Не знаю, вам виднее, как владельцу обоих камер.
От себя скажу, что картинка от 5д3 немного отличается, но не в худшую сторону однозначно.
Canon EOS-1D X Mark II
Всего 1596 сообщ.
Показаны 101 - 120
Re[EOS-1D X]:
Canon EOS-1D X Mark II Firmware Version 1.0.2
Changes:
Firmware Version 1.0.2 incorporates the following functional improvements and fixes.
1. Incorporates countermeasures for a phenomenon in which the bottom part of still images recorded to SanDisk CFast cards become corrupted.
2. Enhances communication reliability between the camera and CFast cards.
If you are using the affected CFast cards, after having updated the camera firmware to Firmware Version 1.0.2, please make sure to use the camera to format the CFast card.
The Version 1.0.2 firmware being released at this time is for cameras with Firmware Version 1.0.0. If the camera's firmware is already Version 1.0.2, it is not necessary to update the firmware.
When updating the firmware of your camera, please first go over the instructions thoroughly before you download the firmware.
The firmware update takes approximately six minutes.
<Cautions in the Use of SanDisk CFast Cards>
Please note that when using the SanDisk CFast cards listed below with the EOS-1D X Mark II, the bottom part of still photos may become corrupted.
Affected CFast Cards:
- SanDisk Extreme PRO CFast2.0 64GB (SDCFSP-064G-xxx)
- SanDisk Extreme PRO CFast2.0 128GB (SDCFSP-128G-xxx)
- SanDisk Extreme PRO CFast2.0 64GB (SDCFSP-064G-xxxA)
- SanDisk Extreme PRO CFast2.0 128GB (SDCFSP-128G-xxxA)
- SanDisk Extreme PRO CFast2.0 64GB (SDCFSP-064G-xxxB)
- SanDisk Extreme PRO CFast2.0 128GB (SDCFSP-128G-xxxB)
*The "xxx" at the end of the product number varies depending on the sales region.
When using the affected CFast cards with the EOS-1D X Mark II, follow the steps below.
1: Check whether the firmware version of the EOS-1D X Mark II is Version 1.0.2 or later. If the firmware version of the camera is Version 1.0.0, update the firmware to Version 1.0.2 or later.
2: Format the affected CFast card with the EOS-1D X Mark II with firmware version 1.0.2 or later.
Note that when using a CFast card formatted according to the above step 2, the following operations will take place.
- An "ImgSaver.bin" file of several MB in capacity will be created in the "MISC" folder on the card. Do not move or delete the folder or the file on the card.
- When opening the card slot cover, the access lamp may remain lit or blink for a longer duration.
Remove the card only after having confirmed that the access lamp is off. When the access lamp is lit or blinking, recording to the card is in progress.
Never perform the operations below when the access lamp is lit or blinking as doing so may result in corrupted image data or may cause damage to the card or the camera.
- Removing the card
- Removing the battery pack
- Applying vibration or shock to the camera
- Unplugging and replugging the power cord (when using the separately-sold household power outlet accessories)
When using SanDisk CFast cards, to fully utilize the card performance, use the refresh tool provided by SanDisk before formatting the card with a camera with the above step 1 applied.
Refresh tool: http://kb.sandisk.com/app/answers/detail/a_id/17370
In addition, if an affected SanDisk CFast card has already been formatted with a computer or another device, please format the card again with a camera with the above step 1 applied.
About the "Refresh Tool" of SanDisk cards:
Q1: Whenever the camera is used to format a SanDisk CFast card, is it mandatory to use the refresh tool? If the refresh tool is not used, will the bottom part of still images become corrupted?
A1: The refresh tool is not related to image corruption that appears at the bottom part of still images. We are informing users about this tool as SanDisk recommends regular use of the refresh tool when using SanDisk CFast cards. For details about the use of the refresh tool, please inquire with SanDisk.
Q2: How often does the refresh tool have to be used?
A2: For details about use frequency, and the use of the refresh tool, please inquire with SanDisk.
Q3: What will happen to camera operations if I continue using a SanDisk CFast card without using the refresh tool?
A3: The speed for continuous data writing may decrease. If the data writing speed seems to have decreased during high-speed continuous shooting, please try to use the refresh tool to alleviate the problem. For any other technical questions concerning CFast cards, please inquire with SanDisk.
Before starting the firmware update operations, please confirm the contents of the download, and carefully read through the firmware update procedures.
Changes:
- Removing the card
Re[caramba1]:
от: caramba1
Сереж, я не говорю про лучше и хуже...Просто все единичке Кенона разные по картинке.
Re[caramba1]:
И правда покидали бы равов с портретами людей-на солнце-против солнца,в тени,в помещении с энергосберегайками т.п.
хочется посмотреть,покрутить,убедиться что 1 версия лучше второй
Re[caramba1]:
Re[caramba1]:
от:caramba1
сравнение сабжа с предшественником и другимиПодробнее
Снятое лицо при одной горящей свечке мне больше информации о камере даст,чем тысячи этих тестов
Re[Алексей Коровкин]:
http://cpn.canon-europe.com/content/education/technical/thorsten_milse_on_wildlife_photography_in_madagascar_the_eos-1d_x_mark_ii.do?utm_source=newsletter_july_2_16&utm_medium=email&utm_campaign=Newsletter
Re[EOS-1D X]:
от:EOS-1D X
http://cpn.canon-europe.com/content/education/technical/thorsten_milse_on_wildlife_photography_in_madagascar_the_eos-1d_x_mark_ii.do?utm_source=newsletter_july_2_16&utm_medium=email&utm_campaign=NewsletterПодробнее
Роскошно, мы так сразу из снимков диковинных толи животных, то ли тварей каких на мадагаскаре ) и поняли, как камера бледнолицых россиян - жениха с невестой и пьяных гостей в загсе/прогулке/ресторане снимает, в условиях российской действительности )))
Re[Пётр Иванов]:
от:Пётр Иванов
Роскошно, мы так сразу из снимков диковинных толи животных, то ли тварей каких на мадагаскаре ) и поняли, как камера бледнолицых россиян - жениха с невестой и пьяных гостей в загсе/прогулке/ресторане снимает, в условиях российской действительности )))Подробнее
Каждому свое...
