Panasonic S5,S9 все версии (S5, S5II, S5IIX, S9)
Всего 4545 сообщ. | Показаны 1 - 20
Panasonic S5 все версии (S5, S5II, S5IIX)
Уже принимаются предзаказы.
Panasonic S5 Camera Overview
LUMIX S5 full-frame mirrorless camera is designed especially for content creators. Latest advances in image resolution, image stabilization, and autofocus all in this compact camera that is the signature of LUMIX. Experience extraordinary video recording in 4K 60p, 4:2:2 10-bit. It also offers a Full HD 180fps Slow Motion option as well as 4:3 Anamorphic support. This is what makes S5 perfect for use when taking still photos or as a vlog camera.
With 24.2MP 35mm full-frame CMOS sensor, the LUMIX S5 boasts a wide dynamic range and high sensitivity performance. The adopted Dual Native ISO technology enables the LUMIX S5 to record maximum ISO 51200 crystal-clear high sensitivity video. Dual Native ISO minimizes noise in high sensitivity. V-LogN-Gamut compatibility offers a 14+ stop dynamic range to capture every detail.
The improved autofocus detects head as well as eyes, face and body. The powerful Dual Image Stabilization with 5-axis enables a 6.5-stop slower shutter speed.
The compact nature of the S5 is one of the signature features of the LUMIX series. To make sure that your camera withstands tough field use, the S5 comes with a dust and splash resistant construction. Optimized heat dispersion ensures a stable, continuous video recording without interruption.
One of the expanded features of LUMIX S5 is the Live View Composite mode which instantly creates a stunning image out of several live shots; the shutter releases at designated intervals of exposure time to merge the bright parts into a single image. Useful for shooting fireworks or a starry sky.
In USA Panasonic “LUMIX S5” the cost will be $1997.99 for the body and $2297.99 for the lens kit.
Panasonic S5 Full Specification
-Sensor: 24.2MP effective, full-size CMOS with a total number of pixels of 25.28MP-
Dust reduction: Sensor shift type
-Dynamic range: 14 steps + (V-Log ) -Still
image: JPEG, RAW, HLG, 6K/4K photo
-Video: 4K59.94p/200Mbps (4:2:0 10bit LongGOP), 4K29.97p/150Mbps (4:2:2 10bit LongGOP)-EVF
: Organic EL, 2.36 million dots, magnification 0.74 times, eye point 20mm, 120fps
-Monitor: 3 type liquid crystal 1.84 million dots, touch panel, free angle, 3:2
-AF: contrast AF, DFD, face/pupil recognition, body recognition, Animal recognition, -6 to 20EV
-Metering system: 1728 split multi-pattern metering, EV0 to 18
-ISO sensitivity: 50-204800
-Dual native ISO: Normal 100 and 640, V-LOG 640 and 4000, HLG 400- 2500, 200 and 1250 with Cinelike D2/V2-
Image stabilization: Sensor shift type, 5 axis, 5 steps effect (6.5 steps for dual IS, dual IS2 also supported)
-Shutter: 1/8000 seconds-60 seconds , Electronic front curtain 1/2000 seconds-60 seconds, electronic 1/8000 seconds-60 seconds, silent mode available
-Sequential shooting: 7 frames/sec for AFS/MF, 5 frames/sec for AFC, 30 frames/sec for 6K photos, 60 frames/sec for 4K photos-
USB port: USB3.1 Gen1 Type-C
-HDMI port : MicroHDMI TypeD-
Microphone terminal, headphone terminal, remote input, XLR (optional) -Card
slot: Dual, SD/SDHC/SDXC, slot 1 supports UHS-II
-Wi-Fi: 2.4G, 5G
-Bluetooth: v4.2
– dust and water specifications
– battery: lithium-ion, 2200MAh
– battery life: 440 sheets (monitor), 470 sheets (EVF), 1500 sheets (EVF power save mode)
– battery grip: DMW-BGS5 (optional)
– dimensions: 132.6×97.1×81.9mm
-Weight: 714 grams (including SD card battery), 630 grams (body only)
сравнение Кенон 5д Мк2 /Кенон R6 /Panasonic S5
https://vmirefoto.blogspot.com/2022/01/canon-r6-panasonic-s5.html
обзор на Rtings
https://www.rtings.com/camera/reviews/panasonic/lumix-dc-s5
Настройки АФ
Lumix AF Guidebook
Скачивать здесь:
https://www.panasonic.com/global/consumer/lumix/technologies/af.html
Таблица совместимости (на основании отзывов в теме) линз Canon EF с адаптерами:
Sigma MC-21
Canon 16-35 f4 IS USM L - работает
Canon 100 f2.8 IS USM Macro L - работает
Canon 50 f1.8 STM - работает (есть жалобы)
Canon 50 f1.2L - работает (есть жалобы)
Canon 70-200 f4 - в целом работает нормально, но есть важный нюанс - с разными экземплярами могут быть разные фокусы. Один, например, не фокусировался на расстоянии свыше 3 метров, другой наоборот на мдф не мог навестись. Поэтому перед покупкой надо тщательно проверять работу конкретного образца. В целом по съемке все работает нормально, понятно, что бывают приколы с фокусом (иногда фокусировка идёт на рандомную точку просто).
