Nikon D810
Всего 426 сообщ. | Показаны 1 - 20
Nikon D810
Характеристики:
- Sensor size is 36.35MP
- picture control settings can be set in 0.25EV adjustments
- new 'clarity' picture control (adjusts local contrast) along with 'flat' for CINE style color reproduction/flat tonal curve
- new phase detect AF algorithm
- live view manual focusing aid (50/100/200% image enlargement)
- newly designed mirror drive and mirror balancer
- manual white balance has been improved (0.5 down to 0.25 step control for finer adjustments in both the temperature and tint
- approx. 100% FoV with Optical Viewfinder
- Organic EL display in viewfinder (an FX first), permitting easier readability in bright conditions and quicker response times in colder environments
- In camera HDR (range of 3 EV)
- IP-B H.264
- FX and DX crop mode during video - easily switched by pressing the new 'i' button
- Zebra highlight control during video rec. ('i' button control)
- MOV format, H.264/MPEG-4AVC, as backup data can be simultaneously recorded in Full HD 1080/60p to the camera's memory card
- 5 frames / second maximum, up to 100 frames up to FX format
- 6fps 1:2/DX ratio
-7fps DX with MB-D12 (requires: AC Adapter EH-5b (sold separately)/Li-ion rechargeable battery EN-EL18a (sold separately)/AA batteries
- 0.12 seconds startup time
- 0.052 release time lag
- when cropped from FX image area, sides of frame are masked
- 170 degree viewing ability on the back screen; glass panel RGBW array with custom color adjustment
- Quick access to frequently used functions 'i' button
- Precise horizontal alignment; can be called up by the 'i' button
- i-TTL inbuilt flash (24mm wide view); 12m ISO 100 @ 20C; i-TTl dimming available
- shutter is self checking (much like the F5, D3, D4 series) (for errors)
- Advanced dust-proof and drip-proof performance robust body of magnesium alloy (While maintaining the robustness of the equivalent to the D800 series, and has achieved a further weight reduction)
- grip reviewed better support
- CF Type 1 UDMA support; SDHC, SDXC with UHS-I standard)
-approx 1200 frames on EN-EL15 battery CIPA; without using flash 3860 frames were acheived (with I suspect the MB-D12)
Основные характеристики:
— Новая матрица формата FX с разрешением 36,3 млн пикселей: обеспечивает максимальную детализацию изображения и возможности для гибкого кадрирования.
— Сверхширокий диапазон чувствительности ISO: от 64 до 12 800 единиц ISO с возможностью расширения до значений, эквивалентных чувствительности от 32 до 51 200 единиц ISO.
— Серийная съемка со скоростью до 7 кадров в секунду: высококачественные изображения с полным разрешением при съемке со скоростью до 5 кадров в секунду. Изображения с разрешением 15,3 млн пикселей при съемке со скоростью до 7 кадров в секунду в режиме кадрирования DX.
— EXPEED 4: абсолютно новый уровень общей производительности фотокамеры.
— Передовая скорость автофокусировки: 51-точечная система АФ Multi-CAM 3500FX с возможностью создания 9-, 21- и 51-точечного покрытия кадра и понижения чувствительности до −2 EV (ISO 100, 20 °C).
— Режим групповой АФ: быстрое наведение на объект и улучшенная изоляция фона даже во время съемки при недостаточном освещении.
— D-видео с режимом нескольких зон: видеоролики стандарта Full HD (1080p) в форматах FX и DX с частотой кадров 50p/60p. Во время видеосъемки можно использовать диапазон значений чувствительности ISO, начиная с 64 единиц ISO, а также управлять выдержкой, диафрагмой и уровнями звука.
— Файловый формат RAW размера S: создание 12-разрядных высокодетализированных файлов без сжатия в формате NEF от компании Nikon способствует более быстрой передаче изображений и упрощает их последующую обработку.
— Picture Control 2.0: простая последующая обработка благодаря параметру «Равномерный», который доступен при настройке максимального динамического диапазона; точная настройка детализации с помощью параметра «Четкость».
— Высокая резкость: новая конструкция затвора и шахты зеркала, а также электронная передняя шторка обеспечивают максимально возможную резкость изображений.
— Монитор с возможностью настройки цветов: ЖК-монитор с диагональю 8,0 см, разрешением 1229 тыс. точек, антибликовым покрытием и совмещением по технологии RGBW. Поддерживается регулировка цветового баланса и яркости монитора.
— Увеличение с разделенным экраном в режиме Live View: сверхточная проверка выравнивания и резкости изображения. Чтобы воспользоваться этой функцией, нажмите кнопку «i».
— Быстрый и надежный механизм затвора: затвор из сплава углеродного волокна и кевлара, позволяющий осуществлять задержку срабатывания в 52 мс, проверен в стандартном цикле 200 000 срабатываний и отличается выдержкой от 1/8000 до 30 с; при синхронизации вспышки выдержка составляет 1/250 с и длиннее.
— Неограниченная непрерывная съемка: съемка любого количества изображений в формате JPEG и создание превосходных фотографий со световым следом.
— Батарея EN-EL15 высокой емкости: невероятно компактная и легкая литий-ионная аккумуляторная батарея емкостью 1900 мАч (7,0 В). Съемка до 1200 фотографий¹ без дополнительной подзарядки.
— Носители данных: два гнезда для карт памяти, способствующие более продуктивной съемке. Гнездо для карты CF предназначено для высокоскоростных карт UDMA 7, а гнездо для карты SD — для высокоскоростных карт SDXC и UHS-I большой емкости.
