светофильтр UV(0) или UV(C)?
Всего 48 сообщ. | Показаны 41 - 48
Re[tirpir]:
Есть вот такое мнение:
I believe this filter difference calls for a bit of caution. I'm sorry this is so long but my experiences below certainly cleared up some things in my mind. I did not know the difference in these filters except I could usually find the HMC UV(C) version cheaper than the HMC UV(0) version, that is when I could even find both versions for sale. Also I saw a filter test at http://lenstip.com ...icle-UV_filters_test.html and that made me think the HMC UV(0) was the filter I wanted. I am most interested in filtering out the most ultraviolet frequencies right up to 390nm or 400nm where the visible light starts so the frequency transmission charts in their tests were very revealing for me. I went to the Hoya web site at http://www.hoyafilter.com/ They listed an email address for USA support at support@thkphoto.com I sent an email asking what the difference in these filters is. They seemed quite willing to help. I received a prompt reply from Glenn Nash saying... "The HMC UV(0) has the UV protection in the glass, the HMC UV(C) has the UV protection in the multi-coatings." Now I decided the HMC UV(0) was definitely the one I wanted. I ordered a Hoya HMC UV filter from Crutchfield on 6/21/2011 for what seemed to be a pretty good price. In the text of the description it did not state which version the filter was but the picture of the item 'Very Clearly Showed' it was an HMC UV(0). So I ordered it thinking I was getting an HMC UV(0) filter but they sent an HMC UV(C) filter. I called them and they said to return it and they would send the HMC UV(0). After several days I received a phone call saying they only have the HMC UV(C) version and that it replaced the HMC UV(0) version. I didn't totally buy this so I went to the Hoya on line catalog and I could only find the HMC UV(0) version and no mention of the HMC UV(C) version, not sure what that means, maybe I just didn't find it. I told Crutchfield over the phone that their web site clearly showed the HMC UV(0) version in the item picture. They said again they did not have it and to return mine. I checked their site for other Hoya HMC UV filters and found more cases where the text did not say which version it was but the picture 'Very Clearly Showed' the item to be an HMC UV(0). This was true for the size I ordered, 77mm, and it was also true for 82mm, 72mm, 67mm, 62mm, 58mm and 52mm. I didn't check any smaller sizes. This has not been corrected as of 7/15/2011. I don't know which version they would send for these other sizes but I certainly do not believe the HMC UV(C) version is replacing the HMC UV(0) version. I believe the HMC UV(C) version is a cheaper filter - this is my personal opinion. I didn't bother to dig any further. I will just order my filter from another source. However I do know that searching will find quite a few instances of people ordering HMC UV(0) filters and receiving HMC UV(C) filters instead. One might think these are just honest mistakes but I could not find one instance of anyone ordering an HMC UV(C) filter and receiving an HMC UV(0) filter. Go figure. Personally I would not tolerate any substituting of HMC UV(C) filters for HMC UV(0) filters.
Вкратце:
Производитель заявляет, что в HMC UV (0) защита от ультрафиолетового излучения достигается хим.составом стекла, в HMC UV (C) - многослойным покрытием. Многие продаваны кидают покупателей, подсовывая UV (C) вместо более дорогого UV (0).
Взято тут и на других ресурсах тоже попадается.
Судя по старому тесту раньше в HMC тоже применялся тип UV (0) - по качеству на одном уровне с серией Pro, но дешевле, теперь ему на смену пришёл тип UV (C).
Сравнительный график можно найти на сайте хойи:
http://www.hoyafilter.com/hoya/products/generalfilters/uvcslimframe/
Re[Henker]:
Ну вот, только заказал Hoya UV(0) и наткнулся на эту тему, где написано, что он желтит :(
Или это давно было и UV(0) уже не желтит? :D
Re[fox77]:
от: fox77
Вряд ли это имеет значение при съёмке на цифру, где эта желтизна исправится автоматически.
Re[Alexander46]:
от: Alexander46
Желтизна-то исправится, а обрезание фиолета и синего, которого в cmos и так кот наплакал, может привести к проблемам с цветом в этом углу спектра.
Re[alexandrd]:
от: alexandrd
Там эта желтизна если и есть (сам не пробовал), то на уровне погрешности установки ББ. Не будет ничего подрезаться, это ж не цветной фильтр, у которого такая плотность, что полстопа отжирает.
Re[Alexander46]:
от: Alexander46
Надо смотреть его спектральные характеристики, может он из стекла с присадками, которые имеют сильные полосы поглощения не только в УФ, но и в видимом.
Re[alexandrd]:
от: alexandrd
100% нет.
Re[fox77]:
от: fox77
А Вы баланс белого настраивать не умеете? Ну желтит и пусть себе желтит. Это не препятствие ни разу.
