Tamron 18-270mm f/3.5-6.3 Di II VC PZD
Новинка! Начало продаж 20 декабря 2010!
The Tamron 18-270mm f/3.5-6.3 Di II VC PZD lens was supposed to be announced at Photokina but it was delayed in the last moment. As previously rumors indicated, the lens is much smaller than its predecessor (the new version is on the left).
The price is $649 and it will be available for Nikon and Canon mounts on December 20th, 2010 (in Japan). A Sony version of the lens will be released at a later date.
Full details after the break:
The new lens features a Piezo Drive (PZD):
Ultrasonic motors are divided into two categories depending on the principle that generates the energy to move the drive: traveling wave motors and standing wave motors. Traveling wave motors include the ring type ultrasonic motor used in the recently launched 70-300mm F/4-5.6 VC USD as well as other lenses, but this lens employs a newer technology, the PZD (Piezo Drive), which functions on the standing wave principle.
A standing wave ultrasonic motor utilizes high-frequency voltage to extend and turn the piezoelectric (piezoceramic) element, thus moving the entire element in a standing wave movement. The metal tip is the contact point of the element to the rotor, and moves in an elliptic motion from the swiveling motion of the moving element, and the friction from this motion turns the rotor. Standing wave ultrasonic motors have the distinct advantage of being smaller than their traveling wave counterparts, and therefore allow a more compact SLR lens size.
New VC mechanism (moving coil method)”
Tamron’s original VC image stabilization mechanism utilized a moving magnet system whereby a heavy magnet was positioned near the moving VC lens element. In the new VC unit the positions of the magnet and the coil are reversed, because of this the VC optical lens element is attached to the coil. The new VC mechanism employs a moving coil mechanism with a lightweight coil, and the lighter coil reduces the load on the drive system. Thus, the lighter, more compact new VC unit contributes to the lens’s overall light weight and compact size.
Specifications:
Model B008
Focal length 18-270mm
Maximum aperture F/3.5-6.3
Angle of view (diagonal) 75° 33′-5° 55′
Lens construction 16 elements, 13 groups
Minimum focus distance 0.49m (19.3 in)
Maximum magnification ratio 1:3.8 (at f = 270mm: MFD 0.49m)
Filter size φ62mm
Length 88mm¹, ² (3.5 in)
Entire Length 96.4mm¹, ³ (3.8 in)
Diameter φ74.4mm (2.9 in)
Weight 450g¹ (15.9 oz)
No. of diaphragm blades 7
Minimum aperture F/22-40
Standard accessories Flower-shaped lens hood
Compatible mounts Canon, Nikon, Sony
2) TAMRON ANNOUNCES 60TH ANNIVERSARY MODEL 18-270MM Di II VC PZD — THE WORLD’S LIGHTEST, SMALLEST 15X ZOOM , WITH TAMRON’S FIRST PZD (PIEZO DRIVE) AF SYSTEM
A light, compact, ultra-high-power 15x zoom lens with PZD (Piezo Drive) the first Piezoelectric internal autofocus motor by Tamron exclusively for digital SLR cameras with APS-C(3) sized sensors.
December 9, 2010, 2:00am EST, Commack, NY — Tamron Co., Ltd., a leading manufacturer of optical equipment, announced the release of yet another groundbreaking lens: the world’s most compact, lightweight lens with a 15x zoom ratio*1, featuring a 62mm filter diameter, VC (Vibration Compensation) image stabilization and Tamron’s first standing wave ultrasonic motor system for SLR lenses, PZD (Piezo Drive) *2. The 18-270mm F/3.5-6.3 Di II*3 VC PZD (Model B008) DSLR ultra-high-power zoom lens for Canon and Nikon mounts will be released December 20, 2010, with the development of a Sony*4 compatible mount at a later date. This is the second lens released to commemorate Tamron Co., Ltd.'s 60th anniversary. The SP AF70-300mm Di VC USD best-in-class telephoto zoom was released this summer.
The 18-270mm Di II VC PZD is an astonishingly light, compact ultra-high-power zoom lens with a filter diameter of Ø62mm. Weighing in at 15.9oz., this new all-in-one zoom lens is equipped with an AF unit driven by Tamron’s new PZD (Piezo Drive), an ultrasonic motor that delivers faster and quieter focusing when the autofocus is engaged.
