там же есть интересный радио спуск ) http://abc74.narod.ru/350dremote.html Делаем ИК, проводной и радио пульты дистанционного управления для Canon EOS 350D
Назад в будущее (canon 350d)
Всего 543 сообщ.
Показаны 341 - 360
Re[whitehats]:
а может можно добавить функцию или поправки по настройке камеры и пути решения бэкфокус, фронтфокуса для объектива? :?: :?: :?:
я видел только кустарное решение "Подстраиваем работу автофокуса Canon EOS 350D" http://abc74.narod.ru/350dafadjust.html
Re[whitehats]:
Тема заглохла. А ведь интересная и новшевства http://chdk.setepontos.com/index.php/topic,4202.msg54643.html#msg54643 в прошивке появились :!:
дополнительно:
“14:TimeLapse” = Create pictures every [user set 1-999] sec. Example : 100 x 5s --- take 100 pictures at every 5 sec.
Right – increase time by 1 sec
Left – decrease time by 1 sec
Play – increase # of pictures by 1
Menu – double # of pictures (after like 10 million it goes back to 0)
“15:AFPSelection” = how you can select the Auto Focus Point
Standard = nothing changed from original set
Wheel Off = you can NOT use the wheel when selecting AFP. You can still use the Up, Down Left and Right button + the presets for APF (eg. : set + zoom out)
Blocked = You can only use the presets for APF (eg. : set + zoom out)
“16:AFPoints 1” = set the Auto Focus Point
the AF helping light of my external flash doesn't work when you're using a set that is not standard.
Use left/right in the info menu to move the cursor and set to activate/deactivate the selected points.
If all points are selected in a set the menu will show
TLLCRRB
this stands for top, left, left-center, center, center-right, right, bottom.
the point where the cursor is set to will be in lowercase. non-selected points will show a blank, with cursor set on them a @
“17:AFPoints 2” = see “16:AFPoints 1”
“18:AFPoints 3” = see “16:AFPoints 1”
“19:Review time” = # of seconds picture will be displayed after taking it. This can now be set to
Hold : display image until any button pressed
OFF: doesn’t display any image after picture was taken
1 to 30 sec : display image for user set time --- the maximum values are user settable in the file user_settings.txt, they are not fixed to 30 s
“20:AutoPowerOff” = puts camera into sleep mode. This setting can be set to :
Off: never goes into sleep mode
1 to 60 min : goes into sleep mode after user set time (1 minute increments) --- the maximum values are user settable in the file user_settings.txt, they are not fixed to 60 min.
“21:FlashExComp” = Flash Exposure Compensation. This setting can be set to :
-6 to +6 in 1/3 increments (standard was -2 to +2)
дополнительно:
TLLCRRB
Re[Rafael Fomenko]:
а какие новшества, вроде ничего значительного. у нас было это.
Re[V.J.]:
от: V.J.
Какие вы молодцы :D Хоть бы мне сообщили тогда?!
Мне вот эта новая (уже б/у у продвинутых форумчан) фича очень понравилась - “21:FlashExComp” = Flash Exposure Compensation. This setting can be set to :
Попробовал - вспышка только слегка подсвечивает в -6. Теперь пойду в студию без зеркальца синхронизироваться со вспышками студийными
Re[Rafael Fomenko]:
Низко кланяюсь этому фотику. Он хоть и стал орудием преступления и вещдоком.,но жизнь спас!
Re[Блудный сын]:
del
Re[whitehats]:
Господа ПОМОГИТЕ ставлю прошивку (скрины) как сто раз разжёвано на 3стр. ничего не помогает 6часов флэшку мучил на экране в конце выдает :CF содержит Firmware требуется обновить Обновление невозможно СТОП
Re[Анатолий Юдин]:
А родная стоит 1.0.3 ?
Re[whitehats]:
В том- то и дело стоит 1.3 менял и версии скринов каке нашел ипусковые файлы может зависит от производителя камеры?
