Canon EOS R5 Mark II
Всего 9591 сообщ. | Показаны 9041 - 9060
RE[Сергей]:
от: Сергей
ну ппц какие нужные апдейты.. )))))
Вот этот, в виду мировой политической обстановки, очень полезен.:
7. Добавлена возможность назначать непрерывную предварительную стрельбу на настраиваемые кнопки.
RE[Edmus]:
от: Edmus
[color=#4b4b4b][size=16][font=Inter, sans-serif]Вот этот, в виду мировой политической обстановки, очень полезен.:
100%
RE[Сергей]:
от: Сергей
на сайт https://www.usa.canon.com/support/p/eos-r5-mark-ii залили новую прошивку 1.3.0
Есть очень даже полезные апдейты
Firmware Version 1.3.0 incorporates the following enhancements and fixes:
1.Adds [American Football] in [Action Priority] to optimize human subject detection for individuals wearing helmets and shoulder pads.
2.Improves tracking and detection performance for [Register people priority] in challenging conditions-including profile views, blurred or partially obscured faces, small subjects in the frame, and children-even when the feature is set to [Off].
3.Adds the ability to set [AF for close-up demos] during movie recording in [Movie manual exp.], [Movie auto exposure], and other Creative Zone modes to allow for its use in combination with exposure and AF area settings.
4.Adds [Wi-Fi freq. band] to [Communication Settings], allowing the user to select the 5 GHz or 2.4 GHz band when transferring from Bluetooth to Wi-Fi.
5.Adds [No. of connections] to [FTP transfer settings], allowing the user to select the number of transfer threads for [FTP transfer].
6.Adds the ability to store up to four [Color temp] values in [White balance setting] and to assign [Switch color temperature] to [Customize buttons for shooting].
7.Adds the ability to set [False Color Settings] to [On] when [HDR/C.Log View Assist] is selected.
8.Adds the ability to assign [Pre-continuous Shooting] to [Customize buttons for shooting].
9.Adds the ability to transfer AF-related settings between cameras of the same model by adding [Save to card] and [Load from card] to [Register/recall AF-related settings].
10.Adds the ability to display the electronic level during movie recording.
11.Adds the option for grid display during movie recording.
12.Adds the ability to display playback screens and menu screens when outputting to two screens via [HDMI Display During Connection].
13.Adds the ability to switch the group settings of a receiver camera from the sender camera when using the EOS Multi Remote app.
14.Adds support for DPRAW shooting.
15.Adds support for the Software Development Assistance Kit (EDSDK/CCAPI).
16.Fixes an issue that may cause Err49 to be displayed repeatedly during communication with an SFTP server.
17.Fixes an issue that may impact the camera's shooting ability if the auto power-off function is activated during interval timer shooting.
18.Fixes an issue that may cause the camera to restart when the shutter button is pressed while deleting images.
19.Fixes an issue that may cause the camera to not be recognized when connected to a smartphone via USB.
20.Improves other system stability.
RE[feog]:
от:feog
 2026-04-27 (11h 47' 29'') Canon EOS R5m2 RF45mm F1.2 STM ISO 100 ''1-500 S'' F1.6 focusing distance 2m by leteom, on Flickr
посмотрел серию на фликере - гуд цвет
RE[Edmus]:
от: Edmus
Это удобно, у меня это работает на пользовательском режиме С3, и походу меняю мнжду режимами, а теперь можно на репетитор диафрагмы поставить
RE[Vasil_M]:
от: Vasil_M
Благодарю!
RE[viking0458]:
от:viking0458
Интересно, а свою программу Camera connect они думают исправлять? Опять перестала работать! Попробовал скинуть через картридер Lexar, пожалел!!! Скопировалось не всё и в добавок исчезали фото на карте памяти!
Приложение Camera connect установлено на айфоне и айпаде.
На айфоне зависает на попытке входа по canon id.
На айпаде вчера запустилось без проблем, входа в учетку не просило, и даже обновило прошивку на R8.
UPD: вроде помогает "квн"
RE[Amalanhig]:
от: Amalanhig
обновились?
RE[feog]:
RE[feog]:
RE[feog]:
До жаркой встречи языка хамелеона и кузнечика осталось..1...2...3...
Все топовые технологии в действии, 30кс, прешутинг (в кои веки пригодился).
РФ 135 на открытой
RE[Сергей]:
Думаю, жду отзывов от ковбоев. Им футбол в касках дали, наверное скоро увидим их пояснения по 1.3.0 для r5 mark ii
RE[Виктор]:
от:Виктор
Вот это лошадкииии! Просто балдёж, какие шеи. Где это ?
RE[Сергей]:
от: Сергей
обновились?
да обновился, на canon.ru тоже уже выложили новую прошивку 1.3.0
для меня в этой прошивке полезными см. ниже пункты
1. Пункт [American Football] (Американский футбол) добавлен в режим [Action Priority] (Приоритет действий) для оптимального распознавания людей в шлемах и наплечниках.
4. Добавлен параметр [Wi-Fi freq. band] (Диапазон частот Wi-Fi) в меню [Communication Settings] (Настройки связи), что позволяет выбирать 5 ГГц или 2,4 ГГц при переходе с Bluetooth на Wi-Fi.
5. Добавлен пункт [No. of connections] (Количество подключений) в меню [FTP transfer settings] (Настройки передачи по FTP), где можно выбрать количество потоков передачи для [FTP transfer] (Передача по FTP).
6. Добавлена возможность выбора до четырех значений [Color temp] (Цветовая температура) для параметра [White balance setting] (Настройка баланса белого) и назначения для параметра [Switch color temperature] (Переключение цветовой температуры) значения [Customize buttons for shooting] (Назначить кнопки для съемки).
8. Добавлена возможность назначить параметру [Pre-continuous Shooting] (Предварительная серийная съемка) значение [Customize buttons for shooting] (Назначить кнопки для съемки).
9. Добавлена возможность переноса настроек автофокусировки между камерами одной модели с помощью параметров [Save to card] (Сохранить на карту) и [Load from card] (Загрузить с карты) для настройки [Register/recall AF-related settings] (Сохранение/вызов настроек AF).
14. Добавлена поддержка съемки DPRAW .
19. Устранена проблема, при которой камера могла не распознаваться при подключении к смартфону по USB.
RE[Виктор]:
от:Виктор
Приятные фото, только везде мыло на глазах.
RE[valser61]:
от: valser61
Под Санкт-Петербургом, место называется Колтушские высоты.
