Цитата:от: ИнженеР
Да там оптическая схема похоже не переработана, просто стаб заменили и все. Так что картинка будет прежней, только выдержка для получения резкого кадра увеличится.
ну так это то что хочется- резко, без смаза...на эфр 600мм.
учитывая заявления - есть надежда. что АФ будет быстрее.
LUMIX G VARIO 100-300mm / F4.0-5.6 II / POWER O.I.S.
Micro Four Thirds 100300mm Telephoto Zoom Lens / 200600mm (35mm camera equiv.)
Intense action
Drawing subjects in from a distance, this 300mm (35mm camera equivalent: 600mm) ultratelephoto zoom lens is ideal for capturing intense action sports, or even animals you couldn’t normally get close to. Unlike conventional lenses, LUMIX G lenses like this one are small, lightweight and fit perfectly in the palm of your hand. Now you can take professionallooking shots of an athlete – and even capture individual drops of water falling through the air.
POWER O.I.S. – ultra-sharp photos
Capture scenes carefree or at the spur of the moment. The optical image stabilisation (O.I.S.) technology built directly into the lens ensures your photos will look great, with sharp blurfree contours across the entire picture. Taking highly popular MEGA O.I.S. further, this advanced technology immediately compensates even large camera shake and vibrations that may occur in photography. So you can capture truetolife scenes without the need for a tripod. In the end, you’ll enjoy wonderfully crisp images.
Video Support – perfect video-recording
With video support any user has everything they need for recording with their LUMIX camera. Not only does it perform smooth aperture changes so there are no sudden jumps in exposure, it also boasts a silent design for enhanced capture of the scene’s audio. What’s more, the stunning AF performance of this lens records excellent 4K video, where precise focusing is essential.
Splash/Dustproof – more creative options
Brave the elements in nearly any kind of weather or shooting location. This lens features a splash/dustproof construction* that is tough enough to withstand even heavy field use. It protects the lens system inside from sand, rain and more, making it perfect for shooting under harsh conditions. Now there is nothing holding you back from capturing the creative nature or landscape shots you want.
*The lens supports this feature in conjunction with splash/dustproof LUMIX cameras.
17 elements in 12 groups:
– 1 ExtraLow Dispersion lenses
ExtraLow Dispersion (ED) lenses correct chromatic aberration rendering sharp, highcontrast images with clear colors from corner to corner.
Filtersize: 67mm
POWER I.O.S. Optical Image Stabilizer
Length: Approx. 126mm
Weight: Approx. 520g
