New firmware update 1.2 for Nikon Coolpix P7000
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/50723
* Autofocus performance has been increased for more reliable focus acquisition on the intended subject, reducing the number of cases in which focus on the subject was not acquired or focus was acquired on the background when the shutter-release button was pressed halfway.
* Auto bracketing and the self timer can now be enabled at the same time.
* Aperture settings at or near maximum aperture were grayed out and apparently unavailable for selection (selection was actually possible) when the following procedure was performed. This issue has been resolved.
1. An aperture value other than maximum aperture was applied with shooting in [A] (aperture-priority auto) mode.
2. The camera was turned off .
3. The camera was turned on again.
4. The user attempted to adjust the aperture setting (aperture settings at or near maximum aperture grayed out).
* An issue that prevented operation of the specified function when the shutter-release button was pressed while theFn (function) button was held down in [M] (manual) mode has been resolved.
* An issue that in some rare cases caused inaccurate shutter speed display in [M] (manual) mode has been resolved.
* An issue that caused an asterisk (*) to be displayed, and continue to be displayed even when settings were reverted to their default values, next to the Vivid Picture Control (COOLPIX Picture Control) option when User Setting U3 was enabled has been resolved.
* The results of adjustments to White balance>Choose color temp. using the P7000's NRW (RAW) processingfunction on NRW (RAW) images were the opposite of those achieved with adjustment of NEF (RAW) images captured with Nikon digital-SLR cameras (higher settings resulted in bluer images while lower settings resulted in redder images). P7000 settings have been reversed for operation and results similar to that of D-SLR cameras.
* An issue that in some extremely rare cases caused NRW (RAW) images to become completely black with editing using the camera's NRW (RAW) processing function or with RAW processing using ViewNX 2 has been resolved.
* An issue that caused borders and outlines in images to appear rough with playback on an HDTV when the camera was connected to the TV via an HDMI cable has been resolved.
Read more on NikonRumors.com: http://nikonrumors.com/2011/12/06/new-firmware-update-1-2-for-nikon-coolpix-p7000.aspx/#ixzz1flcGzNVh
встречаем Nikon P7000 [mod]
Всего 806 сообщ.
Показаны 481 - 500
Re[www user]:
Re[ATAMAH]:
В работу автофокуса увеличено для более надежного приобретения сосредоточиться на предмет предназначен, уменьшение числа случаев, когда фокус на объекте, не приобрел или фокус был приобретен на фоне, когда спусковая кнопка нажата наполовину.
Брекетинг Авто-таймер теперь может быть включен в то же время.
Диафрагмы или вблизи максимальной диафрагме были неактивны и, видимо, недоступен для выбора (выбор на самом деле это возможно), когда следующая процедура была выполнена. Эта проблема была решена.
1. Диафрагмы, кроме максимальной диафрагме была применена со стрельбой в [] (приоритета диафрагмы) режиме.
2. Камера была выключена.
3. Камера была включена снова.
4. Пользователь попытался настроить диафрагмы (диафрагмы или вблизи максимальной диафрагме серым цветом).
Ошибка, препятствовавшая работе указанной функции, когда спусковая кнопка была нажата в то время как Fn (функция) кнопка была нажата в [M] (ручной режим) была решена.
Вопрос, что в некоторых редких случаях, вызванных неточной дисплей выдержки в [M] (ручной режим) была решена.
Вопрос, который вызвал звездочкой (*), которое будет отображаться, и по-прежнему отображается даже если настройки были возвращены к значениям по умолчанию, рядом с Vivid управления снимками (COOLPIX Picture Control) вариант, когда пользовательских настроек U3 была включена была решена.
Результаты корректировки баланса белого> Выберите цвет темп. использованием NRW P7000 (в RAW) функции обработки на NRW (RAW) изображений были противоположны тем, достигнутые с регулировкой в ​​формате NEF (RAW) изображений, полученных с Nikon цифровых зеркальных камер (более высокие значения в результате синее изображения при низких настройках в результате краснее изображений ). P7000 настройки были отменены для работы и результаты похож на D-SLR камер.
Вопрос, что в некоторых крайне редких случаев, вызванных NRW (RAW) изображений, чтобы стать полностью черным с редактированием использованием NRW камеры (RAW), функции обработки RAW или с использованием обработки ViewNX 2 была решена.
Вопрос, который вызвал границы и контуры на изображении появляются грубые с воспроизведением на экране телевизора, когда камера была подключена к телевизору через кабель HDMI, был решен. :D :D :D это автоматический перевод,сорри :D
Re[www user]:
Обновил...действительно фокусировка стала лучше...остальное еще не проверял. Тут проверяю обновку (хотя это одно и тоже, что ссылки выше) https://nikoneurope-ru.custhelp.com/app/answers/detail/a_id/50778
Re[www user]:
Люди! подскажите пожалуйста, как в Р7000 сделать ручную настройку Макро?...никак не получается!
Re[AnKo]:
Все описано в инструкции стр. 42 "Использование ручной фокусировки".
Re[ingval]:
фокусировка после новой прошивки-супер!!!
Re[www user]:
Доброго времени суток.
Еще одним пользователем Nikon P7000 стало больше. :)
Re[www user]:
Подскажите пожалуйста, а файл для прошивки можно записывать на любую карту памяти или обязательно на ту, которая используется в фотоаппарате?
Re[Oberst]:
А чем конкретно фокусировка стала лучше после новой прошивки?
Re[AnKo]:
Если есть другая карта памяти можно и на нее...это не принципиально...главное как в инструкции написано сделать...с новой прошивкой фокусировка стала лучше цеплять, а особенно когда недостаточно света...а еще ББ стал нормальным (снег стал "белым", а не синим как небо).
Re[Nicolos_koch]:
от: Nicolos_koch
ну славу богу,значит не зря мне никон деньги платит...
Re[Oberst]:
А вот после перепрошивки камера с гарантии не слетит???
Re[AnKo]:
от: AnKoс какого перепугу?это же официальная прошивка никона на официальном сайте
Re[Oberst]:
от: Oberst
Я позвонил в гарантийный сервис-центр, там сказали, что эта процедура проводится только в официальных сервисных центрах, куда аппарат нужно сдавать от 3-7 дней (ХА!)...и что самовольное проникновение в "мозги" - автоматом слетается с гарантии каким-либо официальным ни была бы прошивка...я вот тут прочитал в паспорте и сервисной книжке про прошивку и там стояли прочерки...рискнуть и прошить самому?
Re[AnKo]:
весь цивилизованный мир перепрошивку делает самостоятельно и только отдельные сервисы центры на этой процедуре хотят срубить бабло
Re[Oberst]:
от: Oberst
ОК! сегодня-завтра буду кумекать с прошивкой...спасибо за поддержку, а то я уже было подрастроился как-то.
Re[AnKo]:
на сайте есть подробные пошаговые инструкции,следуйте им и будет вам счастье :smile2:
Re[www user]:
Тоже свой перепрошил. Никакой особой разницы не заметил, если честно. :)
Re[Fet47]:
фотографировать пробовали?
Re[Oberst]:
Да, припоминаю, было что-то такое. :) При неудачном освещении бывают такие же проблемы с автофокусом на малоконтрастных предметах, как бывали и до того, на нулевой прошивке. И такая же волшебная надпись "ждите" на экране при удалении одного жалкого жипега. Может, с новой прошивкой есть какая-то разница в миллисекундах по времени висения этой надписи на экране, но не могу сказать, что она для меня существенна.
