Всего 59856 сообщ. | Показаны 41941 - 41960
Re[Tigra Girl]:
Еще одна проблема для мануальщика с 1Ds Mark II, кроме отсутствия лайв-вью и маленького экранчика. Оказалось, что эта камера не работает с мануальными линзами без одуванчика. Отказывается делать кадр и пишет ошибка 01 - нет контакта с объективом. В инструкции про это не нашел. Нашел в нете.
Придется недоворачивать переходник.
The lens detection Microswitch.
On some EOS bodies there is a small microswitch in the lensmount which must not be tripped by any attached lens or lens adapter in order for the camera body to work. If an adapted manual focus lens trips this microswitch, the camera body them looks for a valid EF series lens to be attached. If it doesn't see the correct electrical connection the the camera body thinks there is an error condition and will not operate. I've never been able to find an official list of which bodies have this switch and which don't. The early 1D series bodies do, up to the 1D MkII. The 1D MkIII doesn't. I think the D30, D60 and 10D have it too (note that's the D30/D60 not the later 30D/60D). Some, possibly all, EOS film bodies have it. I know the EOS-3 does for example.
If you have one of the bodies with this microswitch and your adapted lens causes the camera to freeze you have to remove a small part of one of the bayonet flanges in order to avoid tripping the switch. Either that or do not lock the adapter completely in the EOS mount. If you don't fully rotate it so that it "clicks" into place it won't trip the switch. Of course the adapter is them not fully locked onto the camera, so you need to be careful not to accidentally allow the lens to part company with the camera!
Re[Tigra Girl]:
Кому качественный китайский фишай 8/3.5 - всего за 3 доллара и с бесплатной доставкой?
ебей
232586557083
Re[Tigra Girl]:
от: Tigra Girl
ебей
232586557083
3 бакса - это цена адаптера под никон... товар то там выбрать нужно - либо стекло, либо адаптер. Стекло в итоге совсем других денег стоит. Есть такая игрушка в обиходе. Это китайский аналог samyang 8mm f/3.5, внешне очень похож на него, но только внешне(это же Китай :D ) Samyang кстати заметно резче будет, но и дороже.
Re[valera_e]:
Да, хорошая уловка продавца.
Re[King_TT]:
от:King_TT
Да, именно о нем речь шла. Хотя с первым марком не менее интересно;) Сейчас 5д марк 3 самая удачная модель для перехода на фф, стоимость упала, запчасти появились в свободной продаже и МЛ прошивка на нее имеется с модулем вай фай и дистанционным управлением. Кстати, кто знает, почему в народе не прижился 5дс? Продают сейчас его очень не дорого б.у., учитывая, что ему год-полтора отроду и стоимость его была около 4к евро...
Не впадайте в массовую эйфорию, морковка 3 не есть бюджет для людей , которые хотят сделать "фоточки", для этих целей вполне подойдёт морковка 2 или же 6D, взял и не заморачиваешься. Для особо прошаренных беззеркалка фуджик, для самых умных и "ограниченных социальными сетями" - айфон или P9 c двойной камерой, вот и вся арифметика
Re[dimuka]:
от:dimuka
ребята - сменил религию - перешел на сони с канона) стекла оставил каноновские ) связал все метабонсом )) https://vk.com/foto85?w=wall16110516_5564%2Fall
первая сьемочка тут 85 1.2 вторая и 24 1.2 первая ) как не странно но фокус на сони работает точнее чем в каноне с дуалпикселем не сравнивал )
Поздравляю, морковку 2 давно уже устарела физически и морально, боковые точки не работают адекватно, аф ерунда, рабочее ISО крайне мало
в любом случае увидите результат по-любому и он будет положительным
Это как пересесть с москвича на ауди
Р.S. с цветами будет на первых парах беда-бедой, глаз как ни крути, привыкает к кеноновской картинке, сделать это в соньке будет сложно и неиррационально как по времени, так и по затраченным силам
Re[Tigra Girl]:
от:Tigra Girl
Хотите пользоваться мотоцыклом для перевозки картофеля. Камера старенькая, в неё нет ничего для работы с мануалом, кроме большого желания хозяина это опровергнуть. Ерундой маетесь
Re[Tigra Girl]:
от:Tigra Girl
Приехал мне 1Ds Mark II.
