В объективе 3 линзы. Каждая завинчена своим кольцом. До упора. Можно сточить САМ стакан объектива, зная цель и характер улучшения!
Всего 59854 сообщ.
Показаны 33141 - 33160
Re[Tigra Girl]:
Re[Tigra Girl]:
от: Tigra Girl
Do you have any full frame digital camera? Why don't you use it with Buhl and your other rare lens?
Buhl 240mm f2.5 - what that? I can not find this lens.
I do not have the full-frame digital Tiagra Girl. Most of my gears are analog formats up to 8x10 camera. For digital I used to have large formats but I sold most of them and only keeping m4/3 and smaller formats due to compactness and the ability to use small vintage cine lenses/c-mount lenses.
Regarding coverage ability, Buhl lenses and others have large image circle. To make use most of it, you need to have a format that is suitable to take advantage of the thin bokeh. I do not use full-frame on Buhl because it does not allow thin DOF . The only thing that you want to mount large image circle lenses on smaller format is IF the lenses have wonderful bokeh, and Buhl and Hektors lenses have OK but not great bokeh, therefore I have no incentive to mount them on smaller format.
Yes, I have two 240mm f2.5 buhls. They are the fastest among Buhl lenses (250mm doesn't count since it has f-stop of 2.8 or f2.9).
Elgeet Navitar 111mm f1.5
Elgeet Navitar 111mm f/1.5 + 0.72x zhongyi speedbooster + epl5
Lens is 7-element coated . Large coverage up to 4x5 but it is good for medium format. It has identical Aero Ektar bokeh. I like to use it on smaller sensors due to high resolving power and large bokeh size on smaller format. Thinking of mounting it on a 6x4.5 film camera
https://www.flickr.com/photos/124354192@N07/29536717606/in/dateposted/
Re[Renditiont Noit]:
от:Renditiont Noit
https://www.flickr.com/photos/124354192@N07/29536717606/in/dateposted/Подробнее
Artwork. But a little more sharpness, maybe?
от: Renditiont Noit
It looks similar to Delft 105mm f0.75
это выглядит как Delft 105мм f0.75 . Товарищ , вы знаете имя линзы ?
Big russian Триплет 3,65\365. 3 lens. No samples anywere.
I plan to buy this one to test on a full frame Nikon D800e.
Мay I ask: where are you from and what's your name?
Re[Tigra Girl]:
от: Tigra Girl
Optic is pretty decent but I used it on half-frame digital sensor along with 0.72x which degraded its sharpness. Best use on full-frame and medium format, but I love the bokeh .It's main my working lens on m4/3 format , perhaps I should bump post-processing sharpness a little .
от:Tigra Girl
Сan you show a photo of this lens? I've only seen Buhl 229/2.5.Подробнее
Yeah the 240mm f2.5 is pretty rare. You can see how it looks here on my facebook link https://www.facebook.com/rendition.noit/posts/1659400557682100
The coverage for Buhl 229mm and 240mm are 4x5 and 5x7 if you remove the rear. The Hektor design has large coverage and I think the 240mm covers 8x10 but I do not have a proper subject to test it indoor.
от: Tigra Girl
Thanks ! It's a triplet lens , best work for 8x10 format. I have a 340mm f2.4 heliar-type lens somewhere but I can't mount it on 8x10 due to the size and big rear. Most of my 300mm-500mm lenses are mounted on 8x10 camera. I am thinking of building a 16x20 cameras and maybe larger cams due to the lenses I have.
I am an enthusiast lenses enthusiast from Arizona, U.S . Quite a few of us shoot large format and analog here :D . I have been following this thread for a year or two now.
Re[Tigra Girl]:
Buhl 240mm f2.5 + graflex series D + fuji fp3000b negative scan
Buhl 240mm is hektor-design 4-elements in 3 groups. Coverage is 4x5 and 5x7 and 8x10 portrait but I do not test on 8x10 yet.
FOV as 35mm full-frame is 0.32x(240mm f2.5) = 76.8mm f/0.8
https://www.flickr.com/photos/124354192@N07/24785344315/
Pictures of the lens:
https://www.facebook.com/rendition.noit/posts/1671609463127876?comment_tracking=%7B%22tn%22%3A%22O%22%7D
https://www.facebook.com/rendition.noit/posts/1659675267654629
Very good. Thanks.
Re[Tigra Girl]:
крутые снимки
Re[Tigra Girl]:
от:Tigra Girl
Нашел на фликре.
Buhl 200/2.5 на формате 4x5.![]()
Аэроэктар 178/2.5 на формате 4x5.![]()
https://www.flickr.com/photos/sandyphimester/Подробнее
Yes Sandy Phimester is in my special group on Facebook. We are a lot of insane lenses hoarders :D . If you guys want to join also just friend me on Facebook and I'll send you a link
Schneider Gottingen 12cm f2
Schneider Gottingen Xenon 12cm f/2 aerial lens + Pentax 6x7 + m65 helicoid 22-55mm . Reach infinity on 6x7 with adapted helicoid. It shows vignette on 4x5 at infinity , so best use on medium format 6x7 6x7 and 3x4.
For sample picture, lens was shot on pentax 6x7, tri-x 400 ASA, developed in ilfosol-3
https://www.flickr.com/photos/124354192@N07/27353509214/in/dateposted/
Re[Tigra Girl]:
я думаю тут всему виной атмосфера, ч/б-елость, и руки мастера, в цвете оно выглядело бы не так фотогуманно
Re[mpazu]:
чб + бф + стекло.
Re[dimuka]:
Особенно цветные и не на большом формате :)
от: Renditiont Noit
Like this helicoid?
ebay
322010104836
Re[Tigra Girl]:
от: Tigra Girl
Like this helicoid?
ebay
322010104836
Yes that one if you use small lenses. But for faster/heavier lenses it does not work too well. Rather, few of us have already switched to a sturdier and better-built helicoid like this one:
Ebay 252508683434
The most sturdy and best built m65 helicoid is from this seller
