Вышло обновление прошивки для X100T - http://www.fujifilm.com/support/digital_cameras/software/firmware/x/x100t/
Обновления для X100T довольно незначительны, направлены в основном на исправление ошибок в камере (см пресс-релиз внизу).
Последняя версия прошивки имеет номер 1.10 для X100T.
Ver.2.10 для X100 / X100 Black, Ver.1.20 для X100S / X100S Black.
FUJIFILM RELEASES NEW FIRMWARE FOR X100T, X-T1, S1 AND FOUR X-MOUNT LENSES
March 31st, 2015 – Fujjifilm Corporation has released firmware updates for the following products to enhance operability and functions:
X100T FIRMWARE UPDATES:
“CONVERSION LENS” setting updated
When an Fn button with “CONVERSION LENS” setting is pressed, one of the messages below appears in a cyclic manner in addition to the icons.
Improved flash functionality
When using an external non-TTL flash, it will now fire when the “MECHANICAL+ELECTRONIC” is selected in the “SHUTTER TYPE” option of the SHOOTING MENU.
Updated viewfinder display
When the dual optical viewfinder/electronic range finder (ERF) display is used with the Digital Split Image, the white Focus frame appears in the centre of the viewfinder.
Improvement of Focus Peaking display
Focus peaking improved in the electronic viewfinder for darker environments to help with focusing.