Приятная вещица. Хотя экранчик, конечно, слабоват. Но он и на 1Ds Mark III слабоват по разрешению.
Вообще я испытываю симпатию к единичкам. Солидные, проф. и удобно лежит в руке. Управление второй единички от третьей отличается сильно.
Круглый диск хуже крутится - неудобно и туговато. На третьей единички - одно удовольствие.
Не понятно было, как заходить в разные пункты меню. Непонятно было, как менять баланс белого и как устанавливать качество и формат кадра. Но самое трудное оказалось - это как просматривать отснятые кадры - кнопки с треугольничком "Play" нет.
Разобрался. Сделал пару пробных кадров с третьей единички и приехавшей второй. Посмотрел на экранчике и расстроился. На второй - изображение мутное, не контрастное. Оказалось всему виной - экранчик.
По картинке примерно одинаково. Старичок (Mark II) чуть натуральней цвет, но надо еще на портрете будет на солнышке посмотреть.
А вот по экспозиции - старичок на 1,25 ступени светосильней матрица. При одинаковых настройках, исо, выдержке и диафрагме - на 1Ds Mark III пришлось на стоп вытягивать, а на 1Ds Mark II на 0,25 стопа понижать. Допускаю, что незаметно чуть солнце выглянуло. Буду тестировать дальше.
Но без лайв-вью это, конечно, не аппарат для мануальщика.
Автофокус попал чуть в разные места, это надо учитывать. Снято на Canon EF 50/1.8 на 1.8.
Тест ерунда, не показательный, особенно интересно было слово "натуральнее"))
Главное правило единичек - никогда не смотреть на экран единичек.
Вам бы это не знать, на экраны перво-второ-третье и в принципе четвёрто единичек вообще никто не смотрит, т к там муть редкостная и нихрена не видно, только растроишь себя. На компе они выглядят хорошо, это "фишка" единичек
Попробовали бы Вы управление на 1d mark II N, там вообще чёрт голову сломит, перестановка параметров только при доубл удержании нужных кнопок, это такая фича, мол что б случайно настройки не сбить :D Вот там конечно поржать есть над чем, а во второй единичке, всё технологично. Да и годков уже ему сколько, мил человек))Только большие энтузиасты покупают 1d, 1ds, 1d mark II (N) и около того, промолчу про первопятак.
Re[mpazu]:
от:mpazu
Само собой что 3 не бюджетное решение. Никакой эйфории нет. Но сейчас бу 3 стоит уже около 1к и за эти деньги в нем есть: 1. "Хороший" автофокус в сравнении с 2м марком, 6д и дело не в точках, а в скорости работы. 2. Съемка видео в формате рав, если есть желание получить киношную картинку. 3. Лучше экран для лив вью и съемки видео. 4. Возможность юзать вай фай блоки, передавая фото на лету. 5. Выше рабочее исо.
Во втором марке всего этого нет. 6д стоит сейчас почти те же деньги бу и она уровнем ниже и качеством сборки. Так о чем вы говорите? А для "ограниченных" подойдет вообще любой добротный смарт ценой 250-300уе. Для селфи качество чуждо.
Re[King_TT]:
от:King_TT
Не около 1к, а 85 000 р +- пару тыс, всё что критично ниже - рабочие лошадки проффотографа со всеми вытекающими либо развод, это так
Все няшки можно найти в 6д легко, а он стОит 45+-к руб, а то что корпус хлипковат , так это пофиг, потценам смотрим сайт начинающийся на А и заканчивающийся на ВИТА
Так поо что это я, агитируя тушки для повседневной жизни и жизни в кайф за хоть и не такие конские , но все же нормальные цены, вы делаете плохую полезную работу, а дело в том, что сримая я на морковку 2 на улице и снимая Вы на морковку 3 при тех же условиях, результвт будет тот же, я уже молчу про сравнения полулюбительскуой 6д и морковки 3, там простому обывателю не за что переплачивать, а проф будет рассматривать её как инструмент для работы
Видео мне в рав нужно? нет. Вайфай на лету? так постобработка после съмки идет😁так и что передавать РАВ? ☺
Re[Tigra Girl]:
Тест фотографий (кроп 100%) с трех мобильников против 1Dx Mark II.
