Yongnuo 568EX - вспышка с поддержкой HSS
Всего 891 сообщ. | Показаны 181 - 200
YN-568EX for NIKON ожидается в новом году
вот ответ на мой вопрос о версии Nikon:
Dear Alex,
Thank you for your email.
No confirmed time table yet but should be in 2013.
Wish you a nice weekend!
В ближайшие дни мы точно не увидим YN-568EX for NIKON
Yongnuo YN-568EX FP Sync-enabled flashgun
Вспышка для NIKON уже в продаже!
Я жеж говорил что в выходные все произойдет :))
а мой дилер отдыхает :)))))
цены на ебее от $180
внешний вид в стиле Nikon с золотистыми надписями
Yongnuo YN-568EX for NIKON
пара картинок и описание
Product Information:
The YN568ex flash speedlite is the first High Speed Sync flash of Yongnuo.It is designed for Nikon cameras.
Main Functions:
1. Support HSS (High Speed Sync), Up to 1/8000 second.
HSS works when the flash is on-camera and in slave mode as well.
2. AWL SUPPORTED FOR Nikon’s & Canon’s SYSTEM
Any YN568EX can work as a slave flash in TTL mode as well as M, Multi mode, controlled by above "suitable for" listing..
3. TTL FLASH WITH LARGE GUIDE NUMBER
GN58@ ISO100, 105mm; which reaches the level of the mainstream hot shoe flashes, supports TTL/M/Multi mode.
4. MULTIPLE TRIGGER MODE SUPPORTED
The YN568EX can be triggered by hot-shoe, flash command slave mode, optical S1, and S2(pre-flash-canceled mode).
5. SUPPORTS AUTO/MANUAL ZOOMING
The YN568EX covers a focal length range of auto, and 24 to 105mm, supports full-frame/half-frame camera.
6. COMPREHENSIVELY SUPPORTS TTL FUNCTIONS
FEC, FEB, Rear-curtain sync, FE lock, Modeling Light, Nikon camera menu accessible.
7. 2.5mm JACK PORT PROVIDED
YN568EX provides 2.5mm jack port,you can make the flash synchronously by connecting to the 2.5mm jack port.
8. SOUND PROMPT SYSTEM
Turn on the sound prompt function, different sounds indicate working situations help you focus on shooting.
9. MODELING LIGHT FUNCTION
Press down the camera’s depth-of-fired preview button, the YN568EX will send out continuous flash lasting one second.
10. ADVANCED SETTINGS ON FLASH
The YN568EX supports advanced settings; you can customize the unit according to your shooting preferences.
11. AUTOMATIC SETTINGS SAVING
YN568EX can save the current settings automatically.
12. LCD PANEL USER INTERFACE WITH SUPER GELIVABLE METAL HOT-SHOE STAND
Note: This above content is followed the test form of Yongnuo Company.
The YN-568EX competes not only with Canon 600EX-TX, 580EX II, and the Nikon SB-910, SB-900, but also with other 3rd party flashes in the professional class such as a Metz 58 AF-2, Nissin Di866, and the Sigma EF-610 DG Super. In function it is a flash almost same as the Canon 580EXII. And bewteen the YN-568EX and YN-565EX, the main difference is that the YN-568EX can work in HSS mode while the YN-565EX can't.
Hot-shoe mode support: Nikon D7000 D5100 D5000 D3100 D3000 D800 D700 D300 D300s D200 D90 D80 D70s D70 D60 D40x D40 D3 D3x D3s D2x
Wireless slave mode support:
NIKON:
Commander SU-800
Flash SB-900, SB-800, SB-700
Camera with CLS i-TTL system & AUTO FP: D4, D3x, D3s, D3, D2x, D800, D700, D600, D300s, D300, D200, D7000, D90, D80
CANON:
Commander ST-E2
Flash 580EX II
Camera 7D, 60D, 650D, 600D (без поддержки HSS при запуске с помощью встроенного коммандера)
ПРОБЛЕМА совместимости со тарыми камерами CANON
Сегодня читал обратную связь Yongnuo с пользователями из Китая и узнал следующее:
Оказывается вспышка YN-568EX для Canon до ноября имела проблемы совместимости скорее всего со всеми старыми камерами, не имеющими меню управления вспышками.
.1D, 1DmkII,
.5D
.10D, 20D, 30D
.300D D-Rebel, 350D XT, 400D XTi
Oднозначно, проблемы были у 20D, 30D, 5D, 1DmkII.