Canon 85 f1.8 USM - работает
Canon 135 f2.0 USM L - практически не работает (ограниченно фокусируется на средние дистанции после нескольких попыток)
Fotodiox
Canon 135 f2.0 USM L - работает
Претензии по работе с адаптерами не принимаются, информация "как есть".
Panasonic Lumix S5 II и S5 IIX
Версия Panasonic Lumix S5II не может писать видео в разрешениях 5.8K ProRes 422/422HQ (23.98/24/25/29.97к/с), DCI 4K/UHD ProRes 422/422HQ (23.98/24/25/29.97/50/59.94к/с), 3.3K (4:3) ProRes 422/422HQ (23.98/24/25/29.97/50к/с), FHD 4:2:2 10-бит (23.98/24/25/29.97/47.95/48.00/50/59.94/100.00/119.88к/с) на внешний SSD через провод USB-C, в то время, как модель S5IIX это делает.
Кроме того, Panasonic Lumix S5 IIX поддерживает потоковую передачу по IP через Wi-Fi, USB или Ethernet, а также USB-модем.
Panasonic Lumix S5 II (DC-S5M2K)
Байонет Leica L
Полнокадровый сенсор на 24МП 6000 Х 4000 и 12000 Х 8000 с функцией High Resolution
Встроенный 5-осевой стабилизатор изображения на 6.5 ступеней
Гибридная система фокусировки с 779 фазовыми точками фокусировки, чувствительность -6 +18 EV
ISO 100-51.200 с возможностью расширения до 50-204.800
Двойное нативное ISO 640 и 4000
Затвор электронный или механический от 60 секунд до 1/8000 секунды, механический с первой электронной шторкой только до 1/2000 секунды. Выдержка синхронизации 1/250 секунды
Скорость серийной съёмки на механическом затворе 9 к/с и 30 к/с с электронным
Видео: DCI/UHD 4K 60p Full Frame 4:2:2 10-bit без ограничения по времени
6K 30p Full Frame 4:2:0 10-bit 200 Mb/s до 30 минут, 12-бит через HDMI
V-Log, Hybrid Log Gamma
Встроенный вентилятор охлаждения
ЭВИ на 3.680.000 точек, с увеличившим 0.78х и 100% покрытием, частота от 60 до 120 к/с
Основной дисплей на 1.840.000 точек с диагональю 3 дюйма
2 слота для карт-памяти SDXC, оба с поддержкой UHS-II
USB Type-C (для зарядки и/или передачи данных), HDMI, разъем 3.5 мм для наушников, разъем 3.5мм для микрофона, Bluetooth и Wi-Fi
Защищённый корпус от пыли и влаги
Вес 744 грамма (с батареей и картой памяти)
https://www.panasonic.com/uk/consumer/cameras-camcorders/lumix-mirrorless-cameras/lumix-s-full-frame-cameras/dc-s5m2k.html
Panasonic Lumix S5IIX (DC-S5M2X)
Байонет Leica L
Полнокадровый сенсор на 24 МП, изображения 6000 Х 4000 и 12000 Х 8000 с функцией High Resolution
Встроенный стабилизатор IBIS на 6.5 ступеней
Серийная съёмка на механическом затворе 9 к/с и 30 к/с с электронным
Видео DCI/UHD 4K 60p Full Frame 4:2:2 10-bit до 400 Mb/s без ограничения по времени
6K 30p Full Frame 4:2:0 10-bit 200 Mb/s до 30 минут, 12-Bit через HDMI
Стриминг через USB 5776 X 3056 30к/с 10-бит
IP стриминг 3840 x 2160 60к/с
Запись данных на SSD через USB
Встроенный вентилятор для охлаждения
2 слота для карт SDXC, оба с поддержкой UHS-II
USB Type-C для зарядки и передачи данных, HDMI, разъем 3.5 мм для наушников, разъем 3.5мм для микрофона, Bluetooth и Wi-Fi
https://www.panasonic.com/uk/consumer/cameras-camcorders/lumix-mirrorless-cameras/lumix-s-full-frame-cameras/dc-s5m2x.html
ссылка на презентацию:
https://youtu.be/WjvZgZSpRWU
Обзоры:
DPReview TV: Panasonic S5 II Review
https://youtu.be/LSvKwCrmIYM
Panasonic Lumix DC-S5 II / DC-S5 IIX initial review
https://www.dpreview.com/reviews/panasonic-lumix-dc-...
