Trial (по крайней мере под Mac) скачивается версии 13.1.1.
https://support.captureone.com/hc/en-us/articles/360010082458-Capture-One-20-13-1-1-release-notes
Capture One Pro (5, 6, 7 ,8, 9, 10, 11)
Всего 10729 сообщ.
Показаны 9121 - 9140
Re[Sanchis]:
Re[Sanchis]:
от: Sanchis
Чтото на офсайте нет этого обновления...
Появилось. :)
Re[Rafael Fomenko]:
Да, подтверждаю! :D
Capture One 13.1.1
Capture One 13.1.1
Добавлена поддержка macOS Catalina 10.15.5.
Исправлены критические ошибки в работе.
Также в Capture One 13.1.1 курсор кисти/градиента теперь автоматически переключается на режим, соответствующий выбранному слою (Корректирующий, Исправляющий, Клонирующий).
Исправленные ошибки в работе: Mac
Fixed an issue where OpenCL would sometimes not work with Intel Iris GPUs.
Fixed an issue where a white vertical line could appear on some images when exported.
Fixed an issue where Luma Range masks would not include Heal and Clone Layers when recalculating the range.
Fixed an issue where the color swatches would sometimes disappear in Basic Color Editor.
Fixed an issue where Color Editor settings could disappear when creating a new Layer.
Fixed an issue where the shortcut for Hide Clone / Heal Arrows would not persist correctly.
Fixed various issues with Phase One iXG movement.
Fixed an issue where using watermarks would cause poor performance.
Fixed an issue where Open With plugin would fail to initialize.
Fixed an issue where Favorite Icon would not show on new Favorites until restart.
Fixed an issue where a global range in Advanced Color Editor could not be added as the first range.
Fixed an issue where print watermarks could scale incorrectly or disappear.
Fixed an issue where resetting the Keystone Tool would not reset the keystone lines in the viewer.
Fixed various other issues.
Исправленные ошибки в работе: Win
Fixed an issue where undoing heal strokes would sometimes work incorrectly.
Fixed an issue where brush flow would not be correctly persisted.
Fixed an issue with images not displaying when selecting a Project.
Fixed an issue with Projects not updating correctly.
Fixed an issue where having Exposure Evaluation visible would negatively impact editing performance.
Fixed an issue where legacy tool tabs were not available from the customize tool tab menu.
Fixed an issue where it was not sometimes possible to reset the Layers of all selected variants.
Скачать Capture One 13.1.1
Re[:
Наболело
Вес файла сохраненного в tiff:
Без компрессии - 110Мб
Zip - 88Мб
LZW - 105Мб
После пересохранения в фотошопе в Tiff с компрессией LZW - 66Мб, т.е. вес уменьшается вдвое.
Капча не умеет LZW?
Zip - 88Мб
LZW - 105Мб
Капча не умеет LZW?
Re:
"Вот тебе, бабушка, и Юрьев день!"
Обнаружил в версии 20.0.3 билд 13.0.3.19,
что C1 теперь не может 2-а раза подряд сохранить одинаковые RGB-значения в tiff-файл.
Сохранял tiff-файл с профилем "Embed Camera Profile" для профилирования.
Никакие настройки не меняются,
но при каждом новом сохранении, получаются другие RGB.
Превознемогая себя :) , установил последнюю С1 версии 20 билд 13.1.1.31.
То же самое.
В изображении с колочекером24 размером 960x630 пикселей (от NikonD3s) отличия больше 100-а единиц RGB(16bit) такие:
X,Y : RGB из Сохранения_1 - RGB из Сохранения_2
220,467 : 41568 17841 16670 - 41463 17788 16631
221,467 : 41360 17793 16658 - 41257 17734 16604
228,818 : 12034 08096 06097 - 11933 08043 06063
302,026 : 48292 28541 08329 - 48130 28417 08270
302,029 : 47583 28020 08208 - 47404 27878 08144
302,030 : 48666 28834 08557 - 48465 28689 08506
323,562 : 05749 05796 05978 - 05642 05690 05864
325,718 : 05327 05372 05594 - 05221 05231 05483
445,493 : 54877 48573 14441 - 54719 48436 14370
449,493 : 54112 47734 13492 - 53963 47593 13440
466,046 : 09050 14522 33780 - 09019 14469 33666
494,407 : 39964 40822 40949 - 39836 40697 40832
590,149 : 06877 07124 07548 - 06770 06999 07415
625,483 : 06142 06379 06729 - 05998 06245 06578
627,385 : 40531 41244 41506 - 40429 41140 41401
627,391 : 40532 41176 41442 - 40429 41085 41355
Всего разных по величине отличий RGB в этом изображении размером 960x630: 34475
Вы поняли о чем я ?
