Портрет - на СФ / БФ (плёнка)
Всего 6879 сообщ. | Показаны 6341 - 6360
Re[Алексей-У]:
от: Алексей-У
DD-X? :)
DD-X
Dilute it at 1:9 and increase your 1:4 time in 60% for a start, see if you like, need more?Increase further.
Regarding sharpness, well, accutance might be a better term, but yes it's a fact, higher the dilution, higher the accutance.
So, the previous friend stated he got more grain at 1:4 dilution than 1:9, well, I don't shoot that much 35mm nowadays, but if my memory isn't failing, wasn 't precisely the contrary? Higher dilution, more grain
I have used DDX at 1:9 AND 1:11( for the newer TMX emulsion ) for a long while now. I ran film tests utilizing TMX ( as noted, new and old emulsions ), TMY, HP5, and Delta 100 using the BTZS sytem, my Jobo expert tanks for 4x5 film and 8x10 film, 75F ( in Florida ). I ran tests for conventional silver printing and contact printing, and for doing contact prints for Pt. and Azo. Yes, the tests were involved, but worth it. I can tell you without personal reservations that using DDX at 1:9 produces very sharp negatives that print without any problems at all using Grade Two filters ( or equivalent ) on VC paper, and on graded paper. Indeed, except for the expected higher contrast of negatives developed in Pyro, I see little if any difference with reference to accutance in the negatives developed in DDX vs. those developed in Rollo Pyro using conventional contact prints of 8x10 negatives ( get ready to duck!! ). I believe that such large contact prints are a very good "eye-ball test" to use for the comparison of DDX with RolloPyro as far as negative and print quality are concerned. Caveat: I have not yet done contact printing with the Pyro negatives using Azo/amidol or PT. so as to be able to compare DDx developed negatives with Pyro developed negatives using those "alternate process" techniques.
https://www.photrio.com/forum/threads/question-for-dd-x-users-1-9.45317/#:~:text=On%20Unblinkingeye%20the%20time%20at,more%20than%20a%20100%25%20dilution.
Ilfotec DD-X works great at 1+9 (i.e., 1:10 dilution). At this dilution, it makes DD-X a contender with other developers that otherwise cost less.
Not only that, but it also gives nice tonality and relatively fine grain. I like DD-X 1+9 almost as much as HC-110 Dilution B.
http://120studio.com/film-dev/ilfotec-ddx.htm
Re[noir.]:
czj sonnar 180/2.8, hp5+
Re[Петр]:
Добрый день, Пётр!
Всегда с удовольствием смотрел твои портреты, например, на 314-й странице этой темы. Но в этом году или ты изменил технику съемки, или ещё по каким причинам, нынешние снимки мне не нравятся! Какие-то рыхлые, нерезкие, как будь-то самой захудалой Сменой снято, с поцарапанным объективом!
ИМХО, конечно, но...!
Re[Корр]:
Сорри что вмешиваюсь, которые нравились были после постобработки, наверное.
Re[Аэротар]:
Подождем, что ответит Петр!
Re[noir.]:
от:Корр
Добрый день, Пётр!
Больше года назад я перешел на монитор 27" 2560x1440 (раньше был 22" 1680*1050) и редактор (был Photoshop CS2, стал Affinity Photo). На большом мониторе очень долго пытался подобрать уровень шарпинга, чтобы не корежило картинку, но размер 850-850 на 27" - это какая-то мелочь, толком не поймешь. Наверно, не ту позицию при шарпинге выбрал при очередном изменении. Или речь не про резкость, а про контраст и полутона?
В любом случае, спасибо за критику и желание помочь. Не знаю, как это побороть. Если вы не против, можно списаться или созвониться, и вы поможете мне найти золотую середину.
А может это vk.ru корежит картинки.
После того, как Flickr всех прокинул с бесплатным хостингом, я из VK картинки размещаю.
А может, стекло в сканере грязнее стало :)
Я могу прислать по почте картинку в виде файла, желающие могут открыть и сравнить с тем, что в теме, и узнаем. Я при таком разрешении монитора сильной разницы не замечу, наверно.
Так лучше (по быстрому обработал, шарпингу чуть больше добавил)?
Re[Аэротар]:
от: Аэротар
Я стараюсь постобработки делать минимально. Максимальная обработка: сделать 3 слоя, чтобы с одного можно было посредством стирания вытянуть тени, с другого слоя света. А так обычно уровни туда-сюда, ресайз и шарпинг.
Re[Петр]:
На переделанном снимке много лучше всё получилось, только контраст, на мой взгляд, маловат. А по пост обработке я помощник никакой - с компом на "Вы".
Re[Корр]:
от: Корр
Ок, понял. На моем мониторе контраст на грани. Возможно, наши дисплеи по-разному отображают.
Вывод понял: просто шарпить чуть больше, чем обычно, и контраст побольше.
Re[Петр]:
Монитор у меня простенький, но старые-то снимки на нём очень хорошо смотрелись! Ну и не калиброван он, естественно, так что удивляться нечему!
 Lena by Irshat K, on Flickr
Fuji Velvia 50 | Hasselblad 503 CXi | Sonnar 150f4
Re[Irshat]:
от:Irshat
Re[Петр]:
от: Петр
После шарпинга смотрится лучше, да. Но ещё сильнее шарпить, пожалуй, уже не стоит.
Контраст, на мой взгляд, оптимальный.
Я бы вот так всё и оставил в плане обработки под WEB.
Для чистоты эксперимента смотрел на четырёх разных мониторах, включая Retina и такой же, как у тебя. :)
Re[Санин Юрий]:
от: Санин Юрий
Празднование Равноденствия (22.09.2020). Языческие обряды. Полесье.
Rolleiflex 6008.
Kodak TX400
HC 1+31
фотки хорошие, но происходящее- атас
Re[Irshat]:
от:Irshat
Шикардос
Re***:
от: AndreyVA
от: А.Р.
Шикардос
Re[noir.]:
Ксюша и Тасма Тип 42л
Re[noir.]:
Ломо O2 600mm/10
8x10, Delta 100
Carl Zeiss Jena Epiotar 420/3.5
8x10, Delta 100
Re[Dorff]:
сканируетете в артоффоте ?
