Всего 59854 сообщ. | Показаны 44881 - 44900
Re[Tigra Girl]:
от: Tigra Girl
Спасибо. Попробую. Все равно 2 недели скучать, пока мастер не вернется.
Вот чел решил проблему такую же
deanb2010 wrote:
Eureka! Solved the problem. After the last poster, I started
thinking about all the steps I had gone through. The only thing I
had not changed was the battery. So I put in a freshly charged
battery (Official Canon Battery, also - The previous battery I did
have in the camera was not "official" but it did show a full charge.)
So the summary is: Either the camera is smart enough to know that the
battery was not a Canon battery - not likely, or the 3rd pty battery
had just enough of an undervolt for the camera to pick it up and not
perform the update. In any event, thanks to all who replied to my
need and triggered additional thoughts. I have been reading this
forum & dp-review as an observer for 4+ years. I have greatly
benefited from everyones input over that time. Thanks.
The non-canon battery may not be operating up to the proper voltage.
Canon warns that if power fail during the firmware update, the camera will be in an inoperable condition; which means you'd have to return it to Canon Service.
If the camera's operating system sensed a not fully charged battery, or a battery with low-voltage condition, then it will error out of the update as a safety precaution.
My advice is stick with genuine Canon components, such as LiON batteries, Flash, etc.
т.е. он тупо поставил родную батарею
еще пишут https://www.canonrumors.com/forum/index.php?topic=7622.0
Re[D163RUS]:
Спасибо. Батарея фирменная.
Нашел 3 прошивки. В том числе одну более старую. На всех флешках, всех аккумуляторах - 9% и зависает.
Тоже думал попробовать энергии побольше дать, но бат. блока к третьему пятаку у меня нет.
Видимо что-то там в утопленнике не хватает по питанию при прошивке.
Как в компе - вольтажа не хватает - завис при выполнении программы.
Думаю, что батблок - самая правильная мысль!
Завтра найду, кто такой продает, попрошу выручить.
Еще вариант - отдать мастеру, чтобы почистил внутри аппарат. Т.к. на всех аккумуляторах сейчас показывает моргающую батарею.
Re[Tigra Girl]:
от: Tigra Girl
Не перешарпишь - враги начнут кричать: "мыло твои мануальники!"
Как много в этом признании!
Во-первых, то, что в ваших "снимках" больше Фотошопа, чем "вава" проекционных стекол.
Во-вторых, так могут "кричать" только те, кто хоть однажды работал с RAWами от ваших проекционников.
Там хорошо видно, что они не контрастные, блеклые и, как вы, доцент, точно их характеризуете, "мыльные".
Именно Фотошоп делает то, что мы видим в результате.
Разумеется, если закрыть глаза на картинку в целом, - там вообще не о чем говорить!
Что и требовалось доказать. Хорошо, что вы, доцент, сделали это сами.
Re[Tigra Girl]:
от: Tigra Girl
Это как стекло протереть, по колёсам попинать :)
Есть такой глюк - старые не программируемые переходники M42-EOS не совместимы с 5D Mark III. С таким переходником при включении фотоаппарата сразу идёт запрос на обновление прошивки. Другие новые кэноны просто выдают ошибку объектива.
Re[Tigra Girl]:
от: Tigra Girl
Значит дело в том что фот не видит по каким-то причинам уровень заряда батареи, начиная от банальных контактов в тушке (те что батареи касаются) кончая "железными" проблемами. Короче ждать мастера из отпуска.
Re[Alchan]:
от: Alchan
От телосложения моделек зависит, если худенькая 85-100мм в самый раз.
Она тоже хочет видеть себя еще более худой или такой же - но не толще :)
Re[Tigra Girl]:
минолта 55 1.7 / gfx
Re[Арсений Шапуров]:
Даже на не особо светосильном полтиннике хорошо.
Приходите c Фуджи на Митакон 85/1.2.
Re[Tigra Girl]:
Проверил 5d Mark III с бат. блоком.
Та же картина. Вставляю 2 свежих аккума, вставляю батблок - моргает слабый аккумулятор. Идет обновления и снова на 9% виснет.
В общем-то это можно было предвидеть. Вольтаж с батблоком не повысился, только емкость выросла и время работы.
Дожидаюсь мастера с отпуска, несу аппарат на чистку.
Re[Tigra Girl]:
Хотел бы его испытать. Но всё равно не понимаю как, если он под никон, и есть переходник под canon. Там линза в переходнике? Или это наоборот, под никон нужна линза?
Ничто ни под что не надо. Объектив с байонетом Никон можно поставить и на Никон и на Кэнон. Это Кеноновский объектив на тушку Никон не поставить.
