В процессе выбора тушки среди перечисленных в топике обнаружил в форумах такую проблему, причем на самых ходовых выдержках. Неприятно. Вот достаточно взвешенный коммент с тестом с дпревью.
I came across one unpleasant thing regarding D5300, that would be good to highlight. In certain shutter speeds the photos are blurry. It is not yet clear whether this applies only to certain pieces or if it is an overall problem of model D5300. We had tested two pieces (D5300) and both of them were suffering by this problem. Also I have found several examples on the Internet, that were clearly showing the same thing. So what did I find out?
When shutter speed is set to 1/200 s, we can observe a significant "ghosting effect" (doubling of an image), which is likely a problem of a shutter release. When longer shutter speed is used the problem appears less significant. So, when we used 1/125 s the "ghost effect" is not visible, but it switches into a blurry picture thanks to the longer speed. When the shutter speed value is set to 1/100 images look slightly better, but blur is still visible even with 1/50 s (it can be easily considered as a result of wrong focusing or optical problem of a lens). BUT, when we used shutter speed 1/30 s and longer, this problem disappears and the image is sharp.
It is strange, because I can't imagine how could a person not be able to hand-held the shutter speed 1/200 s. It is even stranger, because same problem occurred when shooting on the tripod.
Shutter speed 1/250 s produces nice sharp images. Shutter speed 1/200 s looks acceptable on the first look, but when you look on the vertical lines you can notice they are significantly less sharp.
Last sample shows same issue. Shutter speed 1/320 and 1/250 s are sharp and without any problem. Speed 1/200 shows ghosting effect again. And when 1/160 s and lower speed are used "ghosting" gradually switches into a blur.
This sharpness issue occurred on both D5300 bodies while using 4 different lenses that we had available for the test. The extent of the issue may vary from piece to piece. On a second body of D5300 that was tested, this issue was milder, but it occurred in same shutter speeds as on the first tested body.
It is a question how the problem with image blur described in the chapter about exposure is frequent. Our both tested pieces suffered same problem. Therefore I strongly recommend to test your piece before the purchase, especially try shutter speed from 1/250 and 1/200 .
Неприятно. Причем, это мягко сказано. Кто-нибудь что добавит может.
Shutter shock - Микросмаз от затвора - d3300/d5300/d5500 - реальность проблемы
Всего 34 сообщ.
Re[S.A.Y.]:
Это не проблема конкретных указанных моделей и не поломка, а особенность работы с камерами, где многоМП матрицы.
Да и смазы могут в одних условиях быть, а в других нет. Много факторов могут влиять.
Re[S.A.Y.]:
от: S.A.Y.
На Д7100 - камере с той же матрицей - ничего подобного не вижу. Вместо копи-пасты непереведённого текста лучше бы дали ссылку на фото, на которые опирается автор отзыва. Т.к. причин "двойных контуров" больше чем "якобы микросмаз", особенно с утверждением, что он виден и при съёмке со штатива.
В общем, эта проблема обсасывалась ещё при выходе Д800, но та имела более чем в раза тяжелее зеркало и более быстрый затвор. Так что для любительского кропа эта проблема либо высосана из пальца, либо у тестера руки кривые, или видит то, что хочет видеть.
Re[S.A.Y.]:
Слишком облегчили камеры. У некоторых БЗК тоже есть.
Re[Sergei-62r]:
от:Sergei-62r
В общем, эта проблема обсасывалась ещё при выходе Д800, но та имела более чем в раза тяжелее зеркало и более быстрый затвор. Так что для любительского кропа эта проблема либо высосана из пальца, либо у тестера руки кривые, или видит то, что хочет видеть.Подробнее
Часто в дискуссиях можно слышать про одинаковые матрицы чуть не во всех Никонах, где появилось 24мп. Однако, даже при поверхностном рассмотрении оказывается, что не одинаковы. А если посмотреть еще ближе , то это становится вовсе не очевидным. Вы можете предъявить снятые с 7100 и других, упомянутых в топике камер матрицы, чтобы доказать свое утверждение их одинаковости? Иначе, это необоснованное утверждение.
