Калибровка с записью профиля в LUT монитора
Всего 27 сообщ. | Показаны 21 - 27
Re[Energy-2]:
от:Energy-2
купил NEC 2490WUXI2 хочу откалибровать лут монитора, дома стоит NEC2090... Есть калибратор EYE D2... Дома калибровал монитор через родную программу калибратора. Теперь тоже задался мыслью попробовать откалибровать лут монитора. В списке деййствительно нет 2490WUXI2...
Уже есть...
[quot]Hardware Support List SpectraView Profiler 4.1.20
March 2010
Colorimeter:
- basICColor SQUID
- basICColor SQUID 2
- Colorvision Spyder 2
- Colorvision Spyder 3
- Monaco OPTIX XR
- X-Rite Eye-One display
- X-Rite Eye-One display 2
- X-Rite Eye-One display LT
- X-Rite DTP 94 USB
Spectrophotometer:
- X-Rite Eye-One Pro
- X-Rite Eye-One Monitor
Display Color Analyzer:
Konica Minolta Display Color Analyzer CA-210
Displays (hardware calibration):
- NEC SpectraView 1980 (manual software activation via TAN)
- NEC SpectraView 1990 (automatic software activation via DDC/CI)
- NEC SpectraView 1990p (automatic software activation via DDC/CI)
- NEC SpectraView 2090 (automatic software activation via DDC/CI)
- NEC SpectraView 2180 (manual software activation via TAN)
- NEC SpectraView 2190 (automatic software activation via DDC/CI)
- NEC SpectraView 2190p (automatic software activation via DDC/CI)
- NEC SpectraView 2490 (automatic software activation via DDC/CI)
- NEC SpectraView 2490-2 (automatic software activation via DDC/CI)
- NEC SpectraView 2690 (automatic software activation via DDC/CI)
- NEC SpectraView 3090 (automatic software activation via DDC/CI)
- NEC SpectraView Reference 2690 (automatic software activation via DDC/CI)
- NEC SpectraView Reference 3090 (automatic software activation via DDC/CI)
- NEC SpectraView Reference 21 (automatic software activation via DDC/CI)
- NEC MultiSync P221W (manual software activation via TAN)
- NEC SpectraView Reference 241 (automatic software activation via DDC/CI)
Displays (combined hard- and software calibration):
- NEC MultiSync LCD 1980 (manual software activation via TAN)
- NEC MultiSync LCD 1990SX (manual software activation via TAN)
- NEC MultiSync LCD 1990SXi (manual software activation via TAN)
- NEC MultiSync LCD 2090UXi (manual software activation via TAN)
- NEC MultiSync LCD 2180UX (manual software activation via TAN)
- NEC MultiSync LCD 2190UXp (manual software activation via TAN)
- NEC MultiSync LCD 2190UXi (manual software activation via TAN)
- NEC MultiSync LCD 2490WUXi (manual software activation via TAN)
- NEC MultiSync LCD 2490WUXi2 (manual software activation via TAN)
- NEC MultiSync LCD 2690WUXi (manual software activation via TAN)
- NEC MultiSync LCD 2690WUXi2 (manual software activation via TAN)
- NEC MultiSync LCD 3090WQXi (manual software activation via TAN)
- NEC MultiSync LCD PA241W (manual software activation via TAN)
Displays (software calibration):
- all other displays, LCD and CRT (manual software activation via TAN)
Other Devices:
- basICColor diLIGHT
- JUST Color Communicator 2
- manroland Press Console[/quot]
Re[Sergey Kan]:
достаточно ли пробной версии? Я так понимаю родная SW работает 14 дней. Этого хватит чтобы залить все настройки и работать? или нужен все же ключик дабы все работало.
Заранее спасибо.
Re[Energy-2]:
от: Energy-2
Заранее спасибо.
Пробная версия полнофункциональная. Через 14 дней работать перестанет.
Но профили останутся... :D
Только если будет также использоваться ЛУТ видеокарты, то загрузчик надо будет взять другой.
P.S. Как заставить работать дальше не спрашивайте. Не знаю. У меня еще 1980SXi, где была волшебная комбинация включающая режим SV. После этого профайлеру уже никаких лицензий не надо...
Re[Sergey Kan]:
Как-как... ключ нужен. Мне тут как-то добрые люди подкинули. У меня уже год стоит SVII на 2490WUXi2, не ругается.
Re[Скилливидден]:
от: Скилливидден
под SVII у меня и генератор есть...
А профайлер так работает. Типа для родного SV монитора никаких ключей не надо...
Re[probe]:
от:probe
Показать ущёрбность SVII очень просто: создайте в фотошопе пустой лист с профилем монитора. И залейте его горизонтальным (или вертикальным) градиентным серым с отключенным дизерингом.
В районе малых яркостей будут очень заметны границы переходов. Более того, там серый будет переливаться цветами.
Это довольно странный метод проверки :-)
То, что вы видите на мониторе в Фотошопе обработано перед показом Фотошопом с учетом профайла вашего монитора. Отсюда могут вылезать неравномерности градиента.
Так можно проверять качество профайла, но перед проверкой надо назначить созданному градиенту профайл монитора.
Именно Assign profile.
В этом случае Фотошоп будет считать, что картинка для вывода на монитор уже в нужном нам профайле и никаких изменений в нее вводить не будет.
Re[sakharov]:
от:sakharov
Дык он собственно говоря и хотел показать ущербность созданного профайла...
от:sakharov
Зачем козе баян?
Да еще и через задницу...
Присваивать картинке профиль конкретного выводного устройства это бредятина. Профиль устройства вывода нужен только для того, чтобы сконвертить в него картинку перед выводом (каким образом это делать это второй вопрос - вариантов море).
Если так уж хочется посмотреть в ФШ как будет выглядеть картинка с отключенным профайлом монитора (хотя лично я не очень понимаю зачем это может понадобиться), то вполне достаточно нажать Ctrl+Y (View - Proof setup - Monitor RGB).