Re[Tigra Girl]:
35КП 140 1.8 / gfx
Re[Tigra Girl]:
Митакон 85/1.2
Re[Tigra Girl]:
Новости.
1. Приехал мне Visionar 141/1.9. Давно на него не снимал. В погоне за Королем 200/1.9 продал его на заре находок Визионаров. А теперь вот снова приобрел. Было бы интересно его сравнить с Митаконом 85/1.2. Все-таки 141/1.9 - самый резкий из всех Визионаров. По wow-фактору - аналог фирменным 135/2.0 или мануальным 135/1.8.
Поставил Визионар в переходник на аппарат - только близкое макро. Ладно, отпилил по самую заднюю линзу. Вставляю - и о чудо: тоже только близкое макро!
Фантастика. Что это значит? Это значит, что в оптическую схему вмешивался бывший владелец. В лучшем случае - он просто при сборке поставил линзу не так. В худшем - вообще не будет одной или нескольких линз внутри.
Раскрутил на две части. Так и есть. Не хватает внутренней линзы. Скорей всего - линзы треснула, или была разбита, или пошла в другой аналогичный объектив.
И этот был продан. Кому он теперь нужен!
Вот как бывает.
2. Мой фото-мастер вернулся из отпуска. Отнес ему сегодня Canon 5D Mark III, который зависал при перепрошивке.
Re[Tigra Girl]:
от: Tigra Girl
Митакон 85/1.2
Митакон очень хорош!!! Чем больше смотрю, тем больше нравится. :D
от:Арсений Шапуров
35КП 140 1.8 / gfx
Арсений, на GFX этот объектив просто супер! 3D так и прет... так и прет ... очень нравится. По объему ничуть не хуже canon 200/2.0L на FF.
Re[Tigra Girl]:
от:Tigra Girl
Фотобайки от Тигры.
Приехал мне на днях с ебея Canon 5D Mark III. Не рабочий. Хотя состояние прекрасное.
На этот аппарат я никогда не снимал. Вот купил недорого для тестов. Авось удастся починить. Но не удалось.
Как приехал, оказалось - утопленник, скорей всего. И, конечно, никаких признаков жизни. Даже аккумулятора нет индикации при включении, что иногда бывает при не самых тяжелых случаях.
Ладно, что делать. Мастеру нести не хочется. Это будет стандартная история: 50 долларов за полную разборку-сборку и диагностику через две недели, с заключением - "Восстановлению не подлежит! На будущее: такие аппараты больше не приносите". :)
Придется выставить на ебей, как нерабочий. Хоть часть вернуть - и то хорошо.
И вот уже сфотографировал его, составил подробное описание полного комплекта с флешкой, коробкой и прочим. Вставляю флешку, аккумулятор, уже хотел класть в коробку, а он тут возьми да и включись!
И все работает! Фантастика.
Ну я решил проверить по полной программе. Да, снимает и видео, и фото, и записывает и все ок.
Ну и решил - гулять, так гулять, я еще на него новую прошивку поставлю - вообще цацка будет под ключ.
Отформатировал sd карту в аппарате, скачал с оф. сайта последнюю прошивку на флешку. Запустил обновление. Пошло!
Но до 9% дошло и висит.
И сколько аккумуляторов не вставлял и других флешек с прошивками не менял - до 9% доходит и висит.
Естественно, что камера стала совершенно нерабочей. При включении требует обновления. А обновление зависает.
Вот как бывает.
Может контакты в камере почистить.
Может как-то через кабель с компа можно перепрошить...
больше похоже на то, что стояла ранее прошивка от magic lantern
поэтому вариант восстановления, это скачать ее. залить на флэшку и попробовать установить.
разборка тут не поможет
Re[RulexJB]:
Там стояла обычная старая. 1.2.1
Но если ML - это всего одна лишняя строчка в стандартной прошивке, то я вполне мог не заметить.
В любом случае - уже отнес мастеру.
Как ML на третьем пятаке выглядит? Включаешь меню и сразу ясно, что не стандартная прошивка, или сначала стандартная, а потом в ней надо куда-то входить?
Re[Tigra Girl]:
А у меня уже много лет гелиос 40. Сначала снимал им на 450д, потом 550д, после перехода на ФФ какое-то время был заброшен из-за 70-200 2,8 (тамрон), теперь вот потихоньку опять выгуливаю.
https://drive.google.com/file/d/1SlRO9HVI4eAipL3gwd94-LLXwJIbD0hM/view?usp=sharing
https://drive.google.com/file/d/1LZREZZGqMrjvXLoIE7lsHLeqYN0uXRdz/view?usp=sharing
Re[unreset1]:
Спасибо. Потемней бы сделать - и будет ок.
Аппарат, диафрагма?
