Короче говоря, торгаш пишет, что экспонометр показывает всегда восьмерки. Ссылается на то, что батарейка у него стоит просроченная 2004 года, а новой у него нет. Стоит мне оплачивать лот или нет?
Срочно нужна помощь знатаков!
Here's a VERY Nice 'SOLIGOR' Digital Spot Sensor! This Meter appears to be in EXCELLENT condition. The battery is held in w/tape, so you might want to replace the door (seems to work fine as it is) and there might be a problem with the readout. Using the installed battery - which shows an 'expiration' date of 2004 - the red LED readout lights up, but show all 8's. I'm not sure if this is some sort of error code, or it's possible this needs to be re-set, but it seems to be OK-? I don't know enough about these to be sure - maybe someone out there can provide some info/help.
