Fujifilm X-T20 и X-T30 облегченные версии флагманов X-T2/T3
Всего 7783 сообщ. | Показаны 5361 - 5380
Re[SpacemanUA]:
от:SpacemanUA
Портреты клевые получились!! Особенно второй понравился
Re[max err]:
Samyang 50mm 1.2, iso800, 1/180 (adobe std)
Samyang 50mm 1.2, iso800, 1/180 (Acros)
Re[photokitteh]:
от: photokitteh
Если над фото надо сидеть в редакторе, надо сидеть долго, значит на этапе съёмки/подготовки что-то было сделано не так.
Или есть желание сделать не так как было на самом деле...
Re[rus-lis]:
Fujifilm X-T20 Firmware Update (ver. 2.00) – available beginning of April
Improved AF tracking
With the newly developed scene recognition algorithm, the camera can track even smaller moving objects twice as fast as with the previous firmware version.
Improved touchscreen operation
With the update, the X-T20 receives many of the touchscreen features already familiar from the FUJIFILM X-E3:
1. Enlarge display: When you double-tap, the picture is magnified and centered on the focus point.
2. Focus range selection: The user can move the focus point even when magnified.
PRESS RELEASE
Page 1 of 3
3. Zoom in / out: If you split or contract two fingers on the display, you can now also change the thumbnail (9 pictures / 100 pictures).
4. Select an image from the thumbnail view by tapping or dragging the image, or double-tap to full view.
5. Function Selection via Quick Menu (Q)
6. On-screen keyboard *
* Except for some functions.
Compatible with “FUJIFILM X RAW STUDIO”
With the FUJIFILM X RAW STUDIO software, RAW data can be converted using the on-board X-Processor Pro when the camera is connected to the computer via a USB cable. Fast batch processing of several recordings in quick succession is also possible. “FUJIFILM X RAW STUDIO” is available as a free download on the FUJIFILM website.
User-defined operation of the FUJINON XC15-45mmF3.5-5.6 OIS PZ
After updating the firmware, the operation of the new zoom lens FUJINON XC15-45mmF3.5-5.6 OIS PZ can be configured as follows:
1. Occupy focus ring with zoom function
2. Maintaining the zoom position during time-lapse recording
3. Maintaining the zoom position in playback mode (faster
Readiness to reactivate the recording mode)
More flash functions for radio remote control of studio flash units
With the update, the high-speed flash synchronization and the TTL flash exposure mode can now also be used with radio remote control of compatible studio flash units from other manufacturers.
Display RGB histogram and overexposure warning
A function key can be used to fade in the RGB histogram as well as to activate the overexposure warning (blinking of overexposed areas).
Enlarged and custom viewfinder display
With the firmware update, the information displayed in the viewfinder and on the display can be enlarged. The position of the display can now also be selected by the user.
Re[max err]:
Ковырялся в летних снимках, нашел интересного комарика.
Re[max err]:
Любителям деталек
Панорама Дивногорье
Re[max err]:
Re[Ilya Shor]:
от:Ilya Shor
Мне понравилось.
Re[SpacemanUA]:
отличные новости, Фуджифильм в очередной раз подтвердила, что не обходит и "бюджетные" камеры вниманием.
Re[Ilya Shor]:
понравилась тоже
SpacemanUA, vipches1
приятные портреты :)
Re[Ilya Shor]:
от:Ilya Shor
Очень приятно получилось, душевно
Re[SirPalomid] [max err] [serg67]:
Re[max err]:
благодарю :)
Re[max err]:
Re[max err]:
И немного живности
Re[max err]:
XF35F2
Re[vipches1]:
от:vipches1
Ну прямо до дрожи пробирает! Очень эмоциональный портрет.
Re[max err]:
Небольшая сессия с моими девчонками и лошадкой XF18-55.
Re[vipches1]:
от:vipches1
И немного живности
Я так понимаю это Самянг 135 у Вас? Красивое размытие и сам сюжет очень интересный. Сириус Блэк вернулся? :D
