Fujifilm X-Pro3 Specs
Price
MSRP $1799 (standard finish, body only), $1999 (DR finish, body only)
Body type
Body type Rangefinder-style mirrorless
Sensor
Max resolution 6240 x 4160
Image ratio w:h 3:2
Effective pixels 26 megapixels
Sensor size APS-C (23.5 x 15.6 mm)
Sensor type BSI-CMOS
Processor X-Processor 4
ISO Auto, 160-12800 (expands to 80-51200)
Boosted ISO (minimum) 80
Boosted ISO (maximum) 51200
Custom white balance Yes
Image stabilization No
Uncompressed format RAW
JPEG quality levels Fine, normal
Optics & Focus
Autofocus
Contrast Detect (sensor)
Phase Detect
Multi-area
Center
Selective single-point
Tracking
Single
Continuous
Touch
Face Detection
Live View
Manual focus Yes
Number of focus points 425
Lens mount Fujifilm X
Focal length multiplier 1.5×
Screen / viewfinder
Articulated LCD Tilting
Screen size 3″
Screen dots 1,620,000
Touch screen Yes
Screen type TFT LCD
Live view Yes
Viewfinder type Electronic and Optical (tunnel)
Viewfinder coverage 95%
Viewfinder magnification 0.78× (0.52× 35mm equiv.)
Viewfinder resolution 3,690,000
Photography features
Aperture priority Yes
Shutter priority Yes
Manual exposure mode Yes
Subject / scene modes No
Built-in flash No
External flash Yes (via hot shoe)
Self-timer Yes
Metering modes
Multi
Center-weighted
Average
Spot
Exposure compensation ±5 (at 1/3 EV steps)
WB Bracketing Yes
Videography features
Format MPEG-4, H.264
Modes
4096 x 2160 @ 30p / 200 Mbps, MOV, H.264, Linear PCM
4096 x 2160 @ 25p / 200 Mbps, MOV, H.264, Linear PCM
4096 x 2160 @ 24p / 200 Mbps, MOV, H.264, Linear PCM
4096 x 2160 @ 23.98p / 200 Mbps, MOV, H.264, Linear PCM
3840 x 2160 @ 30p / 200 Mbps, MOV, H.264, Linear PCM
3840 x 2160 @ 25p / 200 Mbps, MOV, H.264, Linear PCM
3840 x 2160 @ 24p / 200 Mbps, MOV, H.264, Linear PCM
3840 x 2160 @ 23.98p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 120p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 100p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 60p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 50p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 30p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 25p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 24p / 200 Mbps, MOV, H.264, Linear PCM
1920 x 1080 @ 23.98p / 200 Mbps, MOV, H.264, Linear PCM
Microphone Stereo
Speaker Mono
Storage
Storage types Dual SD/SDHC/SDXC slots (UHS-II support)
Connectivity
USB USB 3.1 Gen 1 (5 GBit/sec)
HDMI No
Microphone port Yes
Headphone port No
Wireless Built-In
Wireless notes 802.11b/g/n + Bluetooth
Remote control Yes (wired, cable release or smartphone)
Physical
Environmentally sealed Yes
Battery Battery Pack
Weight (inc. batteries) 497 g (1.10 lb / 17.53 oz)
Dimensions 141 x 83 x 46 mm (5.55 x 3.27 x 1.81″)
Other features
Orientation sensor Yes
GPS None
Встречаем новый Fujifilm X-Pro 3 (стоит ли "овчинка" две цены X-T30?)
Всего 162 сообщ.
Встречаем новый Fujifilm X-Pro3..
Re[skusha]:
Представлена беззеркальная камера Fujifilm X-Pro3
Она получила титановый корпус и покрытие Duratect
В описании новинки производитель отмечает прочный корпус с наружными элементами из титана. Он целиком окрашен в черный цвет. Кроме того, будут предложены два цветовых варианта с покрытием Duratect, устойчивым к появлению царапин и придающим камере дополнительную внешнюю привлекательность. Их можно отличить по буквам DR.
В камере используется датчик изображения, который производитель называет «X-Trans CMOS 4 с обратной засветкой». Его формат — APS-C, разрешение — 26,1 Мп. Обработкой данных занят процессор X-Processor 4, уже используемый в камерах Fujifilm X-T3 и X-T30. По словам производителя, фазовая система автофокусировки работает при освещенности до -6 EV. Фотографу доступны значения светочувствительности в диапазоне ISO 160-12800, который можно расширить до ISO 80-51200.
Камера оснащена «улучшенным гибридным видоискателем», в котором оптический канал совмещен с дисплеем OLED с возможностью переключения между ними. Видоискатель охватывает 95% кадра, разрешение дисплея — 3,69 млн точек. Кроме того, есть жидкокристаллический дисплей, но в закрытом положении он невиден — примерно, как у ноутбука. Для использования его нужно открыть, отклонив вниз на угол до 180°. В закрытом положении вместо трехдюймового сенсорного дисплея виден небольшой вспомогательный дисплей размером 1,28 дюйма, куда по умолчанию выводятся сведения о том, какая пленка сейчас эмулируется, а также значения ISO и баланса белого.
Камера способна снимать видео с разрешением до 4096 x 2160 пикселей или 3840 x 2160 пикселей и кадровой частотой до 30 к/с. Уменьшив разрешение до 1920 х 1080 пикселей, можно поднять кадровую частоту до 120 к/с.