The 18-270mm Di II VC PZD is easy to use and highly portable – a high-power zoom that will offer the user the versatility to shoot in a variety of situations. Its wide zoom range of 18-270mm positions the lens as an all-purpose workhorse for any photographic situation.
Compact and Easy to Carry 15X All-in-One Zoom with Outstanding Feature Set
The 18-270mm Di II VC PZD boasts the world’s highest zoom range at 15x magnification for a lens with its compact size and light weight, with the added value of Tamron’s proprietary VC (Vibration Compensation) image stabilization. At 15.9 ounces, measuring 3.8 inches in length (from mount face to the tip of the lens), and 2.9 inches in diameter with a filter diameter of Ø62mm, it’s a compact and easy-to-carry lens. A minimum focusing distance of 19.3 inches throughout the zoom range and a maximum magnification ratio of 1:3.8.
Tamron’s new PZD (Piezo Drive) autofocus technology delivers silent, high-speed autofocus in a compact lens
Ultrasonic motors are divided into two categories depending on the principle that generates the energy to move the drive: traveling wave motors and standing wave motors. Traveling wave motors include the ring-type ultrasonic motor used in the recently launched SP 70-300mm VC USD as well as other lenses, but this lens employs a newer technology, the PZD (Piezo Drive), which functions on the standing wave principle.
A standing wave ultrasonic motor utilizes high-frequency voltage to extend and turn the Piezoelectric (Piezoceramic) element, thus moving the entire element in a standing wave movement. The metal tip is the contact point of the element to the rotor, and moves in an elliptic motion from the swiveling motion of the moving element, and the friction from this motion turns the rotor. Standing wave ultrasonic motors have the distinct advantage of being smaller than their traveling wave counterparts, and therefore allow a more compact SLR lens size.
Tamron’s VC mechanism employs a three-coil system, whereby three driving coils activate the shake-compensating VC lens group electromagnetically via three steel balls. The VC lens elements are held in place only by contact with the steel balls, achieving smooth movement with little friction. This provides a stable viewfinder image with excellent tracking performance that eliminates the blur from handheld shots for cleaner, crisper shots.
New VC Mechanism (Moving Coil Method)
Tamron’s original VC image stabilization mechanism utilized a moving magnet system whereby a heavy magnet was positioned near the moving VC lens element. In the new VC unit, the positions of the magnet and the coil are reversed, and because of this, the VC optical lens element is attached to the coil. The new VC mechanism employs a moving coil mechanism with a lightweight coil, and the lighter coil reduces the load on the drive system. Thus, the lighter, more compact new VC unit contributes to the lens’s overall light weight and compact size.
Notice of Classification Code Change for Nikon Mounts
Since the introduction by Tamron of the first Nikon mount lens featuring a Built-in AF motor (AF28-300mm F/3.5-6.3 XR Di VC Model A20) all Tamron Nikon mount lenses with the Built-in AF motor had a model number designation of “NII.” Lenses using a coupler system without a Built-in AF motor are currently designated as “N.”*5 As future Tamron lens introductions for Nikon mount will have the Built-in AF motor as a standard feature, Tamron has decided to simplify the designation and consolidate all Nikon mount lenses as “N,” eliminating the “NII” designation for future models. This model designation change will be effective with the 18-270mm F/3.5-6.3 Di II VC PZD (Model B008) introduction.
About TAMRON Co., Ltd.
‘New Eyes for Industry’ is Tamron’s slogan, as they are a comprehensive manufacturer of a wide range of original optical products, from interchangeable lenses for SLR cameras to various optical devices for both the general consumer and OEMs. Tamron makes optical products that contribute to a range of different industries. As a leading manufacturer of optical devices, Tamron will continue to exercise its rich creativity and leading-edge technical prowess to make advances into various industrial fields.
Optical Product Line-up:
Interchangeable lenses for SLR cameras, digital camera lenses, video camera lenses, CCTV camera lenses, lenses for cell phones cameras, ultra-precision optical components, etc.
