130103C.txt but 10 degree observer
R130103D5010.txt - Same as R130103.txt but 10 degree observer
R130103D55.txt - Illuminant D55, 2 Degree Observer,
Representing a phase of daylight with a
correlated color of approximately 5503K
(mid-morning or mid-afternoon daylight)
R130103D5510.txt - Same as R130103D55.txt but 10 degree observer
R130103D65.txt - Illuminant D65, 2 Degree Observer,
correlated color of approximately 6504K.
(Average northern daylight)
R130103D6510.txt - Same as R130103D65.txt but 10 degree observer
R130103D75.txt - Illuminant D75, 2 Degree Observer,
correlated color of approximately 7504K
(North sky or overcast daylight )
R130103D7510.txt - Same as R130103D75.txt but 10 degree observer
R130103F2.txt - Illuminant F2, 2 Degree Observer,
Represents a cool white fluorescent lamp with
a correlated color temperature of 4200K.
R130103F210.txt - Same as R130103F2.txt but 10 degree observer
R130103F7.txt - Illuminant F7, 2 Degree Observer,
Represents a broad-band (continuous-spectrum)
fluorescent daylight lamp with a correlated color
temperature of 6500K.
R130103F710.txt - Same as R130103F10.txt but 10 degree observer
R130103F11.txt - Illuminant F11, 2 Degree Observer,
Represents a narrow-band (line-spectrum)
white fluorescent lamp with a correlated color
temperature of 4000K.
R130103F1110.txt - Same as R130103F2.txt but 10 degree observer
На выходные будем посмотреть 8)
Re:
FindeR Спасибо!
вопрос ко Всем!,
по обработке с Sigma SD1 Merrill снимков,
пару фотографий предлагаю,
кому не сложно, предложите примеры обработки, мне не нужно описывать, что и как Вы делали, просто по оттенкам интересно,
впрочем если все будет элементарно только в SPP, тогда намекните пожалуйста :)
РАВ: http://rusfolder.com/36082681
РАВ: http://rusfolder.com/36082682
(девушка слилась с цветастым фоном, не воспринимается снимок , фон приглушить или диафрагму поджимать???...)
РАВ: http://rusfolder.com/36083732
уличные снимки для выпускного альбома делаю, буквально завтра-послезавтра отдать заказчику планирую для укомплектовывания альбомов, человек на Nikon d600 работал, а я как второй фотограф,- поучиться (и для денег немножко),
а эти фотографии предлагаю потому,... ну не парней же снимки выкладывать :)
освещение практически на всех фото было от вспышки и с светорассеивателем gary fong lightsphere
P.S. nikon d600 с таким наглазником рулит!
я прям обзавидовался, нужно себе какой нить наглазник прикупить, пусть и не для live view, хотя с этим просматривать фото комфортно очень
вопрос ко Всем!,
Re[Михаил Мосейко]:
Давай посмотрим, что на д600 вышло. Для сравнения.
Re[aiv]:
постараюсь взять фото у друга при встрече на неделе, но он в РАВ не снимает принципиально...
Re[Михаил Мосейко]:
от: Михаил Мосейко
Re:
serg_gera
FindeR
я так понимаю все в целях экономии времени делается, потому в РАВ не снимает
FindeR
от: идущий вследв чём крэдо?
Re[Михаил Мосейко]:
от: Михаил Мосейко
Как то так.
Спешка нужна, говорят былинные мудрецы лишь при ловле блох или при е... чужой жены... (с)
Re[идущий вслед]:
А мне понравилась кнопка в спп: File > Convert to JPEG file. Щелкаешь в рав, приходишь и за долю секунды вытаскиваешь из всей серии встроенный джипег. Просматриваешь, ненужное сразу в корзину, а лучшие тянешь из рава.
Re[aiv]:
от:aiv
А мне понравилась кнопка в спп: File > Convert to JPEG file. Щелкаешь в рав, приходишь и за долю секунды вытаскиваешь из всей серии встроенный джипег. Просматриваешь, ненужное сразу в корзину, а лучшие тянешь из рава.Подробнее
Открою тебе секрет, я это делаю (быстрый просмотр и сортировка) в фасстоуне, он ещё быстрей (вообще без тормозов) и не надо ждать загрузки этого дирижабля СПП.
Re[aiv]:
от:aiv
Спасибо за подсказку, удобно и ОЧЕНЬ быстро работает.
Re[aiv]:
от:aiv
Глянул на x3f профиль, что идет с спп. Он точно вкладывается в adobeRGB. Так что любителям оттенков зелёного с красным лучше куцый sRGB обходить стороной, он их режет нехило. Все актуальные броузеры адобРГБ поддерживают. Монитор конечно тоже нужен соответствующий.Подробнее
Насколько я понимаю, при съемке к РАВу цветовое пространство не применяется, только при конвертации в jpeg?
Re[Cron]:
Ну так все знающие уже давно в профото и конвертят при проявке! :)