Re[Анатолий Юдин]:
В английском хоть немного шарите? Вот тут пошагово всё описано http://chdk.wikia.com/wiki/350D
Пошарю в инете где так же подробно, но по русски...
Re[Rafael Fomenko]:
Аформатировать у меня CF 4GB нужно именно FAT16? CardTricks145 у меня форматировал в FAT 32.
50 ISO?
Тут немного нашлось время и решил задуматься все таки по поводу ISO меньше 100,поделюсь небольшим размышлением по этому поводу:
Раз те "промежуточные" значения ISO, а именно 125,1000,2500 и тд. были софтовыми и получались путем умножения сигнала первое что приходит на ум:"а умеет ли ПО делить этот самый сигнал?",-по идее нам то нужно получить ровно половину от сигнала получаемого на 100 ISO, конечно можно умножить на 0,5,но тогда наверное придется это просто выделить в отдельную функцию чтобы не мешать работе всех остальных показаний ISO
Может сказал глупость, поправьте если что
Re[Анатолий Юдин]:
Отформатировать в ФАТ16 можно при помощи вот этой утилиты http://zalil.ru/30561893 А вот сделать загрузочной - тут надо колдовать в НЕХ редакторе. Где то в начале про это пояснялось...
Отредактировал.
Почитайте вот здесь http://kadets.info/showthread.php?t=69174 про флешки 4Гб и более.
Отредактировал.
Re[Cyber911]:
Пробовали это уже. Включить функцию меньших исо можно. Тут даже выкладывали прошивку с исо 50, 25 и менее. Но практика показала что кадры сделанные на исо 100 равны всем меньшим режимам. Так что увы... :( а жаль.
Re[Rafael Fomenko]:
Я знаю что выкладывалось,может где то что-то не так было,все может быть, я отношусь сам к программистам, но мне интересно немного другое:как бы так выяснить может ли вообще софт фотоаппарата умножать на числа меньшие единицы,если да то стоит тогда призадуматься и купить много пива и засесть за мучительные думы
Re[Cyber911]:
А не посещала мысль...чтозначение ISO не самостоятельная единица, а завязано в какой-то цепочке ? ;)
Re[whitehats]:
Я тоже не программист. Но думаю дела обстоят примерно так. Матрицу делают с каким то определённым :!: значением ISO (например у Кэнона 350го ISO 100). А потом стоят программные/электронные умножители и умножают это число на 2, на 3... ну и т.д. Электронно поднять сигнал проще (транзисторный "усилитель" в радиотехнике), а вот понизить.... :?:
Re[Cyber911]:
Склоняюсь больше к тому что умножители электронные. Программно их можно только активизировать. (это из вышеописанного опыта с ISO меньше 100)
Re[Rafael Fomenko]:
Спасибо за помощь видно на моей камере прошивка какая-то левая хотя показывает 1.03.форматирую fat 16 ,переношу на флешку scanled.fir устанавливаю СF в камеру включаю CF карту в камеру и запустите обновление прошивки [в MENU/последняя вкладка настроек [ключ и молоток-2] в самом низу.]
на экране камеры должно появиться CF card containing firmware is required to update.
Подождите пока голубой светодиод не перестанет мигуть. Подождите еще 30 секунд. После этого выключите камеру, при этом она будет продолжать работать, поэтому просто нужно вынуть батарею из камеры. Самое главное делаю формат.загрузочной СF переношу на неё файл 350d_iso3200_spot устанавливаю в камеру включаю синий огонек не горит читаю на СF згруженна новая прошивка обновить СТОП и все ничего не могу сделать.
Re[Анатолий Юдин]:
"Левых" прошивок в природе НЕТ. На карту памяти в корень надо поместить файл AUTOEXEC.BIN. Читаем фак ЕЩЕ раз:
http://blog.max-fun.de/2010/02/23/chdk-firmware-hack-eos-350d/