Re[Пётр Иванов]:
от:Пётр Иванов
свадьбы бомбить можно чем и попроще, эта камера не для этого
Re[hunter07]:
от: hunter07
Зашибись, топовая проф репортажная камера и не для этого? Это баобабы можно на цифрокомпакт снимать, никто тут и неотличит ничего, так как всеравно все в диковинку!
Re[Пётр Иванов]:
от: Пётр Иванов
да
для этого третьего марка за глаза
я вобще в принципе плохо понимаю зачем Дх нужен если не снимать проф спорт
Re[hunter07]:
от: hunter07
да
Все от гонораров зависит.
Если свадьбы по 100-300 баксов снимать - да, там и Марка сильно много.
А если на уровне топов - почему бы и не взять топовый кирпич?
Быстрее, удобнее, бесшумнее по ИСО, вроде как АФ еще лучше....
Все от денег в кармане зависит, кому заработки позволяют - берут лучшее из имеющегося на рынке.
Если деньги лимитированы - надо выбирать под свои нужды. Мне и 5Д3 слишком много - хватает и 5Д2.....каждому свое.
Re[KOt]:
Речь в разумности затрат. это все равно что из пушки по воробьям пулять. Если возможность есть такая, то можно конечно, вот только зачем?
Одно дело любитель покупает такой кирпич, потому как ему хочется просто, хотя реальной потребности в нем и нет. А свадьбы это жесткая коммерция - потому вложения должны отбиваться и быть оправданными.
Re[hunter07]:
Если цена сабжа - гонорар за 1-2 свадьбы - зачем печалиться о мелочах?
Не надо рукоблудить с батарейной ручкой, долгая батарея. С 5Д3 надо костыли эти брать.
Кроме того, в особо кучерявых условиях типа церквей и загсов - сабж явно будет интереснее работать.
А также - имиджевый момент - можно вполе спокойно говорить, что технику топовая/лучшая и т.п. На таком уровне - это важно.
Взять того же Бабичюса - давно уже на кирпичах Д3-Д4 сидит. Хотя можно было д700, а потом Д750-Д800-810 взять.
Re[hunter07]:
от: hunter07
да
Тут, вопрос, для спорта может быть и удобней и производительней 7дмк2, за счет кропа, в спорте на самом деле пофиг как спортсмены выглядят, главное схваченный момент!
А вот торжественная событийка - свадьбы, концерты, выступления, тут надо жизненно важно морды лица красивые были...
Представьте лучший друг молодой семьи "Петрович" уже на закусках упал счастливый мордой в салат - так салат должен на фото вкусно смотреться )))
Re[Пётр Иванов]:
морды красивыми сделать это работа стилиста-визажиста
красивый салат кстати тоже, фудстилисты даже такие есть
Re[hunter07]:
Del. Дубль
Re[KOt]:
от:KOt
Взять того же Бабичюса - давно уже на кирпичах Д3-Д4 сидит. Хотя можно было д700, а потом Д750-Д800-810 взять.Подробнее
от: hunter07
да
от:hunter07
Одно дело любитель покупает такой кирпич, потому как ему хочется просто, хотя реальной потребности в нем и нет. А свадьбы это жесткая коммерция - потому вложения должны отбиваться и быть оправданными.Подробнее
А на свадьбах нет места репортажу?В темных условиях освещения не нужно выражения морды лица ловить ?
Насчет стоимости...я покупал еще за 217 тыщ и не такие уж и большие деньги были.За 1-2 свадьбы не отбил конечно как КОТ говорит,но вы извините,ресурс от у камеры 400 тыщ,а у 5д марк 3 - 150 тыщ. Что лучше 3 раза подряд покупать 5д марк 3 или 1Д Х. По-моему ответ очевиден.И дешевле получается с расчетом на перспективу
И 1Д Х более надежная камера в случае падения или ударов ,или глюков,или дождя.
В сложных условиях съемки камера более четкая по всем параметрам-по ББ,по экспозиции,по работе с вспышкой,по фокусе тем более.
Просто был опыт работы на свадьбе 2 камерами -1D X и 5D Mark3 .
P\S На 5д марк 3 при съемке на улице в яркую погоду ,далее в обработке цвета получаются более насыщенные и легче тонировки получаются-,в этом мне пятак больше нравятся.Ползунки при регулировке цветов в RAW абсолютно по другому крутятся,поэтому на одни и те же фото с разных камер, пресеты будут разными
Я не уверен, что реальный пробег у 5Д3 и кирпичей в 3 раза отличается.
Вроде как и Марки сильно больше 150 тыков бегают, так что "сносить" не так и просто.
Да и почему "ресурс камеры" - ресурс затвора всего лишь. В Москве замена затвора быстро и дешево, насколько я знаю.
Так что ресурс, имхо, вторичен, надо смотреть на другие параметры.
Кстати, влагозащита - да, не помешает, думаю, чтобы не просить кого-то из гостей держать зонтик - видел как-то на одной свадьбе такое
