Nikon выпустил новый firmware для D70
Если кому интересно, то пару дней назад вышел новый Firmware.
Привожу текст статьи от 29 June 2004 без перевода из Digital Photography Review.
http://www.dpreview.com/news/0406/04062901d70firmware.asp
D70 Firmware Update 1.0.1 / 1.0.2
The D70's firmware is split into two parts (A & B)
The D70 has two sets of firmware, A and B, which must be updated separately, the D70 'A' firmware from version 1.00 to version 1.01 and 'B' firmware from version 1.01 to version 1.02. This download file contains both sets of firmware, A and B as separate files. Upgrade is not necessary if your camera already has these versions of firmware installed.
Issues addressed with 'A' firmware version 1.01
    1) Correction of vignetting that was sometimes visible in the upper areas of images captured in Continuous mode using high shutter speeds.
    2) Correction of an issue that intermittently prevented the Automatic Sensitivity Adjustment function (ISO Auto: CSM 5) to work when the built-in Speedlight was raised but did not fire.
Issues addressed with 'B' firmware version 1.02
    1) Supports for Compact Flash™ memory cards with a capacity greater than 4GB has been added.
    2) Correction of an issue that sometimes prevented the camera from being turned off when images were captured in Continuous mode. This occurred at an Image size setting of ‘M’ and an Image quality setting of ‘FINE’, and caused the memory card access lamp to glow continuously.
    3) Errors in Chinese menus and message text have been corrected.
Качнуть можно прямо из Японии
http://www.nikon-image.com/jpn/ei_cs/swdown/dsc_firm.htm
Re: Nikon выпустил новый firmware для D70
Уже все поставили
https://foto.ru/forums/topics/94683
