Mount Standard Micro Four Thirds System Standard
Focal Length 45mm
35mm Equivalent Focal Length 90mm
Lens Construction 9 Elements in 8 Groups
2 E-HR lenses
Angle of View 27 Degree
AF System High-speed Imager AF(MSC)
Closest Focusing Distance 0.5m
Maximum Image Magnification 0.11x
35mm Equivalent Max. Image Magnification 0.22x
Minimum Field Size 118 x 157 mm
Number of Blades 7 (Circular Aperture Diaphragm)
Maximum Aperture f1.8
Minimum Aperture f22
Filter Size Diameter 37mm
Dimensions Diameter 56 x 46mm
Weight 116g
Box Contents Lens Cap(LC-37B), Lens Rear Cap(LR-2), Decoration Ring(DR-40)
Instruction Manual, Olympus Worldwide Warranty Card
http://www.olympusamerica.com/cpg_section/product.asp?product=1569
