PocketWizard - Опыт Применения и Настройка!
Всего 1080 сообщ. | Показаны 841 - 860
Re[Андрей Скат]:
андрей! в родной утилите (версия 1.35) в первой вкладке "чек апдейт" ( в настройках до этого должна быть включена загрузка бета версий), потом нажимаем обновить прошивку... ))) выбираем бета версию прошивки)))
изменения в кэноновской версии[quot]- When selecting Basic Trigger Mode, the default channel is now 1 instead of 32.
- Improved reliability of getting the first shot when waking a Canon camera from
sleep.
- Changed AC3 operation so that when a zone is switched off, it no longer allows a
remote Speedlite on that zone to trigger at a very low power level.
- Fixed a situation where using an AC3 ZoneController on a MiniTT1 or FlexTT5 offcamera wouldn’t trigger a PowerST4 for the first TEST press.
- Small improvements made in "No Change Trigger Only" mode.
- Fixed a bug where -1.7 on an AC3 ZoneController in Manual mode used a -3.0 setting.
- Corrected an occasional issue when using the +1 manual setting on an AC3
ZoneController caused an incorrect power level to be used at certain HSS shutter
speeds.
- Made camera selection on the Misc Tab alphabetical instead of chronological
Calibration shot no longer triggers any flashes, remote or on-camera. This
conserves battery power and helps indicate the calibration shot. Previously any
flash energy appearing in the calibration shot was purely coincidental and
sometimes caused confusion.
- Default Settings Change: Rear Curtain Sync is now disabled by default. Most users
were not using it and were confused by the operation. Users that understand when
to use Rear Curtain Sync can enable it as needed.
- Improved operation at X-sync immediately after disconnecting a Canon MiniTT1 or
FlexTT5 from a USB cable while running the PocketWizard Utility and not powercycling the radio.
- Corrected a clipping situation with the 7D at 1/320 shutter speed.
- Improved 7D operation with Rear Curtain Sync when using a flash on-camera with a
ControlTL transmitter.
- Improved 5D Mark II operation at 1/250 shutter speed when using a flash on-camera
with a ControlTL transmitter.
- Improved HyperSync Automation performance of the 1D Mark III and 1D Mark IV.
- Fixed an issue where a 580EX II in Master Manual mode wouldn’t send FEC commands
for Zones B and C.
- Corrected logic when using an AC3 ZoneController so that when all Zones are turned
off (A, B, and C), Standard Channel Zone D also turns off just like in the Nikon
radios.
- Reduced the likelihood of clipping or banding in a 5D using rear curtain sync.
- Reduced the likelihood of bottom frame banding or clipping in a 5D at HSS shutter
speeds.
- Fixed rear curtain sync operation when using an AC9 AlienBees Adapter[/quot]
Никон
[quot]Calibration shot no longer triggers any flashes, remote or on-camera. This
for Zones B and C.
radios.
speeds.
remote Speedlight on that zone to trigger at a very low power level.
- Corrected a bug in SpeedCycler Mode where a remote SB-900 or SB-800 would always
fire at full power if at an HSS/Auto FP shutter speed.
- Dramatically reduced the instances of frame clipping at 1/320 and 1/400 when
shooting in Aperture Priority mode with Nikon cameras.
- Corrected over-exposure issues when using an SB-400.
- Fixed a situation that could lead to occasional missed triggers.
- Fixed rear curtain sync operation when using an AC9 AlienBees Adapter.[/quot]
Re[gumko]:
Ага, нашел, спасибо, прошился. Посмотрим.
Re[gumko]:
Потестил новую прошивку, была слабая надежда, что покетовцы исправят проблему запуска камеры. Не оправдалась. Все по- прежнему- запуска камеры нет, пока не уснет экспонометрия камеры.
Re[Андрей Скат]:
снимал на концерте, ставил второй фотик с флексом и шнурком при выключеном горячем башмаке. флекс на камере. на первом фотике мини как обычно. при нажатии спуска на первом, внешние пыхи попадали в экспозицию, второй фотик щелкал после каждого нажатия первого, но без вспышек, позднее срабатывал. да, и еще на втором отключал автофокус на объективе.
Re[Евгений_алекс]:
от:Евгений_алекс
я замарачивался с этой темой... нужно ставить два флекса на обе камеры и мини в руках.. тогда будет нормально работать, при условии что одинаковые модели камер... если нет то нужен мультимакс.
Re[medman]:
Друзья, салют!
А у кого был опыт запуска студийных обычных моноблоков, не генераторного типа, на выдержках короче 1/200?
Вчера имел удовольствие, чувства смешаные...
прибор вот такой:
http://jtlcorp.com/03ll/mobilight600.html
с акумулятором, довольно мобильный и не дорогой, к тому же тыщщаватник.
Итак, на 5D Mark2 повешен mini TT1 на импульснике флекс.
Вначале всё что короче 1/200 - темная полоса внизу кадра, и это правильно,но , достаточно было поставить в утилите для miniTT1 в опции HSS/FP Begins At (HyperSync Ends) значение 1/320th, как новый кадр получился БЕЗ ПОЛОСЫ!
Радости не было предела, но делаю следом ещё один вспых - полоса появляется снова, и все последующие вспыхи с полосой.
Однако, стоит перевести miniTT1 в OFF и тут же назад на C1, как снова, получается снять один полноценный кадр, но все последующие будут с полосой!!
Это конечно прикольно выключать и включать передатчик для съемки каждого кадра, но возможно кто-то знает способ победить этот геморой?
