TS-стекла
TS-стекла
Кто-нибудь имел с ними дело?
Каковы вообще пределы сдвига\поворота?Большой диапазон?
Ясное дело,что не кардан,но все же :(
Re[ToRRenT]:
Тема обсуждалась, например, тут Тема: Canon TS-E 45 мм f/2.8
Ну, есть у меня TS... что конкретно-то интересует?
Не уверен, что ссылка получилась, поэтому выдержки...
Кстати, это не реклама, а просто информация… у них же на сайте есть вполне подробное описание как работют TS-линзы…
вот полная ссылка http://www.araxfoto.com/specials/tilt-shift-35/
а вот текст:
MC ARAX 35mm Tilt & Shift lens
- MC ARAX 35mm Tilt & Shift lens Review
- Picture gallery-1
- Picture gallery-2
- How Shift Lenses Change your Life
This multicoated ARAX 35 mm Tilt/Shift compact lens has a high quality precision CANON type T&S mechanism. 11mm shifting, 8 mm tilting and 360o rotating capabilities enable you to correct perspective distortions, as is often required in interior and exterior architectural, landscape and product photography. The effects possible with large-format camera movements can now also be obtained for 35mm cameras through these TS ARAX lenses..
The excellent multicoated optics of this lens allows you to make sharp, contrasty, and colour perfect images. Of course it has a manual aperture control. The lens can be shifted by 11mm from its normal position. The direction of the shift can be rotated by 360o and locks at 12 angular positions.
This lens was never made at the ARSENAL factory. It is produced by ARAX from MC ARSAT 35mm Shift lenses. We are the OEM for lenses distributed under different brands for other companies. You can find them as ARSAT, BIG, FOTEX, PHOTEX, etc. All of these lenses are manufactured by ARAX technicians.
You can use this lens on any 35mm digital or film cameras.
Comes with protective caps and case.
Specifications
* Lens elements: 11 Multicoated
* Focal length: 35mm
* Focusing scale: 0.3 m to infinity
* Minimum focusing distance: 0.3 m
* Aperture scale: f2.8 to f22
* Shift: 11mm
* Tilt: plus/minus 8o
* Lens rotate: 360o
Available with different mounts for:
* Nikon AI (upgraded to fit on ...D70, D100, D200)
* Canon EOS
* Canon FD
* Minolta Dynax
* Minolta MD
* Pentax K
* M42 (Zenit, Practica, etc.)
* Contax
* Yashica
* Leica R
There are no adapters, since we manufacture each lens with a specific mount.
Use the lens with the appropriate mount for your camera, without any additional adapters!
Re[ToRRenT]:
Обычно наклон в пределах 7-9° и сдвиг в предлах полукадра.