Panasonic announces $800 Lumix S 14-28mm F4-5.6 Macro lens for L-mount camera systems
https://www.dpreview.com/news/5178668433/panasonic-a...
Panasonic Lumix S5 II Review: BETTER THAN SONY!
https://youtu.be/r0QoX81-dFk
Panasonic Lumix S5II | In The Field - Adorama
https://www.youtube.com/watch?v=8Iaowg3WKN4
Panasonic Lumix S5 II and S5 IIX: The Wait is Over; Panasonic is BACK!
https://www.youtube.com/watch?v=A06GnDOx0vE
LUMIX S5 II with Phase Detect Autofocus! And it works Great!!
https://www.youtube.com/watch?v=TtfAE9SEcXM
Panasonic S5 II Review - Finally with Phase Detection AF [ Lumix S5II ]
https://www.youtube.com/watch?v=aF8IO1A5H4M
Обзор Panasonic Lumix S5 II
https://www.cameralabs.com/panasonic-lumix-s5-ii-rev...
Panasonic Lumix S5 II for PHOTOGRAPHY review: BEST value full-frame vs R6 II A7 IV?
https://www.youtube.com/watch?v=LxtNJLbyqxw
https://youtu.be/FYebjEgf3J0
Panasonic S5 II Review: Unbeatable Value
https://youtu.be/g4gUOuskxHw
Welcome To The Panasonic Era: S5 II vs Sony & Canon
https://youtu.be/fdAPBWoXqBQ
Panasonic S5 II - Review and Comparison to Sony A7IV
https://youtu.be/LxtNJLbyqxw
https://youtu.be/NylsUcOfCuU
Panasonic Lumix S5 II :: Its REALLY good
Lumix S5ii VS Sony A74 - Who Now Leads The AF Race?!
https://www.youtube.com/watch?v=MSHU-hmhAls
https://youtu.be/PMYEC1v2sBw
Sony A7IV vs Panasonic S5 II - Hybrid Comparison
https://youtu.be/3jWoirxDCCw
Who is the New King of Autofocus? Panasonic Lumix S5II vs Sony A7IV vs Canon R6II
https://youtu.be/Y5auV2JC7fc
Panasonic Lumix S5 II Review (& S5IIx) - the best value for money hybrid camera in the market
https://youtu.be/mth5cV9hFYM
The Truth about Panasonic Lumix S5II Animal Autofocus
https://youtu.be/P8bZkR_6Tf8
Gimbal like IBIS? Panasonic Lumix S5 II Inbody Image Stabillisation Test - Active I.S. Lumix S5 II Inbody Image Stabilisation System (Active I.S.) Test
vs Lumix S5 vs Canon R6II vs Sony A7IV vs A7RV
https://youtu.be/KCB3taBRRMs
Panasonic Lumix S5II Tutorial: Best Video Settings & Features (100% Free)
Panasonic S5II вход в сервисное меню
1. Включите камеру и сделайте снимок.