Встроенной вспышки нет, но есть горячий башмак. Камера оснащена микрофоном и громкоговорителем, разъемом для внешнего микрофона, двумя слотами для карт SD, SDHC и SDXC (с поддержкой UHS-II), интерфейсами Wi-Fi IEEE 802.11b/g/n и Bluetooth. В оснащение камеры также входит порт USB USB 3.1 Gen1, выведенный на разъем USB-C. Его можно использовать для передачи данных и зарядки аккумулятора камеры.
Камера защищена от пыли и брызг, сохраняет работоспособность при температурах до -10 °С. Ее размеры равны 141 x 83 x 46 мм, масса составляет 497 г.
В продаже камера должна появиться в конце ноября по рекомендованной цене 1800 долларов за вариант Black и 2000 долларов — за варианты DR Black и DR Silver. В России эти цены примерно равны 133 000 и 147 000 рублей соответственно.
Re[skusha]:
Чувствуете интерес какой?
Симпатичная коробочка
https://youtu.be/yRGF8wo2up4
Re[skusha]:
Это эпичный провал с экраном.
Его нельзя перевернуть и поставить на место, чтобы он не торчал.
Сама по себе идея крута, но что стоило доработать конструкцию?
Сделать как на оликах, панасах, канонах простой, отработанный тысячу раз поворотный экран, но - двусторонний, коль уж придумали такую идею.
Но эта конструкция... это фэйл.
Нет стабилизации в тушке. Опять. Я молчу про Сони, панасы, олики и даже лейку.
Блин, в Рико уже есть стаб!!! В Рико - самой консервативной камере эвер.
Нет 4к 60р. Вроде и фиг с ним, но ведь очевидно, что тупо зажали.
Фудзи так хорошо начинали с серией х-про. И вот этим облажаться...
мдэ.
мдэ.
Re[muar]:
Их вчера в стеклянной призьме к нам в больницу привезли (c)
Re[skusha]:
от: skusha
Она ещё и разговаривает!
Re[stronzo]:
от: stronzo
В данной "больнице" на любой вкус и цвет всякого есть.
Re[kaven]:
от: kaven
Быть может задумка такая?
Мол на кой пялиться в экран, есть гибридный ЭВИ (чудно какой-то) в него и смотрите ;)
Re[skusha]:
ЯМ уже заказы принимает. ДУРУ за 147тр. впаривают.
Re[skusha]:
Не надо пытаться ездить по тундре на Роллс-Ройсе..для этого есть машины как минимум 2-3 за одну цену Ройса
Т30 это не Pro3 это Е3
То и PRO3.
Раскрытие дисплея в низ конечно ошибка,но второй маленький отличная идея,но и эта камера не для cэлфиидиотов.
То и PRO3.
Re[skusha]:
камера для души - с удовольствием такой пофотал бы - но и первой прошкой фотать в кайф)
Re[skusha]:
Камера интересная. Но мне кажется, что с экраном есть такой просчет. Допустим, вы откинули экран на 90 градусов. И тут вам нужно срочно посмотреть в видоискатель. При этом вы будете лицом упираться в этот экран. Придется туда-сюда его раскрывать.
Вообще, хорошо, что фуджи экспериментируют. Например, в X-T100 они сделали экран, который одновременно может откидываться и вниз-вверх (как на X-T20), но также и вбок (как на Pen F).
Re[Pomo]:
от:Pomo
Камера интересная. Но мне кажется, что с экраном есть такой просчет. Допустим, вы откинули экран на 90 градусов. И тут вам нужно срочно посмотреть в видоискатель. При этом вы будете лицом упираться в этот экран. Придется туда-сюда его раскрывать.Подробнее
И проблемы при съемке со штатива. Площадка просто не позволяет его нормально открыть. У dpreview в видеобзоре есть.
Re[Pomo]:
от:Pomo
Вообще, хорошо, что фуджи экспериментируют. Например, в X-T100 они сделали экран, который одновременно может откидываться и вниз-вверх (как на X-T20), но также и вбок (как на Pen F).Подробнее
Мне кажется это не просчет, а сделано как раз намерено. Просто тупо убрать экран совсем, было бы слишком даже для фуджи, вот и решили сделать его откидным, что стимулирует чаще смотреть в видоискатель, ну и для любителя снимать "от пуза" нормально будет, камера же больше под стрит заточена. Упор на максимально ретро - экспирианс и акцент на фирменном видоискателе. Камера стала еще более нишевой и подойдет точно не всем, но она изначально не для всех и проектировалась и это хорошо. Абсолютно согласен с тем, что компания постоянно экспериментирует и пытается делать что то свое, а не тупо штампует очередной безликий девайс, о котором через неделю уже никто и не вспомнит.
Re[Saturnus]:
На одной из последних леек вообще нет экрана, кстати :)
Re[skusha]:
А картинки инструмента есть?
Re[igorsphoto]:
На DPreview есть. Матрица та же самая, что на X-T3, так что отличия будут мизерные. Вроде, новую пленку добавили.
Re[igorsphoto]:
от: igorsphoto
там то же железо, что и на Т3/Т30, просто слегонца допилен АФ прошивкой , а что то спецом обрезано (видео возможности в некоторых моментах) и новая "пленка" имеется. В остальном - такое же все будет 1:1
Re[Pomo]:
от:Pomo
На DPreview есть. Матрица та же самая, что на X-T3, так что отличия будут мизерные. Вроде, новую пленку добавили.Подробнее
Отличия в эргономике, на Х-Т3/30 её нет, новинку нужно самому пробовать. https://www.youtube.com/watch?v=-r1bUUbFjy4