Re[Mike_P]:
от: Mike_P
Далеко не очевидно.Например, d5300 ощутимо тяжелее d5500. При этом, проблема с d5300 не стоит менее явно. Скорее, наоборот, судя по обсуждениям.
Re[S.A.Y.]:
от: S.A.Y.
Что значит "одинаковые матрицы чуть не во всех никонах" ? :D
В некоторых моделях матрицы да одинаковые. Удивляет?
Re[Tech_nic]:
от: Tech_nic
Вы через строку читаете? Мне нужны доказательства наличия одинакового модуля матрицы и обвязки в камерах, которые в топике и упомянутой 7100. Не просто Сони или Тошиба, условно, а конкретные модули. В смартфонах даже одной модели с течением времени начинают появляться разные фотомодули. При этом, производителю не интересно об этом информировать, им продавать важно.
Re[S.A.Y.]:
В D7100 и D5100 одинаковый сенсор, обвязка может отличается, но на результат не заметно, чтобы это влияло. Доказательства сами знаете где можно получить. Смысл темы?
Re[S.A.Y.]:
от:S.A.Y.Вы разве не в курсе, что в сервис тулз по построению карты пикселей для этих камер один и тот же файл ? А по поводу микросмаза, таки да, блок привода у 7100 тяжелее на 63 грамма. Это относительно подвижного элемента много.
Часто в дискуссиях можно слышать про одинаковые матрицы чуть не во всех Никонах, где появилось 24мп. Однако, даже при поверхностном рассмотрении оказывается, что не одинаковы. А если посмотреть еще ближе , то это становится вовсе не очевидным. Вы можете предъявить снятые с 7100 и других, упомянутых в топике камер матрицы, чтобы доказать свое утверждение их одинаковости? Иначе, это необоснованное утверждение.Подробнее
Re[Tech_nic]:
от: Tech_nic
Ну я топике 5300/5500 упоминал, а не 5100.
Re[Tech_nic]:
от: Tech_nic
В 5100 16мп, как и в 7000 от Сони. :D В 7100, 7200 и 5200 матрица Тошиба уже на 24 мп, а в 7500- Соня опять с матрицей от Д500
В D5300, D5500, D5600, D3300, D3400- другой сенсор от Сони на 24 мп тоже
Re[Pashkov]:
Я опечатался, D5200, а не D5100. В D5100 сенсор как в D7000.
Re[Tech_nic]:
от: Tech_nic
Re[Pashkov]:
от:Pashkov
В D5300, D5500, D5600, D3300, D3400- другой сенсор от Сони на 24 мп тожеПодробнее
более подробно здесь: Vasili-photo.com Матрицы фотоаппаратов Nikon.
2ТС: Здесь же приведён актуальный на 2017 год модельный ряд Никона...
Re[Sergei-62r]:
от:Sergei-62r
2ТС: Здесь же приведён актуальный на 2017 год модельный ряд Никона...Подробнее
Там сразу по первой ссылке- в 850 матрица не Сони совсем. Хотя остальное верно
Re[Pashkov]:
Re[Pashkov]:
Увы, но другого сайта, где была бы собрана и структурирована в удобоваримом виде эта инфа, я не находил... И уж тем-более не проверял данные по другим источникам. Так что ошибки не исключены, что не отменяет ценность данного источника информации.
Пока источник матрицы Д850 является коммерческой тайной Никона, который утверждает, что самостоятельно разработал эту матрицу. В качестве разработчика также называют какую-то израильскую лабораторию, а непосредственным производителем всё-таки Сони... Так что фиг его знает, да в общем-то и неважно это...
Re[S.A.Y.]:
https://www.dpreview.com/galleries/7318759830/albums/shutter-shock-in-nikon-d5300-5500-7200
Re[S.A.Y.]:
от: S.A.Y.
Целых 60г - действительно, весьма ощутимо