2. Отключите камеру
3. Выберите режим одиночных снимков (single shot)
4. Нажав и удерживая одновременно кнопки PLAYBACK и AF/AE LOCK, включите камеру. Теперь вы находитесь в режиме обслуживания (Temporary Service Mode), хотя на первый взгляд ничего не заметно. Можно убедиться, что включен сервисный режим: если перейти в меню настроек (с «гаечным ключом»), на его последней странице появится отсутствующий в обычном режиме пункт — «ROM BACKUP»
5. Чтобы перейти в меню, удерживая нажатой кнопку PLAYBACK, нажмите одновременно кнопки MENU/SET и Влево
6. Повторно нажав и удерживая PLAYBACK, нажмите одновременно MENU/SET и Влево. Откроется двухстраничная история операций
7. Для переключения между страницами нажимайте кнопку DISPLAY
Значения в истории операций
В истории операций можно узнать:
количество включений камеры — PWRCNT,
число срабатываний затвора — SHTCNT и
вспышки — STBCNT, а также, если интересно
число автоматических отключений — PSVCNT.
Re[Лич]:
Интересно, сильно ли лучше аф у этой модели, нежели у предыдущих?
Re[Лич]:
Чуть с другого ресурса:
Характеристики Panasonic S5
Крепление: L-Mount/Leica L
Сенсор: 35.6 x 23.8 мм, 24.2 МП, CMOS, 5-осевая стабилизация до 6.5 ступеней Dual I.S. 2
Чувствительность: ISO 50-204800
Двойной базовый ISO: 100, 640
Двойной базовый ISO V-Log: 640, 4000
Двойной базовый ISO HLG: 400, 2500
Двойной базовый ISO Cinelike D2/V2: 200, 1250
Автофокусировка: 225-зонная, контрастная, DFD
Режимы автофокуса: AFS, AFC, Авто: Лицо, Глаза, Тело, Животные, Выборочный: Лицо, Глаза, Тело, Животные, Слежение, 1-зонный, Точечный
Пост-фокус: Есть
Фокус-стекинг: Есть, до 999 кадров
Выдержка: от 1/8000 до 60 сек. (механический затвор), от руки до 30 мин., от 1/6000 до 1/2 (видео)
Серийная съемка: до 7 к/с (буфер более 24 кадров)
6K Photo: 30 к/с
4K Photo: 30 к/с, 60 к/с
Синхронизация: 1/250 сек., по 1/2 шторке
Беспроводное управление вспышками: DMW-FL200L, FL360L, FL580L, 4 канала
Формат фото: JPEG, RAW, HLG, 6K Photo, 4K photo
Видео FF: 4K 30p 4:2:2 10-bit 100 Мбит/с, 4K 24p 4:2:2 10-bit 150 Мбит/с, FullHD 24/30p/60p 4:2:2 10-bit 100 Мбит/с, H.264, H.265, MOV, MP4
Видео APS-C: 4K 60p 4:2:0 10-bit 200 Мбит/с, 4K 30p 4:2:2 10-bit 100 Мбит/с, 4K 24p 4:2:2 10-bit 100 Мбит/с
Замедленное видео: до 180 к/с в FullHD
Поддержка LUT: Для экрана и для HDMI-вывода
ОВИ: 0.74x, OLED, 2.36 млн. точек, 120/60 Гц
Экран: 3", сенсорный поворотный экран, 1.84 млн. точек
Разъемы: USB Type-C 3.1, MicroHDMI Type-C (4:2:2 10-bit), 2.5-мм порт удаленного управления, 3.5-мм вход для микрофона (MIC/LINE), 3.5-мм выход на наушники
Карты памяти: два слота SD UHS-I + SD UHS-II
Беспроводная связь: Wi-Fi 2.4/5 ГГц, Bluetooth 4.2 LE
Защита от влаги и пыли: Есть
Батарея: 440 кадров (до 1500 кадров в режиме энергосбережения) 2200 мАч, 7.2 В, 16 Вт*ч, зарядка через USB
Питание через USB: Есть
Габариты: 132.6 x 97.1 x 81.9 мм
Вес: 630 г (корпус), 714 г (с батареей и картой памяти)
По представленным данным видно, что камера поддерживает запись 4K 60p только с кропом Super35/APS-C, при этом кодирование происходит с десятибитной глубиной и потоком 200 Мбит/сек. Однако глубина кодирования цвета в этом режиме только 4:2:0. Чтобы получить 4:2:2 придется «замедлиться» до 24 или 30 к/с. Указывается, что камера позволяет переключаться между PAL и NTSC, чтобы пользователю были доступны необходимые частоты видеосъемки.
Доступна видеозапись в формате «Anamorphic 4K» 3328x2496 с соотношением сторон 4:3. Даже при использовании самой обычной оптики это позволит в некоторых случая получать более гибкий материал для публикации в разных медиа. Но частота этом режиме не может превышать 30 к/с, зато неплохо с объемом сохраняемых данных: 4:2:2 10-бит.
