http://www.isi.com.cn/Product/efilmnews.htm
...и перевод с китайского - увы пока только на английский.
Digital roll film, patent product!
Patent number: 012339172; 033679258
One, may see from the above chart, the digital roll film contour and the size and the ordinary 135 roll films same, may cause the majority tradition the photographic camera not to do any modification, all may directly use the digital roll film photography clear bright Li digital photograph, lets your traditional photographic camera ????, immediately becomes the digital camera!
Note: In May 1 goes on the market the digital roll film is aims at these has the center upscale camera which the B gate, the T gate and fixed time photographs. (Has some cameras when use numerical code roll film, roll film sheeting needs to download)
Two, digital roll film characteristic:
1, the digital roll film uses is in sole possession of the ultra thin CMOS sensor, its thickness only has 0.7mm
Is the ordinary CMOS sensor 1/3, ??? traditional 135 lists reflections camera.
Note: The CMOS photosensitivity size is 1/2 inch, in other words photographs the picture only is selects a scene the window center one part. For example: The original 35mm lens may illuminate the whole body picture in 3 meter about distance, the digital roll film only may illuminate the half-length picture in 3 meter about distance. But wanted to illuminate one prospect numerical code roll film is able to develop one's ability to the full, she was allowed to cause 35mm to decide the burnt camera photographs about 180mm the long burnt effect.
2, the digital roll film uses general durable CR2 may imitate ??? (photographic camera special-purpose battery) does the power source, allows you to photograph the photograph several dried bean curd, reminds in the digital roll film you does not have the electricity time, but also can for you again photograph several ten clear bright Li digital photograph! This only can work several ten minutes digital cameras with one battery compares, appears specially durably. Again also needs not to worry in the travel on the way, because of the photographic camera battery electricity, the regrettable aspect which but cannot photograph.
Note: Stochastically matches delivers the charge number of times is bigger than 800 time may imitate battery one.
3, the patent product digital roll film brings own the liquid crystal display monitor, may through the traditional photographic camera ?? above roll film material demonstration window, promptly examine the digital roll film the active status;
4, the digital roll film special-purpose picture multiplies software, may multiply the digital roll film photography photograph picture element by 10 time of percentages (for example: After 2100000 picture elements multiply may achieve 21000000 picture elements), after multiply the picture can clearer bright Li. (Here is picture multiplies in mathematics is called interpolation)
Note: Any digital photograph all may multiply software through the picture multiplies, after the process multiplies the picture enlarges to 1: 1 looks, can feel fuzzily. This after is because multiplies the picture only can increase the picture element, cannot increase the clarity. But digital roll film like 1 states, the photography picture only is selects a scene the window center one part, we all know one photograph ???? is clearest. Therefore, after the digital roll film photography picture process multiplies the picture enlarges to 1: 1 looks the feeling can good be very many.
5, the digital roll film uses general USB, may conveniently with the computer, the printer, or the digital image equipment connects.
6, the digital roll film has the dynamic photograph function, for has the B gate or the T gate traditional camera increases one digital camera the function, causes your traditional camera to stand Engraves becomes one digital camera, transcribes the digital image for you;
7, the digital roll film has moves the U plate the function, may like one moves the U plate same, downloads for you preserves some data materials.
8, the patent product digital roll film gathers the dynamic photograph, the static photography, moves the U plate and so on, three kind of products functions, one kind of product price this is the digital roll film unequalled, the advantageous superiority!
Цифровая пленка - еще одна попытка?
Всего 41 сообщ.
Re: Цифровая пленка - еще одна попытка?
чесно говоря, не дочитал до конца ни по-китайски, ни тем более по-англицки. вроде хрень какая-то. принцип действия не понятен.
может к вечеру еще подходец сделаю (медленно грузится, вторую стр даже грузить не стал)
еще раз прочитал. не понятно, как и где будет обрабатываться изображение
ну цыфрамылу миниатюризировали до размера касеты с плёнкой. ничё новово по размеру вобщем то щас. матрица то мелкая 1/2". где интересно линзы брать и как их крепить.. хтя какую нить смену переделать былоб прикольно
Re: Re: Цифровая пленка - еще одна попытка?
она рассчитана на работу с обычной пленочной мыльницей и ее оптикой
обзор - бред
обзор - бред
Re[Чайник обыкновенный]:
" А вот пирожки горячие, с мясом, с повидлой.."
http://re35.net/index.html
Неужто сбылась мечта идиота будут выпускать? Наверное, похоронят все-же....
Re[СтарПёр]:
Прикольно! :D
Re[СтарПёр]:
Цена б ещё была рублей 200... Было б прикольно, а так пока что концепт, но сколько их таких уже было...
Re[прафисианальный фатограф]:
а сколько стоит?
Я лет пятнадцать назад думал, что выпустят электронную плёнку: то есть точно такую же, как химическая, только вместо химслоя матрица из светочувствительных элементов с памятью.
Вон как всё обернулось...
Re[GELIOS40-2]:
меня спрашиваете?
Re[Shiroima]:
надо было патентовать идею
Re[СтарПёр]:
"Это" уже поздно выпускать. Или, разве что. в очень ограниченном количестве. Лет 10 назад улетало бы, как "горячие пирожки"! А сейчас цифровые зеркалки очень чувствительно подешевели. А плёночные вымирают, как класс... И зачем тогда этот девайс? Тем более, цена на него будет однозначно не 100 и даже не 200 USD.
Re[Gesha]:
Отчего же. Я б в свой ФЭД, да и в Зоркий, да и в кое-что ещё зарядил бы такое.
Re[СтарПёр]:
от:СтарПёрЧто-то больно похоже на фейк... Часом, не первого апреля вывесили?
Неужто сбылась мечта идиота будут выпускать? Наверное, похоронят все-же....Подробнее
от: прафисианальный фатограф
дак наверно под нее спец. камеру надо :?:
типа М8 или 9 ;)
Re[giora]:
на фед можно ляйковские стекла ставить.
Смысл, конечно, в такой теме огромный
Re[G o r d o n]:
от: G o r d o n
Похоже... А стали бы, думаете, целый домен покупать, сайт мутить, хоть и простенький.
Да и 1 апреля прошло, опровержение бы вывесили, я думаю
Re[СтарПёр]:
от: СтарПёрМало ли... Может, чей-то рекламный ход... Той же Лейки...
Re[СтарПёр]:
от: СтарПёр
Да было б что покупать.
Это ж пол дня делов на всё.
Шутка того стОит, ИМХО.