Tamron is aware of their environmental responsibilities and aspires to preserve the environment in all business activities.
*1For SLR high-zoom-ratio lenses with 15x magnification capability. Current as of December 2010. (Source: Tamron).
*2 PZD (Piezo Drive) is a standing wave ultrasonic motor system developed by Tamron. The motor is faster and quieter than DC motors when the AF drive is operated, and compared with ring-type ultrasonic motors, it has an actuator that facilitates lens design and reduced size.
*3 Di II (Digitally Integrated Design): Di II lenses provide an optimized optical design for exclusive use with DSLRs with APS-C size sensors. Di II lenses cannot be used with DSLRs with an image sensor larger than APS-C size, or with 35mm film SLR cameras.
*4The Sony mount version is not equipped with the VC mechanism as the bodies of Sony’s DSLRs have a built-in image stabilization function. Consequently, the Sony mount version is referred to as 18-270mm F/3.5-6.3 Di II PZD and does not include the VC designation.
*5Coupler system refers to a system that uses a shaft to harness the AF motor built into the camera body to operate the lens. The “N” classification lenses with coupler systems are: AF 55-200mm F/4-5.6 Di II (Model A15); AF28-300mm F/3.5-6.3 XR Di (Model A061); SP AF200-500mm F/5.6-6.3 Di (Model A08); and SP AF180mm F/3.5 Di (Model B01).
Tamron 18-270mm F/3.5-6.3 Di II VC PZD specifications
Angle of view 75°33’ - 5°55’
Maximum aperture F3.5-6.3
Minimum aperture F22-40
Lens Construction • 16 elements/13 groups
Number of diaphragm blades 7
Minimum focus 0.49m
Maximum magnification ratio 1:3.8 (at f=270mm, MFD 0.49m)
AF motor type Piezo Drive (PZD)
Image stabilization Yes
Filter thread 62mm
Supplied accessories • Front and rear caps
• Flower-Shaped lens hood
Weight 450 g (15.9 oz)
Dimensions 74.4 mm diameter x 88 mm length
(2.9 x 3.5 in)
Lens Mount Canon EF, Nikon F, Sony A
Image sample: 39mm (equivalent to 60mm), f/5.6, 1/3200, ISO500, WB: daylight, handheld:
1. http://photorumors.com/2010/12/09/tamron-18-270mm-f3-5-6-3-di-ii-vc-pzd-released/
2. http://www.dpreview.com/news/1012/10120905tamron18270mmpzd.asp
Re[ATAMAH]:
PZD- это как по русски- хороший или плохой?(...датый или ...довый) переводится???
Re[Zloalex]:
от: Zloalex
Поидее должен быть PZDатый! :cannabis:
Re[ATAMAH]:
Ё! Тамрону +мильён за такое название на Российском рынке!!! Это мощнейший маркетинговый ход в России!!!!
Re[ATAMAH]:
Особенно, когда объектив этой самой PZD накроется....
Re[suzom]:
Дык о чём речь! И отказ гарантии в ремонте: накрытие PZDой гарантийным случаем не является. Эротику также снимать воспрещается ввиду крайне высокой чувствительности данного объектива к PZDe.
Re[Zloalex]:
Также, этот объектив скорее всего является последним в линейке Тамронов судя по индексу VCё, PZDец....
Re[ATAMAH]:
от: ATAMAH
.. .. PZD boasts the world’s .. ..
:cannabis:
Re[Zloalex]:
Модераторам- извините за флуд, если режет глаз- потрите. Просто убил выхи на покупку комраду Тамрона 17-50 на никон 3100. Так ничего и не купил. У одного Тамрона в процессе проверки в магазине ОТВАЛИЛАСЬ передняя линза.... Обиделся. Благо при присутствии оформляющего инженера по гарантии. Он очень просил не называть магазин)) Буду брать Сигмо))
Re[ATAMAH]:
Интересно, оптически будет тоже самое или до своего же 18-250 дотянутся?
Re[suzom]:
ну чо, кто уже приобрел и испытал ?
Re[Аццкая_белка]:
от: Аццкая_белка
http://club.foto.ru/camera/model.php?mod_id=2556