Эти четыре модели тестировались в Yongnuo, но думаю, что проблема была общая для всех старых камер без меню управления вспышками и по всей видимости проблема решена для всех остальных камер тоже.
источник: http://www.shanzhuoboshi.com/blog/2012/10/28/25382.html (язык китайский)
Большой тест YN-568EX и YN-560EX сделан в Китае
Большой тест YN-568EX и YN-560EX сделанный китайским сайтом STROBIST
http://www.shanzhuoboshi.com/blog/2012/10/12/25022.html (язык китайский)
Re[Chipp]:
Ну что , никто еще новых вспышек для Canon не получал? Интересно как они, подсветку подправили?
Re[DJUM]:
от: DJUM
Ituner давно её разобрал по косточкам и рассписал уже здеся
Re[Chipp]:
Под новыми вспышками я имею ввиду исправленные партии появившиеся после 10 ноября этого года. Что касается подсветки, я НИГДЕ не видел решилась ли эта проблема.
Еще хотелось бы получить совет на что обращать внимание и как вообще проверить эту вспышку при получении на почте. Буду рад советам)))
Re[DJUM]:
от:DJUM
Вспышка упакована так, что подозрения на повреждения возникнут лишь если сильно пострадала оригинальная коробка.
Если коробка цела, то вспышка уж и подавно :)
Все обновленные продукты в последнее время выходят с начала месяца, чтобы их легче было отслеживать дилерам. Имено дилеры занимаются статистикой и послепродажным обслуживанием.
Исправленные 568-е пошли с конвейера с 1 ноября, продажи начались уже на следующий день у самых ушлых дилеров :)
Заводская наклейка с датой, являющаяся еще и пломбой. содержит только год и месяц.
Наклейку можно найти на корпусе повернув головку на 90 градусов.
На ней должны быть зачеркнуты 12 и 11 как здесь 12 и 8
про подсветку не скажу
не в курсе и мне оно не надо. у меня на камере вспышка редкий гость, там 622-й обычно :)
Re[Chipp]:
Скажите, а на самом фотоаппарате как проверить? в какой режим загнать? че тестить?
Re[DJUM]:
от: DJUM
Вы что ли не читали тему? :)
Всего то 10 страниц.
Есть мое сообщение с картинками и указанием настроек :)
Точно такое же мое сообщение на англоязычном ресурсе где впервые была зафиксирована эта проблема
http://photography-on-the.net/forum/showthread.php?t=1220090
Не поленитесь, почитайте тему.
Здесь вы найдете много полезной информации, которой не найти в мануале.
А на почте вы только за механические повреждения сможете попытаться что то поиметь :)
Там тестить бесполезно :)
Re[Chipp]:
Приехали мне выпущенные в ноябре YN568EX.
Невероятно порадовали вложенные в каждую коробку рассеиватели — белые колпачки.
В ближайшее время постараюсь надыбать 7D, чтобы проверить, решили ли проблему.
Re[Павел Ветер]:
от:Павел Ветер
Колпачки специальные или все еще от 580-й? :)
Если у Вас срастется с тестом, то было бы замечательно увидеть подтверждение в фотографиях :)
Re[Chipp]:
ток не сильно камнями бросайте)))... Возможно ли не выключая пыху (она в башмаке фотика стоит) сделать снимок без нее? или ее только выключать необходимо? ситуация когда нужно сделать кадр с пыхой и без.
Re[DJUM]:
на многих фотиках есть под пальцами между держалкой и обьективом по кнопке
Fn и кнопка репетитора диафрагмы.Их можно програмировать на разные функции.И одна из таких можно задать срабатывание без вспышки. Она действует как на встроенную так и на накамерную.Поищите может и на вашем есть такая волшебная кнопка
Re[Chipp]:
Фотик Canon 600D. Спасибо буду искать. Кстати, так инструкция на эту вспышку и не появилась?
Re[DJUM]:
от: DJUM
на вашей камере проблемы с пересветом и несовместимостью быть не может, даже на неисправленной вспышке :)
но тему прочитайте :)
инструкции в электронном виде в сетке нет до сих пор. даже на сайтах YN
Re[Chipp]:
Жесть, нигде не могу найти как задать срабатывание без вспышки? Люди у кого 600D подскажите???)))
Re[DJUM]:
от: DJUM
начните с инструкции к камере
с первой страницы :)
Re[ituner]:
:) да... да :D
