Capture One Pro (5, 6, 7 ,8, 9, 10, 11)
Всего 10729 сообщ. | Показаны 3521 - 3540
8.2!!
Встречаем версию 8.2!
нововведения:
Видео о новом 3-полосном колор балансе
This is a feature release providing new features, bug fixes, performance
enhancements, stability improvements, camera and lens support.
New features and improvements
• New 3-Way Color Balance Tool for color grading
• Dynamic Locations for optimized workflow
• High resolution previews for 4k and 5k monitors
• Resizable Curve and Color Balance tools
• General under-the-hood improvements for tethering
• Improved graphics in Library tool
• New 5-point Curve preset for ease-of-use
Camera support
• File and tether support for Nikon D5500
• Tether support for Nikon D750
• File support for Olympus OM-D E-M5 II
• File support for Fujifilm X-A2
• File support for Panasonic GF7
• File support for Sony NEX- VG900E
• Improved color for Canon EOS 7D mk II
• Removed tethered support for Nikon D200
Bug fixes
• Several stability improvements
• Fixed a number of alignment bugs
• Fixed a number of localization bugs
• Improved mask drawing (Mac)
• Fixed an issue where the application would crash if external hard drive was
disconnected
• Fixed an issue where slideshows would show very slow
• Fixed an issue where integration with Media Pro was broken
• Fixed an issue where Folders Hierarchy in the Library tool would not show
• Fixed an issue where Masks would not be saved to EIP files
PHASE ONE I MARCH 2015 I PAGE 4
Lens support
• Zeiss Distagon T* 3.5/18mm ZF.2
• Zeiss Distagon T* 2.8/21mm ZF.2
• Zeiss Distagon T* 2.8/15mm ZF.2
• Zeiss Distagon T* 2/28mm ZF.2
• Zeiss Distagon T* 2.8/25mm ZF.2
• Zeiss Distagon T* 2/25mm ZF.2
• Nikon COOLPIX P340
• Nikon AF-S DX Zoom-NIKKOR 18-70mm f/3.5-4.5G IF-ED
• Sigma 8-16mm F4.5-5.6 DC HSM (Canon EF)
Re[Rafael Fomenko]:
Примите новенького. Установил с сайта. Вроде не лузер, но не могу сделать импорт файлов. Лицензия пишет , что каптура работает как экспресс. Что делать?
Re[dima_nn]:
Так не запускайте экспресс. Запускайте Рго.
Re[R_Yosha]:
Так у меня бесплатная от Сони - для Сони. Как ей это обьяснить?
Re[dima_nn]:
Скачайте платную с официального сайта.
http://www.phaseone.com/en/Downloads/Materials/Download-Capture-One-8.aspx
Re[R_Yosha]:
Спасибо за отзывчивость. Я лузер в квадрате!!! Моя 7-ка имела 125% увеличения экрана. Как ни старался увидеть кнопки импорта внизу, не получалось. Поставил 100% и все появилось. Но как работать с таким мелким шрифтом не знаю.
Re[dima_nn]:
Винды никогда не умели толково работать с увеличением отличным от 100% и шрифтом отличным от 96 dpi. Хочешь косяков - отличись. Так что либо очки, либо косячки.
Re[Rafael Fomenko]:
Кто подскажет... у сына при установке С1 8.2 нет профиля ProPhoto RGB... и вообще набор там какой-то бледный. Поиск пока ничего не дал, сравнили с моей капчей - те же настройки.... та же система на ПК. Есть мысли?
Re[sSer]:
Смотрите в процесс ресипи - бэйсик; профото-ржб там как был, так и остался
Re[R_Yosha]:
Спасибо )
Еще бы я понял о чем вы...
Re[sSer]:
от:sSer
Компьютер тот же или другой?
Re[Rafael Fomenko]:
Другой... система та же, W7х64... и в меню обработки, и в вид-профили - количество профилей раза в 4 меньше чем у меня.
Насколько помню - при установке какие-то модули капча спрашивает к дополнительной установке, но вряд ли это цветовые профили )
Re[sSer]:
от:sSer
Модули это - управление камерами по УСБ, вайфаю и т.д. Оба админы на компах?
Только что установил 8.2 - всё в порядке
Переустановить сыну пробовали?
Re[Rafael Fomenko]:
обновился, как шикарный инструмент появился - цветовой баланс, просто супер
Re[Rafael Fomenko]:
[quot]Оба админы на компах? [/quot]
Спрошу как он ставил, я не в курсе. Думаете поражение в правах как гостя? )
В общем все мутно пока
Re[sSer]:
от: sSer
Никогда недолюбливал. То там куда то что то не ставится, то недоставится, то не в тот каталог. Говорят не админом лучше - вирусы не так залазят. Может. Но и всё остальное тоже недозалазит.
Re[Rafael Fomenko]:
New 3-Way Color Balance Tool for color grading - это, безусловно, радует. А вот что такое Dynamic Locations for optimized workflow?
Re[Rafael Fomenko]:
Что за Uniformity(Однородность)?
двигая полозок, визуально не видать ничего. По цифрам: незначительно может меняться разброс одного или нескольких цветов.
Замысел в чём???
зы: Наврал, что не видно. Видно. Пожимая плечами: как Hue Rotation действует, только более тонко чтоли, как точная подстройка...
Re[Балбес]:
от: Балбес
Динамические расположения для оптимизации заливок
Re[Балбес]:
от: Балбес
Как понял в зависимости от тегов и рейтингов кадра ему можно назначить сортировку вывода после конвертации.
Типа с тегом "Вася" в папку "Васе", с тегом "Котик" в папку "Котэ". Вроде так
