SHOW EXIF
SHOW EXIF
Всем присутствующим,добрый вечер!
Не могу найти -SHOW EXIF-
помогите пожалуйста господа фотографы ,
спасибо
Re[Klaus-Krause]:
от: Klaus-Krause
спасибо
http://www.videozona.ru/software/ShowExif/showexif.asp
Re[Klaus-Krause]:
от: Klaus-Krause
...Не могу найти -SHOW EXIF-
Ловите:
Re[Зиновий]:
Господа, где SHOW EXIF показывает количество отснятых кадров? Здесьhttps://foto.ru/forums/general/cifrovye-zerkalnye-fotoapparaty/359586 утверждали поле Total Number of Shutter Releases. И где такое?
---- Основной раздел ----
Make: Canon
Model: Canon EOS 5D
Strip Offsets: 78464
Orientation: Normal
Strip Byte Counts: 1795358
XResolution: 72,00
YResolution: 72,00
Resolution Unit: Inch
Date Time: 2008:08:29 11:23:26
Exif Offset: 270
Exposure Time: 1/100 sec
FNumber: F2,0
Exposure Program: Shutter priority
ISOSpeed Ratings: 400
Exif Version: "0221"
Date Time Original: 2008:08:29 11:23:26
Date Time Digitized: 2008:08:29 11:23:26
Components Configuration: YCbCr
Shutter Speed Value: 0,0101 sec (1/99)
Aperture Value: F2,0
Exposure Bias Value: 0 EV
Metering Mode: MultiSegment
Flash: On, forced
Focal Length: 50,00 mm
Maker Note: "."
User Comment: Not possible to define
Flash Pix Version: "0100"
Color Space: sRGB
Exif Image Width: 4368
Exif Image Height: 2912
Interoperability Offset: 76044
Focal Plane XResolution: Not possible to define
Focal Plane YResolution: Not possible to define
Focal Plane Resolution Unit: Inch
Image Width: 2496
Image Length: 1664
Custom Rendered: Normal process
Exposure Mode: Auto Exposure
White Balance: Auto
Scene Capture Type: Standard
Type of Image: Canon RAW
Bits Per Pixel: 12
---- Дополнительный раздел ----
Canon PhotoEffect: Custom Settings
Macro Mode: Off
Self Timer: Off (Not Used)
Compression Rate: RAW Data (CR2 Format)
Image Stabilizer: Not possible to define
Flash Mode: External flash
Drive Mode: Single (One-Shot per Touch)
Focus Mode: Manual Focus
Image Size: Large
Easy Shooting Mode: Manual
Contrast: Normal
Saturation: Normal
Sharpness: Not possible to define
Metering Mode: Evaluative
Canon AiAF: Off
ExposureMode: Tv-priority (Mode 'Tv')
Focus Details: Not possible to define
White Balance Preset: Auto
Flash Bias: 0 EV
CCD ISO: 400
Lens Type: 50 mm
Subject Distance: Not possible to define
ImageType: Canon EOS 5D
FirmwareVersion: Firmware Version 1.1.1
OwnerName: +390677653180 Vlad Dorogikh
CameraSerialNumber: 1020709816
Noise Reduction: Not possible to define
Shutter AE Lock Button: AF/AF lock
Mirror Lockup: Disable
Exposure Level: 1/2 stop
AF Assist: On (auto)
AV Shutter Speed: Automatic
AEB Sequence: 0
Shutter Sync: 2nd-curtain sync
Lens AF Button: AF stop
Fill Flash Reduction: Enable
Menu Return: Top
Set Button: Not assigned
Sensor Cleaning: Disable
Superimposed Display: On
Shutter Release w/o CF Card: Disable
Lens Information: Not possible to define
Re[Jimmy]:
Этого поля в экзифах от Кэнона нет - это нестандартное EXIF-поле, которое пишут камеры от Никон.
Стандарт EXIF можно посмотеть тут - http://www.exif.org/Exif2-2.PDF
Можете проверить, например, по первому сэмплу Nikon D60 с dpreview http://dpreview-img.fotki.com/gallery/nikond60_samples/originals/dsc_0157_rb.jpg
---- Main section ----
Make: NIKON CORPORATION
Model: NIKON D60
Orientation: Normal
---- Additional section ----
ISO Speed: 100
Quality: Raw
Focus Mode: AF-A
Fine Tune White Balance: 0, 0
Tone Compensation: Auto
Lens Information: 18 - 55mm F/3.5-5.6 VR
Flash Used: Did Not Fire
AF Type: Dynamic Area
Focus Area: Right
Bracketing Mode: Not Used
Auto Bracket Release: Manual Release
Color Mode: Mode3a
Lighting Type: Natural
Hue Adjustment: 0
Noise Reduction: Off
Total Number of Shutter Releases: 172
Re[МБ]:
Спасибо. Значит Nikon пишет, а Canon нет.
