https://www.43rumors.com/ft5-100-new-olympus-announcement-february-probably-e-pl9/
В феврале обещают анонс от Олимпуса новой камеры, но никто пока не знает, какой.
Новости и перспективы развития системы м4/3 [mod]
Всего 30310 сообщ.
Показаны 4301 - 4320
Re[Александр Евгеньевич]:
Re[МакФлай]:
от:МакФлай
Ну слухи ходят. Никто ничего не обещал, но период обновления ~3 года вроде правдив
E-M5 Mark III will be announced on February 28th 2018 with availability in late March/early April. It will launch at 1399 USD/EUR for body-only option.
Here are the full (well, not quite) specs:
16.4 mp stacked CMOS sensor with global electronic shutter
TruePic VII image processor
Native ISO range: 100-25,600
ISO LOW equivalent to ISO 64
12 and 14-bit raw image capture (lossless compression)
4.4 million dot EVF with x0.79 magnification
1 million dots fully articulating display
121-point contrast detect "predictive" AF with new breed of algorithms for scene analysis (different to Panasonic's DFD if you are wondering)
1/32000-60s electronic only shutter (no mechanical shutter) with the usual BULB and LIVE modes available
1/2000s flash sync with every flash and max 1/8000s with FL-900R
Sequential High (S-AF) at 20 fps (12-bit capture only)
Sequential Low (C-AF) at 11 fps 12-bit and 8 fps 14-bit
Pro-Capture mode (max 10 pre-shutter frames)
36 image buffer (raw)
HDR RAW capture (3 frames)
Multi-exposure RAW capture (3 frames)
Improved High Res mode (up to 60 seconds on the long end, up to 50% faster acquisition of individual frames compared to E-M1 Mark II)
5-axis IBIS, up to 6 stops or 6.5 with Sync-IS
Auto-levelling function using IBIS
4K video with full sensor readout, up to 30fps
Cinema 4K at 24 fps with high bitrate codec
Full HD up to 60 fps
720p up to 120fps
8-bit 4:2:2 clean output through HDMI
Mic and Headphone jacks
USB-C (3.1)
Micro HDMI port
Single UHS-II memory card slot[Подробнее
По некоторым характеристикам (конструкция сенсора, 14-битный РАВ, отсутствие механического затвора...) напоминает Сони А9...
Re[Юрий Трубников]:
от: Юрий Трубников
Только бы не ценой :)
от: Александр Евгеньевич
Pl-9
Цены только растут...
E-M1II firmware update coming soon with some features that will be included in the E-M5III
https://www.43rumors.com/e-m1ii-firmware-update-coming-soon-features-will-included-e-m5iii/
Re[А.Барабанщиков]:
Похоже, всё таки будет анонс ПЛ-9, Е-Ммк3 будет, наверное, в сентябре.
Re[А.Барабанщиков]:
от: А.Барабанщиков
https://www.43rumors.com/e-m1ii-firmware-update-coming-soon-features-will-included-e-m5iii/[
То есть, некоторые фичи, обкатаные на М1Мк2, воткнут в М5 Мк3...
Re[Юрий Трубников]:
И наоборот: новые фичи, которые будут в Е-М5-3, добавят в новые прошивки для Е-М1-2 - так в последних слухах пишут.
Походу, PL9 будет близок к 10-3
Ждем 4К, улучшенный стаб и бесшумный затвор (хоть и через странное меню).
И так, и так хорошо. Нехай трудются.)
Интересно, видоискатель положат или опять зажмут?
И ещё интересно, сольются ли в будущем линейки Е-PL и Pen-F
В сентябре на фотокина состоится анонс камеры к 100-летию ОМД. Вероятно это будет ем5м3 !?
Re[А.Барабанщиков]:
от: А.Барабанщиков
Откуда такие вести?
от: Александр ЕвгеньевичВсе-же это скорее предположение :)
Откуда такие вести?
Re[А.Барабанщиков]:
от: А.Барабанщиков
к 100-летию ОМД.
:?: Может все таки всего Олимпуса?
Re[Shovg]:
от: Shovg
OM-Digital - был фперди планеты фсей
К 100 летию Олимпуса покажут новый супер микроскоп)
Первую камеру сделали только в 1936 году)
Хз, мне кажется если и будет камера к 100тию, то это будет что-то редкое и премиальное, типа Пен-A нового или просто лимитед-версия, например.
5марк3... А он точно будет?)
Re[LeonovS]:
от:LeonovS
5марк3... А он точно будет?)Подробнее
К 100-летию по весии Олимпус :) будет камера из линейки ОМД, а что касается ем5м3, то опять же, если верить Олимпус, то обновление прошивки ем1м2 будет содержать ряд новшеств, которые будут обкатаны на ем5м3. Ну а про крокодайловую кожу и платиновый корпус пока что ничего неизвестно.
Re[Shovg]:
от: Shovg
На руморсах как-то шла речь о новой камере, которую Олимпус выпустит к 100-летию ОМД и эта камера пополнит линейку ОМД. Речь шла без каких-либо оговорок и или.