В характеристиках указаны размеры фотографий, которые превышают 24 мегапиксела: 12000x8000 и 8496x5664. Похоже, что в Lumix S5 есть режим съемки с высоким разрешением. Результирующие размеры кадра составляют соответственно 96 и 48 мегапикселов.
Для камеры будет доступна батарейный блок DMW-BGS5 для более уверенного вертикального хвата.
Сходу бросается в глаза только уменьшенное разрешение видоискателя — 2.36 млн. точек против 5.76 у Lumix S1. Конечно, Lumix S5 будет легче на 300 граммов, что нельзя не приветствовать, но это все равно довольно крупная камера, при которой осталась защита от непогоды!
Корпус модели S5 будет на 16 мм уже, на 13 ниже и на 15 мм менее «глубокий», чем S1. Однако, это все равно больше Sony A7 III, с которой, видимо, будет конкурировать новая камера.
Re[С-скиталец]:
от: С-скиталец
Бедная 7-3, с ней уже третий год конкурируют все кому не лень, а 7-4 то уже на подходе.)))
2 сентября выйдет, обзорщики опубликуют, почитаем...
Re[Лич]:
пока главный вопрос S1 продается зарубежом по $1999
новая камера будет точно по этой же цене.
какие причины купить S1 вместо S5 и наоборот?
кто что думает?
какие причины купить новый S5 а не новый canon или Nikon?
Re[Лич]:
Ну если исходить только из цены, то Z5 конечно интересней получается
Re[Лич]:
так или иначе, цена - важный фактор выбора покупки камеры.
лично у меня в планах была покупка S1 , сейчас уже думаю, может сабж лучше.
по комментариям к новости в дпревью многие указывают, что S5 при таких характеристиках должна быть около $1400 -$1500 чтобы успешно конкурировать как с S1 так и с конкурентами.
Re[Лич]:
Какой ажиотаж вокруг новинки))
Фотору как лакмусовая бумажка мертвого фоторынка.
Re[Лич]:
Обратил внимание:
"-EVF: Organic ELOrganic EL, 2,36 миллиона точек..." - это просто OLED или что-то новое?
-"Bluetooth: v4.2"... - уже давно в ноунейм безделушках используют блютуз 5.0)))
Re[Лич]:
новая тушка ожидается, что-то пока тишина насчет новой оптики...
Re[Александр Барабанщиков]:
от: Александр Барабанщиков
Вряд ли все те же грабли контрастного АФ никто не отменял…
Re[Лич]:
цены на объективы сравнимы с RF объективами :)
Re[isi]:
Судя по видосам, точечный неплох, слежение улучшили, но все еще не очень
Re[Лич]:
https://X.ru/reviews/21282-panasonic-lumix-dc-s1-i-dc-s1r-test
X= prophotos
Сколько она будет стоить у нас, интересно?:)) Как по мне, равки интереснее даже чем у R5
Re[Шуруп]:
Она, шо килограмм весит?
Re[Лич]:
714 г (корпус с батареей и памятью), 630 г (только корпус)
Re[Шуруп]:
от: Шуруп
Это не сложно
Проявил сэмпл Профото с улучшайзерами Диксио и профилем по вкусу, намеренно не трогая ББ - ИМХО, ни одна ЦЗК сегодня (кроме Зет-7) не может, без долгой возни, выдать такой приятной и чистой картинки:
Как по мне - мадженты все-равно многовато, но это даже и удобно - не надо лезть в ЭКСИФ, чтобы знать, что это Панасоник
Что скажешь - уважаемый эксперт по цвету? ;)
Re[Лич]:
Но главный плюс тут - китовый объектив. Для видеографов и любителей путешествий, это лучшая ФФ-камера на сегодня. В видео Панасоник был и есть лучше всех, а для тревела зума компактнее и удобнее 20-60 мм. не найти.
Да только какой сейчас тревел?
Re[www user]:
ну уважаемые эксперты по цвету тебе ответят отдельно, я надеюсь. А как по мне, похоже этот панас даже лучше чем р5
ну мне так показалось- насыщается хорошо, хорошо обрабатывается
если почитать про видево, то вообще вах- вах-вах
Re[Лич]:
из под рэп:
https://b.radikal.ru/b16/2011/7d/6a74871858a9.png