Теперь понятно, почему на полнокадровых аппаратах и светосильных стеклах мануальщик не использует автофокус?
Re[Tigra Girl]:
от:Tigra Girl
И почему мануальщик на полнокадровых аппаратах и светосильных стёклах не использует автофокус?
Ну и вопросики у Вас))))
ответ : а) а потому что его на мануальных светосильных стёклах нет
б) потому что он прожённых мануальщик ;)
Re[Tigra Girl]:
Светосильные стекла бывают разные. Иногда попадаются и с автофокусом.
Re[Tigra Girl]:
Всё продаю...
Беру Хувэй
Re[Brun]:
от: Brun
Всё продаю...
Беру Хувэй
Года 4 назад, снимал в студии, человек, помощник, фотограф и просто друг сделал несколько снимков , качество отличное ( была у него пятёрка айфон) при естественном освещении отыгрывает на все сто, фоточки были не отличимы от моих на экранчике фотоаппарата, до той поры пока было это не перенесено на компьютер и просмотрено попиксельно, здесь уже всё стало ясно
Re[mpazu]:
В Украине ситуация такова, что 3 марк сейчас стоит не 1500, как у вас, а 1200-1300 в идеале, с небольшим пробегом. С большим уже около 1000, недавно видел за 800 с пробегом за 300. 6д у нас сейчас тоже около 1000, 5д2 600-700 и они все с большим пробегом. У вас действительно нет смысла брать 5д3, цена в 45 т.р. за 6д против 85 решает. У нас же разница минимальна на данный момент. Так что извините, думал ситуация по СНГ схожа, а разница действительно огромна. С уважением, Сергей
Re[Tigra Girl]:
от: Tigra Girl
мануальщики обычно про это не знают или этим не пользуются, так уж заведено
Re[Brun]:
от: Brun
Всё продаю...
Беру Хувэй
если интересно, то Тигра взят отсюда
https://tech.onliner.by/2018/01/12/smartphones-vs-dslr
хуавей действительно там еб..т всех :) как бы))
особенно заинтересовало Специальные способности Huawei включают в себя выглаживание текстуры кожи и увеличение глаз.
но это же всё вкусно смотрится на темках для тех кому нажать кнопочку да фотка вылетит, мы же фотоонанисты,, народ мускулистый, не ищем простых путей, нам бы посветлеее, потяжелее да с wow как у коня
Re[mpazu]:
Там господа точно решили, что беззеркалки и зеркалки стоимостью $500—1000 для любителей станут историей...
х.з. выводы очень сомнительны.
Фото и видеотехника никуда не денется.
Смартфон будет смартфоном...
с возможностью делать более менее приемлемые фото.
Дешёвые мыльницы можно заменить смартфоном, не более.
Будет очень странно если корпорации производящие фототехнику отдадут большую часть своего пирога и станут прикармливаться у производителей смартфонов...
Бред.
Re[Brun]:
от: Brun
Бред.
А что Вас удивляет? Такое уже есть и довольно давно
Huawei ( тот же Mate 10 Pro) - Leica
Hokia ( тот же экспресс мьюзик 5800, был таков у меня ) - Carl Zeiss
Может ещё что вспомнить, я уже молчу про корпорации, которые сами клепают зеркалки-компакты и уже не одну собаку на этом съели и свои технологии внедряют в свои телефоны Самсунги, панасоники, сони и т д, а вспомним тех, у кого брикет бабла ляшку джинсев жмёт , поэтому берут всё у всех и одно из самых лучших ( айфон )