— Прочный корпус из магниевого сплава: надежная герметизация защищает фотокамеру D810 от попадания воды и пыли.
- Проводное и беспроводное подключение: поддержка сетей Ethernet и беспроводных локальных сетей. Чтобы установить подключение, воспользуйтесь устройством для передачи данных UT-1 (приобретается дополнительно) и беспроводным передатчиком WT-5.
Обзоры и превью:
-первый "лик"
-оф. сайт nikon.com
-никон.ру
-kaddr.com - на русском
-Hands on techradar
-pocket-lint
старт продаж 17 июля, не у нас )
-first impressions preview dpreview
-превью и сравнение с конкурентами cnet
-обзор imaging-resource
-обзор wexphotographic
Отличия от D800/D800e pdf файл
Первые фото - samle photos, flickr
Re[caramba1]:
Откуда дровишки?
Re[Alexey_Mo]:
http://www.expertreviews.co.uk/
час назад "проговорились", а через пол часа закрыли доступ к статье.
Re[Alexey_Mo]:
NikonRumors немного не успели скопипастить
Re[caramba1]:
Но до фотокины она вряд ли на прилавках появится :) nikon rumors уже давно про нее пишут, только вот iso32 это уже загнули маленько - вряд ли таоке будет. Во всем остальном такие же улучшения как и d4-d4s
Re[tfefirf]:
ну вот кеш гугла - оригинал, дата обзора - завтра
Re[caramba1]:
[quot]Вот он, наследник 36 мегапикселного монстра:
-brand-new 36.3 megapixel sensor [/quot]
сомнительно... Никон матрицы 36Мп не делала, Сонька разве новое что-то выпускала?
Или просто что-то прошивкой допилили?
[quot]-new Expeed 4 image processing engine
-D4S' Multi-CAM 3500FX 51-point AF system [/quot]
понятно. работа над ошибками. молодцы.
[quot]-removed the optical low pass filter [/quot]
в ешке он давно ремувд :)
[quot]-added an electronic front-curtain shutter
-added a new split-screen mode [/quot]
интересно, как они реализовали
[quot]-NO 4K video[/quot]
? на видео забили???
в целом - хорошая работа над ошибками моделей 800(е). посмотрим что получилось в итоге...
Re[Nik79]:
от:Nik79
[quot]-added an electronic front-curtain shutter [/quot]
[quot]-added a new split-screen mode [/quot]
-матрицы: в "е" и "800" - 36,2МП, в 810 -36,3МП;
-"улушения" затвора относятся к съёмке через liveview и кол-ву срабатываний
-сплитскрин - для съёмки архитектуры или пока неясно...
-видео 4к нет, его и в д4с нет, зато докинули 1080@60р
Re[caramba1]:
ну, маловероятно что сони будет делать новую матрицу. скорее всего какие-то косметические улучшения и игры с эффективными пикселями.
думаю что различий будет меньше чем у 6Д и Марк 3 :)
касательно электронного затвора - у 800-к были проблемы с микросмазом на коротких выдержках, в частности из-за хлопка зеркала и вроде и из-за затвора.
интересно, профиксено это или нет.
если не будет откровенных косяков то камера видится вполне. главным будет вопрос цены.
апгрейд с 800-к - смысла думаю нет.
Re[caramba1]:
Чёт не понял, а где крутилка "матричный-центровзвешанный-точечный"????
Брекинг заменили?...хм
Re[АнтонЛЗ]:
Now the metering mode button has moved to the main control dial, making it easier to reach and change when shooting. Making way for it is the Bracket (BKT) button, which moves to the front of the camera.
Re[caramba1]:
Ну менять 800-ку пока смысла нет, а если с 600-ки или с кропа переходить-самое ОНО!
Re[АнтонЛЗ]:
от: АнтонЛЗ
Не вижу я никакого смысла переходить с D600.
Re[Yellowstoner]:
Ценник зверский, в рознице это чудо от 160 тыр будет ст0ить.... Кому оно надо за такую цену?
Re[АнтонЛЗ]:
ИМХО, 600/610 и 800/800е/810 - разные девайсы для разных целей и в разные деньги.
Re[yyv83]:
от: yyv83
судя по тому что по данным из открытых источников Никон вкладывает средства в НИОКР в оборудование для медицины а не в фото для масс и профи, не исключено что никто не рассчитывает на массовые продажи Д810. поэтому нарисуют потолочный ценник. кому надо - купят.
Re[Nik79]:
от:Nik79
А я думаю они уже обожглись опустив цену на 800й ниже плинтуса, все равно массово камера не продавалась, подозреваю что по итогам двух лет Кенон на своем 5д3 мог заработать по более.
Re[isi]:
скажем так - за два года кому реально 36Мп для работы уже купили 800/800е.
и Кенон таких опций не дает. Кому надо 36Мп и мануальная оптика разных брендов и стандартов - не смотрит ни на Кенон ни на Никон.
что думаю уже всем понятно - 36Мп на ФФ имеют сильную специфику и в этом плане 20-24Мп на ФФ существенно более универсальны и удобны.
не верю что выпуск 810 приведет к ажиотажу :)
печалька для тех кто все еще ждет замену Д700- ее как не было так и нет.
Кенон с Марк 3 может в ус не дуть - над ним не каплет уже столько лет :)
Re[Nik79]:
Ну как посмотреть: улучшили фокусировку, подтянули видео, добавили скорострельности - по спецификации плюсов то у морквы3 получается уже нет, не касаясь цвета. А ценник - такой же был в Англии на старте у "е".
