Появились объективные характеристики объективов Никон
Всего 26 сообщ. | Показаны 21 - 26
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Появились объективные характеристики объективов Никон
от: ВикторВ
А может у кого есть ссылка, как правильно читать графики МТФ?
www.photodo.com там Products
текст взят из окна объектива.
Understanding the MTF graphs, numbers and grades
Understanding the MTF graphs, numbers and grades We have been testing lenses with Hasselblads Ealing MTF equipment since 1991. All MTF reports are made with the same equipment and by the same operator (Per Nordlund at Victor Hasselblad AB).
So far we have tested lenses only at infinity.
We measure MTF at 10, 20 and 40 lp/mm, where 10 lp/mm (line pairs/ mm) means 10 black lines with 10 white lines in between, for each millimeter.
The lens with the highest MTF in our tests (so far) is the Canon EF 200/1,8L USM.
Photodo test result: 4,8
Higher is better. 4,8 is the grade on a scale going from 0 to 5. The grade is based on the average weighted MTF for the lens. No other variables, such as distortion, flare, or ghosting are taken into account. We chose 0,88 for a grade of 4,8 to make sure that we will never hit the "roof" (>5). See more at Average Weighted MTF: 0,88 below.
Effective focal length: 195 mm
Often the real focal length differs from the one given by the manufacturer. 195 mm is the length we measured with the Ealing.
Weighted MTF for 200 mm: f1,8 0,82, f2,8 0,89, f4 0,90, f8 0,87
Higher is better. MTF is measured 0, 3, 6, 9, 12, 15, 18, and 21 mm from the image center (on axis), at 10, 20 and 40 lp/mm, in two different directions (sagital and tangential). That is all together 48 measurements at each focal length and each f-stop. Rather than listing all these numbers we calculate a weighted average number for each f-stop of all lenses and each focal length of zoom lenses. The center of the image is more important than the edges, and 10 lp/mm is more important than 20 and 40.
The maximum MTF is 1,0, but due to optical imperfections and diffraction, a perfect score is impossible to reach at these line frequencies.
The MTF at large apertures (f1,0 - f2,8) is limited by optical imperfections (with major differences between lenses). At small apertures (f11 - f32+) MTF is limited by diffraction (with minor differences between lenses). For example the Canon EF 200/1,8L USM has its peak at f4.
We don't measure beyond f8 because lens performance at small apertures is limited more by diffraction than by optical quality. At very small apertures all lenses are about equally bad.
Higher is better. When we report an average MTF number for all f-stops at one focal length we use f4 (or wide open, if f4 is not attainable) and f8. Most lenses have their highest MTF at f8. High-speed lenses almost always have a very low MTF at full aperture. That is why we decided to use f4 and f8 as standard apertures. Since MTF for f8 is slightly more important than for f4, we assign weights of 60% for f8 and 40% for f4. In the case of zoom lenses, we report the weighted average MTF at each measured focal length.
Weighted MTF 10 lp/mm: 0,94
Higher is better. 10 lp/mm is important for evaluating the overall contrast and resolution when making small enlargments (10 x 15 cm or 4 x 6 inches).
Weighted MTF 40 lp/mm: 0,71
Higher is better. 40 lp/mm is important only when you intend to make large prints of high quality. If you are going to use the lens with fine grain film, the camera on a tripod, and make big enlargements, then it is important to choose a lens with a high MTF at 40 lp/mm.
Max distortion: -1,1 %
Closer to zero is better. Distortion is when a straight line near the edge appears curved in the image. If the line curves out in the middle, it is due to negative (barrel) distortion of the lens
Positive or pincushion distortion is when straight lines curve inwards in the middle.
The graphs
The graphs show MTF in percent for the three line frequences of 10 lp/mm, 20 lp/mm and 40 lp/mm, from the center of the image (shown at left) all the way to the corner (shown at right).
The top two lines represent 10 lp/mm, the middle two lines 20 lp/mm and the bottom two lines 40 lp/mm.
The solid lines represent sagital MTF (lp/mm aligned like the spokes in a wheel). The broken lines represent tangential MTF (lp/mm arranged like the rim of a wheel, at right angles to sagital lines).
On the scale at the bottom 0 represents the center of the image (on axis), 3 represents 3 mm from the center, and 21 represents 21 mm from the center, or the very corner of a 35 mm-film image.
Separate graphs show results at f8 and full aperture. For zoom lenses, there are graphs for each measured focal length.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Появились объективные характеристики объективов Никон
от: Mike_P
от:ВикторВ
The graphs
Спасибо. Только я к сожалению, английский, не разумею.....
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Появились объективные характеристики объективов Никон
Пробовал перводить переводчиком - лучше бы не пробовал...
от: ВикторВ
Ну так есть google и др.
от нашел на http://mindmix.ru/photo/81-951-ocenka-na-photodo-read.shtml
Рискну написать попроще, хотя может быть немного неправильно.
ЧКХ - частотно-контрасная характеристика и MTF - modulation transfer function, характеризует способность обьектива передавать микроконтраст. Например, если взять заборчик из тонких чередующихся черных и белых линий (на графиках обычно для 10, 20, 40 линий на мм), то у него контраст условно равен 100 % и его структура условно может быть представлена графиком в виде прямоугольных импульсов. При ЧКХ=100% изображение заборчика будет иметь тот же вид, что и исходный объект. Реальная картина даваемая оптикой отличается от идеальной, прямоугольники расплываются и белое становится серым и черное тоже ("прямоугольные импульсы" превращаются в подобие синусоиды, имеющей постоянную составляющую) В пределе все замыливается и вы имеете серый тон.
Подробнее смотрите на www.amd-photo.ru в тестах оптики есть пояснение всех этих графиков.
По своему опыту скажу, что лучше брать оптику с оценкой не ниже 2.8-3, хотя, конечно, надо смотреть поведение кривых МТФ, а еще лучше - провести тестовую съемку.
Мне кажется что MTF объективны, т.к. за ложную рекламу у них "Турма сидеть".
Правда есть "но", насколько мне известно аферта Nikon и Canon запрещает без их согласия публиковать MTF для их объективов.
Однако если серьезный эксперт получит другой MTF от суда и страшных последствий не уклонится.
MTF также проверяет и ХА.
Последние штрихи на многих стеклах перестают читаться именно из-за хроматики. Методика MTF требует четкого чтения штриха.
Потом соглашусь что MTF неудачным стелом стал Nikkor 20mm. Достаточно много плохих отзывов на этот фикс, даже знаю тех кто перешел на Canon разочаровавшись в оптике Nikon. Однако это просто плохой фикс проигрывающий в центре даже Nikkor 18-70.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Появились объективные характеристики объективов Никон
от:fmod
Одна бабка говорила, вторая повторила, и так формируется объективное мнение об объективах :)
Маленький совет (им можно не пользоваться или можно меня послать, но тем не менее): не пишите о том, о чем не знаете и чего в руках не держали ...
