Доброго вечера. Прислали фото с аппарата , который собираюсь брать.Подскажите. Какой параметр в Exif для кенон 5Д говорит об типе автофокуса для данного кадра ?( ручной, автоматический).
Вот exif
---- Îñíîâíîé ðàçäåë ----
Make: Canon
Model: Canon EOS 5D
Orientation: Normal
XResolution: 72,00
YResolution: 72,00
Resolution Unit: Inch
Date Time: 2009:06:28 19:21:05
YCb Cr Positioning: Co-sited
Exif Offset: 196
Exposure Time: 1/250 sec
FNumber: F3,2
Exposure Program: Aperture priority
ISOSpeed Ratings: 400
Exif Version: "0221"
Date Time Original: 2009:06:28 19:21:05
Date Time Digitized: 2009:06:28 19:21:05
Components Configuration: YCbCr
Shutter Speed Value: 0,0039 sec (1/256)
Aperture Value: F3,4
Exposure Bias Value: + 0.33 EV
Metering Mode: MultiSegment
Flash: Off, surpressed
Focal Length: 100,00 mm
Focal Length 35 mm Film: 100,00 mm
Maker Note: "."
User Comment: Not possible to define
Flash Pix Version: "0100"
Color Space: sRGB
Exif Image Height: 2912
Interoperability Offset: 4438
Interoperability Index: R98
Interoperability Version: "0100"
Focal Plane XResolution: 4368000/1415
Focal Plane YResolution: 2912000/942
Exif Image Width: 4368
Focal Plane Resolution Unit: Inch
Custom Rendered: Normal process
Exposure Mode: Auto Exposure
White Balance: Auto
Scene Capture Type: Standard
---- Äîïîëíèòåëüíûé ðàçäåë ----
Canon PhotoEffect: Custom Settings
Macro Mode: Off
Self Timer: Off (Not Used)
Compression Rate: Fine
Image Stabilizer: Not possible to define
Flash Mode: Not fired
Drive Mode: Single (One-Shot per Touch)
Focus Mode: One-Shot
Image Size: Large
Easy Shooting Mode: Manual
Contrast: Normal
Saturation: Normal
Sharpness: Not possible to define
CCD ISO: 400
Metering Mode: Evaluative
Canon AiAF: Off
ExposureMode: Av-priority (Mode 'Av')
Focus Details: Not possible to define
White Balance Preset: Auto
Flash Bias: 0 EV
Lens Type: 100 mm
Subject Distance: Not possible to define
ImageType: Canon EOS 5D
FirmwareVersion: Firmware Version 1.0.1
OwnerName: Not possible to define
CameraSerialNumber: 510202652
Noise Reduction: Off
Shutter AE Lock Button: AF/AE lock
Mirror Lockup: Disable
Exposure Level: 1/2 stop
AF Assist: On (auto)
AV Shutter Speed: Automatic
AEB Sequence: 0
Shutter Sync: 1st-curtain sync
Lens AF Button: AF stop
Fill Flash Reduction: Enable
Menu Return: Top
Set Button: Not assigned
Sensor Cleaning: Disable
Superimposed Display: On
Shutter Release w/o CF Card: Enable
Lens Information: EF100mm f/2.8 Macro USM
подскажите по exif для кенон 5д
Всего 34 сообщ.
Re[Павлухан]:
автофокус там.
Re[__NW__]:
а что означает вот этот параметр:
Кстати, на фото видно потертости горячего башмака. В других местах ничего не видно. Как по вашему, каков примерно пробег камеры?
Re[Павлухан]:
Привет фотателю ЁЖИКОВ. Паша, по такому экзиФУ пробег не видно. Только на доверии и с мыслью, что новых Пятачков не бывает. А когда ручной фокус ,помоему пишет AF Manual.
Re[GUNIK]:
Привет. Приятно, что помнишь ))) По Exifу знаю, что не видно, а вот по башмаку потертому? На моей 400-ке вообще следов небыло при пробеге 10 т. и со вспышкой, ну пусть 2000 кадров
Re[Павлухан]:
Очень от хозяина зависит. Значит неряха и потаскун по свадьбам. Щитай полресурса пройдено.
Теперь только от сладости цены и исходи... и наверно от рентабельности покупки. Клиент не оценит никак. Я на банкет мыльницу G9 планирую.
для танцев и пьяных портретов "Я и Колька"
Re[GUNIK]:
Это с Кореи, типа класс"А". Пробега не знает, цена не скажу что низкая- 50 т.р. Вот и думаю
Re[Павлухан]:
50 т.р. = это ТРИ новеньких G9 ! Ну ладно ДВА и 580ЕХ. И на пару с женой по банкетам, а дочке принтер и печать на месте
Лучше G9 в руках ,чем Пятак (со сбитым башмаком) из Кореи
Re[Павлухан]:
Фото плохое. Тут только тактильно надо, и поглядеть с разных сторон. Рискни, если невмоготу.
Мне проще, нема на покупку "золотого запасу". :?
Re[GUNIK]:
а что плохое-то? вроде ниче...Ребят, ну подскажите у кого какой пробег и каков износ башмака? Нужно определиться
Re[Павлухан]:
может в новую ветку бросить вопрос?
Re[Павлухан]:
от: Павлухан
вот кстати фото. Зацените плиз по башмаку- сколько пробег?
Близок к нулю.
На моем с пробегом 6 тыщь следов больше. А этот вообще девственный.
Re[BSH]:
спасибо, будут еще мнения?
Re[Павлухан]:
А какое отношение имеет башмак к пробегу? Я, например, за 3 с лишним тысячи кадров вспышку ставил раз пять... Это же не машина, на которой не держась за руль или не нажимая педали, не поедешь... :?:
Re[MrHare]:
Можно вспышку туда-сюда дергать каждые пять секунд не нажимая на спуск, а можно одеть один раз и палить сериями без остановки. Износ башмака совсем не указывает на пробег.
А конкретно этот башмак реально почти девственен. На моем пятаке с башмака уже краска отлетать начала
Re[Павлухан]:
Cудя по башмаку, вообще нулевый, там даже не потертости, а блики.
Re[Павлухан]:
Потертость на башмаке это не показатель пробега камеры, это говорит лишь о том, что хозяин ставил внешнюю вспышку или не ставил.
Но внешний вид у камеры очень хороший. Я бы взял.
Re[Павлухан]:
Ребят, спасибо за ответы. :)
Re[Павлухан]:
...действительно,башмак на фото в идеальном состоянии...,а облазит он,надо сказать,почти моментально,т.к.покрашен краской.Стоит пару раз одеть пыху,он и облазит...Белые алюминиевые башмаки куда практичней для сохранения товарного вида...