Сохраняете фото в tiff-файл, получаете, например, "D3ShMULTII000200.tif".
Сразу же cохраняете 2-ой раз, получаете "D3ShMULTII000200 1.tif".
И они - разные.
Но, видимо, это не беда,
зато у нас теперь столько нового и "полезного".
То же самое.
Вы поняли о чем я ?
И они - разные.
Re[Eugene_O]:
А Вы им написали уже об этом?
Re[Павел И.]:
У меня визуальных различий нет. А цифры мне не очень нужны
Re[Eugene_O]:
от: Eugene_O
Всего разных по величине отличий RGB в этом изображении размером 960x630 34475 ...
Уточните об огромном числе отличий в мишени из 24 плашек.
И вопросы:
1. Правильно ли я понимаю, что в Ваших измерениях величины яркости в отдельно взятом RGB канале находятся в диапазоне 0-65535?
2. Какие циферки получатся после применения профилей сделанных из Ваших 2х уже замеренных "разных" файлов?
3. Если делать тифф без масштабирования и сжатия, будет разница или нет?
Re[dm1967]:
от: dm1967
И вопросы:
"X,Y" - это координаты пикселей в изображении размером 960x630.
RGB(16bit) - это 0-65535.
Профили и камерные, и вывода могут быть любыми,
и TIF без сжатия.
И колочекер совершенно ни при чем потому, что
речь идет о 2-х последовательных сохранениях любого _одного_и_того_же_ изображения.
Если не выделять непосредственно сам RGB-массив, то
это можно тупо проверить сравнением полностью 2-х tif-файлов по содержимому.
Например, так:
fc /b "TheSameImage.tif" "TheSameImage 1.tif"
Но вот не знаю хватит ли словарного запаса из "великого и могучего",
чтобы полностью озвучить ответную реакцию на результат.
Re[Rafael Fomenko]:
Печаль однако!
лайтрум и RawTherapee выдают полностью идентичные тифы на выходе
Re[dm1967]:
от: dm1967
Печаль однако!лайтрум и RawTherapee выдают полностью идентичные тифы на выходе
Печаль ?
Уже было так
А теперь нет,
это другое слово, но тоже на букву "П".
И лайтрум и RawTherapee тут ни при чем.
В бережно хранимой C1 v9.3 все так, как и должно быть.
В голове не укладывается,
как вообще смогли добиться таких "выдающихся" достижений.
Re[Eugene_O]:
Что не так?
Сравнение по содержимому двух сохранённых подряд файлов ХХХ.tif ХХХ 1.fif в Тотал командер говорит, что файлы иденитичны.
Контрольный выстрел- сравнение файлов в шестнадцатеричном редакторе Hex Editor Neo 6.31 в разных режимах с использованием разных алгоритмов поиска различий говорит, что файлы идентичны. До Бита. Соответственно, и визуально нет различий.
Re[Aglo1]:
от:Aglo1
Что не так?
Контрольный выстрел- сравнение файлов в шестнадцатеричном редакторе Hex Editor Neo 6.31 в разных режимах с использованием разных алгоритмов поиска различий говорит, что файлы идентичны. До Бита. Соответственно, и визуально нет различий.Подробнее
winmerge, к примеру, отличия видит
Re[dm1967]:
от: dm1967
посмотрел багфиксы их и чего то как то доверять ему не хочется
Re[dm1967]:
от: dm1967
Хотите работать с содержимым файлов - используйте шестнадцатеричные редакторы. Это профессиональные программы для профессионалов, знающих что они хотят. Не верите алгоритмам сравнения HEX-редактора, можете прокручивая файлы, визуально смотреть содержимое одинаковых адресов.
Хотите глубоко копать, используйте соответствующий инструментарий.
Re[Aglo1]:
от:Aglo1
Хотите глубоко копать, используйте соответствующий инструментарий.Подробнее
Что Вас побудило начать поучать меня? :D :D :D
Re[dm1967]:
Использованеие сомнительного инструментария.
ДА и не поучать, а рекомендовать.
Re[Aglo1]:
от: Aglo1
Советы и рекомендации о которых Вас не спрашивали, выглядят по меньшей мере странно... :D
Да и выводы Ваши об использовании мной чего бы то ни было ошибочны
Re[dm1967]:
С Вами всё понятно.