Весь вечер убил, искал зависимости от всех до исключения настроек в утилите, испробовал десятки вариантов... всё тоже самое: первый кадр снимается на абсолютно любой выдержке вплоть до 1/8000, последующий стабильно с полосой либо весь черный.
Re[Lick]:
от:Lick
Друзья, салют!
прибор вот такой:
думаю движком в утилите нужно подстроить задержку, чтобы полоса пропала
Re[Lick]:
от:Lick
Друзья, салют!
прибор вот такой:
я так все время снимаю, так как живу в тропиках....
зависит от длины импульса этого "чуда"...
вот на элинхром квадра кадр 1/5000
Re[Lick]:
от: Lick
но , достаточно было поставить в утилите для miniTT1 в опции HSS/FP Begins At (HyperSync Ends) значение 1/320th, как новый кадр получился БЕЗ ПОЛОСЫ!.
тут ошибка капитальная... нужно ставить тут X-синхронизацию вашей камеры, либо 1.200 либо 1.250...
затем в том же разделе для вашего моноблока поставить значение 10-SLOW...думаю должно работать так импульс 1/800 у него....
попробуйте еще на разных мощностях (длина импульса разная)..
Re[Lick]:
Сразу оговорюсь - на практике пока не испытывал, всё шнурок для подключения моноблоков не удосужусь купить, разбирался с этим в теории. Вот что нашел в сети на эту тему.
Как я понял, во первых, на камере должна стоять выдержка короче длительности импульса вспышки, то есть в данном случае длина импульса 1/800, значит работать нужно на выдержках 1/1000 и короче. Если часть кадра режется, то нужно вручную отрегулировать время синхронизации. Во вкладке HyperSync/HSS ставим галочку в разделе Manual HyperSync For Standard Chennels, ниже активируется ползунок Manual HyperSync Offset, вот с его помощью и нужно добиться точной синхронизации вспышки с затвором. Пока не нашел информацию нужно ли менять выдержку в разделе HSS/FP Begins At (HyperSync Ends), возможно там нужно поставить выдержку соответствующую то ли длительности импульса вспышки, то ли максимальной выдержке, на которой будем работать, соответственно в данном случае или 1/800 или 1/1000.
Тоже очень хотелось бы услышать поподробнее тех, кто на практике уже опробовал работу в этом режиме.
Re[Nero59]:
от:Nero59
первый пункт не правильный точно, у меня у одной вспышки 1/5700 у другой 1/1200.. так первая вообще не работает на любых значениях(короче X-синхронизации) .. а вторая работает на ЛЮБЫХ значениях... хоть 1/400 хоть 1/8000
Manual HyperSyn вообще трогать не нужно с прошлой прошивки... все само определяется...
Re[gumko]:
А с какой вспышкой работает? Я сейчас выбираю, что купить из тех, что можно запитать от аккумулятора, не хотелось бы нарваться на ту, что как первая упомянутая вами откажется работать.
Re[Nero59]:
elinchrom quadra S-head (работает на 1/1200(длинна импульса)) elinchrom quadra A-head (работает на 1/5700(длинна импульса))
Re[gumko]:
от: gumko
elinchrom quadra S-head (работает на 1/1200) elinchrom quadra A-head (работает на 1/5700)
Мда... Не дешево. Я рассматривал варианты или GRIFON MK-400H, или EinsteinE640.
Re[Nero59]:
от: Nero59
отличный комплект за свои деньги.... эйнштейн теже самый деньги, если брать с аккумулятором... в России 25 + 15 батарейка...
только квадра компактнее в разы.. весь комплект весит 3.5 кг... хотя эйнштейн тоже примерно стока же по весу))))
Re[gumko]:
от:gumko
Разница больше чем в два раза - эйнштейн с аккумулятором 40, а Elinchrom Ranger Quadra/S-head - 88 т.р. Получается на эти деньги можно купить два эйнштейна + аккумулятор и еще останется 23 т.р. При этом получаем значительный выигрыш в мощности. В минусе габариты и время зарядки аккумулятора - не так существенно. При условии конечно что эйнштейн будет без проблем работать на коротких выдержках.
Re[Nero59]:
от:Nero59
)))) у вас небольшая ошибочка)))) за 88 тысяч вы получаете один генератор и ДВЕ вспышки... не знаю сколько стоит квадра в РФ с одной головой, в США стоит с одной головой 1400 долларов...
выигрыш в мощности это смешно... 400 ws и 640 ws отличаются на полстопа)))) очень "много" ))))
Re[gumko]:
от:gumko
В РФ с одной головой я пока в продаже не нашел, ссылок много, но всё на Украине. А по разнице в мощности я как раз и имел ввиду комплект батарея + 2 головы. Тогда получается у Elinchrom 268+132 Дж, а у эйнштейна 640+640 Дж, а это уже приличная разница.
Re[Nero59]:
вы сравниваете не сравнимое.. асинхронный генератор с двумя головами с 2 двумя моноблоками))))
закажите на бехе квадру выйдет около 46-48 килорублей... там же бывают бу комплекты по 1100 баксов... еще дешевле)))
по цене сравнимо с покупкой энштейна в РФ...
p.s
русские барыги зажрались)))) 88 тысяч за комплект который в реале стоит 2000 долларов...
Re[medman]:
за 1850 баксов можно вообще купить элинхром ранджер, он тоже на коротких работает... 1100 Ws...
http://www.bhphotovideo.com/c/product/392226-REG/Elinchrom_EL_10280_Ranger_RX_1100_W_S.html
