Цитата:от: noir.
Лучше современных спотов?
Вот заключения из статьи:
"Does the SEI deserve its awesome reputation? And is it -- especially in its LED form -- a usable meter today? The answer to both questions, as so often, is a firm, unequivocal "It depends."
Certainly, as the first ever top-flight professional spot meter, an unmodified SEI is an incredible bit of kit, and as an example of the utmost quality in electro-mechanical-optical design, it is up there with the best. For a collector, a plain SEI is indeed a prize worth having.
The story with usability is a bit more complicated. Although it is possible to use an unmodified meter, we would suggest that the LED conversion is all but essential if you really want to use the SEI. Then, even with the modification, it is distinctly slow and cumbersome next to just about any other spot meter on the market. The upside-down image is also, as already noted, distinctly disconcerting, and with the first ND in place (which is the normall setting for outdoor photography, shadow readings) the image is somewhat murky."
а вот сама статья:
http://www.rogerandfrances.com/photoschool/sei.html
