В Штатах DPP 3.0 дают
На штатовском сервере начали давать DPP 3.0 (на Европейском еще нет).
Наконец то додумались до индивидуальной установки шумодава для каждой картинки и групповых изменений параметров...
Список изменений по сравнению с 2.2
1. Changes from Digital Photo Professional 2.2
Added functions
1-1. Support added for Windows Vista.
1-2. Support was added for EOS-1D Mark III.
1-3. Support added for single-image display for RAW+JPEG images. (*)
The edited content is applied only to RAW images. File moving, copying, or deleting applies to both the RAW image and the JPEG image. Single image display is only used with CR2-type RAW and JPEG images that were shot simultaneously. (The images used with TIFF-type RAW and JPEG images can not be displayed as a single image).
1-4. Enabled thumbnail image rearranging using drag & drop.
1-5. Enabled a frame display in trimmed images in main window or edit image window.
1-6. Added multi-image synchronizing function in edit window.
1-7. Supported multi-page printing in detailed setting printing.
1-8. Enabled a Color Management settings window call function in the detailed setting printing window.
1-9. Enabled images trimmed in DPP to print as trimmed images when they are printed using Easy-PhotoPrint, Easy-PhotoPrint Pro.
1-10. The GPS data can be displayed with other shooting information when the GPS data is added to it.
Changed Functions
1-11. Brought together as collective image adjustments in the tool palette in the main window. Added a noise reduction tab, and allowed noise reduction to be applied to individual images.
1-12. Changed the display method of trimmed images in edit window, edit image window. Images trimmed in DPP are now printed as trimmed images.
1-13. Improved the speed for displaying RAW images in edit window.
1-14. Support added for new Picture Style files. (.pf2)
The extension for the Picture Style files has been changed from ".pse" to ".pf2" Please download the files again. The effect of the files has not been changed.
Modified Functions
1-15. When selecting the detailed setting printing and contact sheet printing, the printing result could become completely white (or in some cases, completely black). But this has been corrected.
Re[Sergey Kan]:
не могу скачать!!!
ссылку не дадите???
Re[solsol]:
http://www.usa.canon.com/consumer/controller?act=DownloadDetailAct&fcategoryid=314&modelid=10464
Дальше раздел Software.
Re[Андрей Якубовский]:
Почему качается файл DPP30UPD_EN.exe размером ~24,5 Mb, когда там написано 44,1 Mb ?
Re[Kaktus]:
от: Kaktus
- наверное не исправили размер и от DPP22UPD_EN.exe остался - тот как раз был 44,1 МБ (46 320 328 байт)
Re[МБ]:
Понял, спасибо.
Re[Kaktus]:
от: Kaktus
Это апдейт(обновление) предыдущей версии.
Накатил сверху на DPP v2.2.0.1, встала нормально,- сейчас в Version information пишет Digital Photo Professional Version 3.0.0.3,будем осваивать.
Re[gregori]:
от: gregori
от:Kaktus
1) хоть это и называется Update, реально это полная версия и установленная предыдущая версия DPP в обязательном порядке не требуется. Требуется лишь наличие хотя бы одной из программ из списка:
[quot]Please make sure that at least one of the following applications is installed in your computer before downloading Digital Photo Professional 3.0 Updater for Windows.
- File Viewer Utility
- EOS Viewer Utility
- Digital Photo Professional
- RAW Image Task
[/quot] Фактически при установке выполняется просто проверка наличия одной из этих программ, как подтверждение того, что вами уже было куплено что-то, комплектуемое Кэноновским CD EOS Digital Solution Disk. Например, я снес предыдущий DPP 2 и DPP3.0.0.3 прекрасно встал без него (т.к. у меня остался ZB).
2) размер загружаемого файла указывают именно для того, чтобы знать, во что обойдется загрузка в смысле времени и денег и чтобы оценить, весь ли файл загрузился, поэтому указывать должны именно загружаемый объем, без учета того, обновление это или нет.
Re[МБ]:
предыдущая версия не стоит иду по ссылке пустое окно!!!! - что делать????
Re[solsol]:
Подождать, пока страница загрузится, а потом нажать на ссылку Software.
После этого опять подождать :D и выбрать из появляющегося списка нужное ПО.
Re[solsol]:
от: solsol
А загранпаспорт и виза есть? :?:
Re[solsol]:
от: solsol
проверить, разрешен ли джава-скрипт и поп-апы. Должна быть такая страница:
- давить Drivers/Software, в отдельном окне (том самом поп-апе) откроется окно со списком софта, где и будет DPP - после его выбора принимаем лицензионное соглашение, появится страница с инструкциями по загрузке и установке, сама загрузочная ссылка - почти внизу:
[quot]Download
DPP30UPD_EN.exe [/quot]
(ниже - загрузка руководства по DPP)
Re[Sergey Kan]:
Зашибись. Супер программа. Главное, с цветом изящно работает. Точней, дивно его отображает.
Re[Сергей Иванов]:
на вашей картинке желтого много :-)
Re[V.S.K.]:
от: V.S.K.
Да при чем тут - желтый?! Цвет в Preview и Photosop один, а в DPP - другой!
Re[Сергей Иванов]:
Эка невидаль! А подсунуть всем просмотровщика и редакторам один профиль монитора не пробовали? Кстати на первой картинке, у Вас там сравнивается цвет ТИФФа с цветом РАВа...
Re[Михаил Р.]:
Гм.. мне кажется, Михаил, Вы не совсем поняли суть вопроса. Тифф-то сделан из того самого РАВа. То есть - в окне программы обработки - цвет совсем не тот. Например, в Апертуре цвет РАВа - ,и в Превью, сделанного из него ТИФа - идентичен. А тут - нет. Следовательно, ориентироваться визуально - нельзя. Что касается профилей - везде стоит sRGB.
Это - чтоб понятно было - о чем идет речь. Здесь приведено окно Апертуры. Расхождение цвета есть, но ничтожно малое - которым можно в практической работе пренебречь. Это укладывается в предел ошибки в типографии с запасом.
Причем, в Апертуре - коррекция делалась лишь по экспозиции и контрасту. Цвет - по умолчанию.
А вот, еще раз "шедевр" - от Кэнона.
Они явно, издеваются. Даже для любительской съемки - перебор.
Может - и можно это поправить... приеду вечером со съемок - повожусь с профилями... но ведь приведенные мною настройки - это то, что по умолчанию..
Re[Сергей Иванов]:
Вы хотите сказать, что при работе в DPP цвета одни, а после перевода в Tiff и открытии в других программах в том жe sRGB, другие?
А то эмоции есть, а перевода нет.
Re[Сергей Иванов]:
от: Сергей Иванов
А чего во всех файлах прописано "Color LCD калиброванный" :)
Re[Сергей Иванов]:
Вы с профилями сами разберитесь сначала, у Вас Preview (судя по всем) использует "Color LCD Калиброванный", так почему же в DPP выбран sRGB? И сравнивать надо не RAW с TIFF, а TIFF в Preview и тот же TIFF в DPP.
