Canon 1Ds vs. 5D. Б/у.
Всего 92 сообщ. | Показаны 41 - 60
Re[Fannyfinger]:
от: Fannyfinger
Главное, я так понимаю, - что-нибудь ответить... Очень доволен
Главное лапшу на уши навесить...
Результат главное, а не промежуточный носитель :)
Re[Дмитрий Курилов]:
[quot]->> I'm using the 1Ds... I like it because it matches with my other 1d-series cameras, but you are really maxing it out at ISO 800. I'm one of "those guys" who actually needs the durability and weather-sealing things. Batteries go so fast it's unreal.
The files are comparable to a 5d, if not sharper. They seem to spend a little more time on that kind of thing with the pro cameras (there has to be SOME reason to buy them). It does actually have the zoom in review, though it isn't as well-developed as the newer ones - turn it on with the custom function, and there's a way to scroll through 9 or 16 tiles of the image to check focus. It's a little annoying, but works for slow-moving situations. The review time doesn't bug me too much - if you turn the review time up a little and use it with a histogram you don't really have to worry about it too much. But if you're trying to do playback, it can take some time. The AF on the 1ds is a world of difference above the 5d - this really cemented it for me.
The couple of things that really are making me think about changing over to a 5d is the fact that less color correction is required on the 5d - nothing is glaringly obvious straight out of a raw on the 5d's, while a 1ds has some nasty greens in the shadows. The battery time really kills you. It's just a couple hundred shots while using AF and LCD sparingly. I've found that I rarely use it with portrait or longer lenses, and low-light situations I tend to stick to a mkII-N for the better AF, so the difference in the 5d and 1ds isn't really too noticeable for things like weddings when it's a 2nd/3rd/4th camera. It tends to get relegated to remote work a lot. Not that a 5d wouldn't.
I'm just going to wait for the 5d upgrade and re-evaluate... If I can take a profit by switching over I will; otherwise I'll keep it or consider a 1DsII.[/quot]
[quot]The moral of this story is that if you use this daily as a second body or backup, I'd recommend the 1Ds. If all you want is a FF camera, then the 5D is great. Just keep in mind that the 1Ds is very slow if you are a chimper.[/quot]
Re[Mike_]:
от: Mike_
У пятока лучше картинка
А можно ли где-нибудь посмотреть что-нибудь типа сравнений?
Один и тот же сюжет, снятый на деэску и на пятак?
Гугел в ауте...
[quot]->> I don't buy this stuff about the 5D being flimsy.
I have dragged 5D's up and down mountains. I have had them underwater in housings. I have had them mounted to cars, airplanes, mountain bikes, and more. 90% of the time, I am out in the dirt and weather and have had absolutely no issues whatsoever.
Get the 5D you will be happier than the 1Ds. If you like a "big" camera, buy the grip and you are back to basically a 1 series camera.
I forgot - until some of you mentioned it - just how glacially slow the buffer is on the 1Ds.[/quot]
Re[dbanet]:
от: dbanet
Гугел в ауте...
А может не искать микроскопические различия в картинке этих двух камер? Ведь хороший и технически качественный снимок - это еще и многие другие факторы, которых в 1Ds больше:
- автофлкусировке и работа с боковыми точками
- две флешки (надежность)
- емкость АКБ (не уверен...)
- эргономика
- техническая надежность
- пыле влага и удароустойчивость
При сегодняшней равной цене (35-40 тр), эти качества ЕДИНИЦ, ведь то же чего то стоят! А порой это даже важнее чем работе в чуть больших ИСО? и чуть с большей матрицей (пик селей)?
И вообще, все ЕДИНИЦЫ, перед продажей забрызгивают специальным сопреем и камера становится - притягательной и любимой, не смотря на изначально пугающий вес и габариты...
Re[Генпалыч]:
от:Генпалыч
- эргономика
Про спрей улыбнуло.
Ну, кто что скажет ещё?
Re[dbanet]:
Есть еще такая тенденция, народ который ругает ЕДИНИЦЫ за из габариты и вес, через какое то время покупает батблок к своей камере, вешает его, привыкоет и больше ни когда не снимает и ... Опять начинает ругать ЕДИНИЦЫ за ее Гагарины и вес...
Вот лот на ебее 130677554370. Под конец торгов можно будет например за 800долларов взять.
Но, блин, неужели никто не делал тестов?
Склоняюсь к пятаку и батручке...
Re[dbanet]:
от: dbanet
Почему?
потому что:
- есть больше шансов нарваться на ушатанный вусмерть, чем на хорошо сохранившийся;
- затворы больше в сервисы не поставляются, а значит если затвор крякнет, то надо будет искать какой-то б/у-шный и нет гарантии, что тот тоже не присмерти;
- банально нет даже слота для второй карты;
- есть за чуть большие деньги более свежие Дски - 2й серии.
Вот, сравните сами:
а вот автофокус и у 1Ds и у 1Ds-II от пленочного EOS 1V. И только в 1Ds-III поставили новый датчик с 19ю крестами вместо семи.
Re[Ёхан]:
от:Ёхан
потому что:
Первые два пункта да, существенны.
Re[dbanet]:
Ни сколько не уговориваю за 1Ds - просто рассуждение аппонента за 1Ds
- здесь на Фото.ру на барахолке 1Ds - за 34 тр - можно посмотреть и диагностировать!
- купить затвор в прозапас (сейчас это пока возможно из старых запасов), и забыть этот пункт - пожизненно!
Ну а если хочется 5D - то же хороший выбор, но проблема с заменой затворов в сервисе там скоро то же наступит...
Re[dbanet]:
от: dbanet
Про спрей улыбнуло.
Ну давай я еще скажу,за цену не говорили -цена 1дс 8000$ была в 2002 а 5така 2000$ в 2005, насчет затвора, то они просто решили убить не убиваемою камеру именно так,прекратить выпускать затворы иначе камера будет вечной,иначе продажи не будет 1Dx
Re[babuin]:
Уф...
Всё сложно.
Re[dbanet]:
Затворов к единице не выпцскают, конечно, но у них и ресурс куда как выше, чем у пятака.
Что у них с матрицей?
Вот уже который раз не могу получить какой-нить объективный ответ.
Что-нить типа теста 1дс и 5д?
Должен быть кто-то на форуме с этими камерами.
Re[Генпалыч]:
от: Генпалыч
флэшка одна
аккум так себе
Re[Ёхан]:
Тем более, что аккум может быть уже и помирающим. Вообще за аккумы я бы поболе беспокоился, чем за затвор.
dbanet, да вам уже не раз сказали, что разница в картинке будет минимальна. Герметический тест их покажет, реальная съемка - нет. Плотность пикселей на матрице практически одинаковая, структура - тоже, DLA тоже не сказать чтобы различается.
Re[Anton Grachev]:
от: Anton Grachev
А чо эта? Ресурс затвора 1Ds всего 150.000 срабатываний.
У 5D ресурс 100.000 срабатываний.
Re[Ёхан]:
Да ничо эта. 150 тыс - это очень много, на самом деле. ну, то есть лупить свадьбы или каталоги я бы ей не стал, само собой. Но это нас приводит к тому, для чего вообще ТС камера.
