The new primes are available for Canon EOS M mount, and for all other mirrorless mount types too. B&H Photo is accepting pre-orders
Samyang/Rokinon 50mm f/1.2 at $549
Samyang/Rokinon 21mm f/1.4 at $499
Lens Mount: Canon EF-M, Fujifilm X, Micro Four Thirds, Sony E.
EF-M Mount Lens/APS-C Format
33.6mm (35mm Equivalent)
Aperture Range: f/1.4 to f/22
3 Aspherical Elements, 1 ED Element
Ultra Multi-Coating
Internal Focus; Manual Focus Design
Non-Rotating 58mm Filter Mount
Rounded 9-Blade Diaphragm
Combining a wide-angle perspective with a fast maximum aperture, this 21mm f/1.4 Lens from Rokinon is designed for Canon EF-M mirrorless cameras and provides a 33.6mm equivalent focal length. One extra-low dispersion element and a trio of aspherical elements are incorporated into the lens construction, and help to control aberrations and distortions for increased clarity and sharpness. The bright f/1.4 maximum aperture excels in difficult lighting conditions and also enables greater control over focus placement, which is further complemented by the manual focus design and rounded nine-blade diaphragm to produce a quality of bokeh. Additionally, an Ultra Multi-Coating has also been applied to all lens elements to reduce lens flare and ghosting for increased contrast and color fidelity when working in harsh lighting conditions.
This 21mm f/1.4 lens is designed for APS-C-format Canon EF-M mount mirrorless cameras and provides a 33.6mm equivalent focal length.
Bright f/1.4 maximum aperture is ideal for working in low-light conditions and also offers greater control over your focus position for selective focus applications.
One extra-low dispersion element and three aspherical elements are incorporated within the lens design and help to control chromatic and comatic aberrations, as well as reduce color fringing, for sharper, clearer imagery.
An Ultra Multi-Coating has been applied to all lens elements in order to suppress lens flare and ghosting for increased contrast and color accuracy.
This manual focus lens has a non-rotating 58mm front filter mount to better enable the use of polarizing, graduated ND, and other filter types that require precise positioning. Additionally, its internal focus design maintains the overall length of the lens during use.
Rounded nine-blade diaphragm contributes to a pleasing out-of-focus quality when using selective focus or shallow depth of field techniques.
80mm (35mm Equivalent)
Aperture Range: f/1.2 to f/16
Two Aspherical Elements
Ultra Multi-Coating
Manual Focus Design
Non-Rotating 62mm Filter Mount
A truly fast prime offering a portrait-length perspective, this black 50mm f/1.2 Lens from Rokinon is designed for Canon EF-M mirrorless cameras where it provides an 80mm equivalent focal length. The combination of the long perspective and bright f/1.2 maximum aperture enables extensive control over focus placement, which is further complemented by the manual focus design and rounded nine-blade diaphragm for a smooth bokeh quality. The lens construction incorporates a pair of aspherical elements to minimize chromatic aberrations and distortions for a cleaner, sharper image quality void of color fringing. An Ultra Multi-Coating has also been applied to boost contrast by suppressing lens flare and ghosting.
This 50mm f/1.2 lens is designed for APS-C-format Canon EF-M mount mirrorless cameras and provides an 80mm equivalent focal length.
Bright, fast f/1.2 maximum aperture benefits working in difficult lighting conditions and also avails extensive control over shallow depth of field.
Two aspherical elements help to control chromatic and comatic aberrations in order to achieve greater sharpness and clarity.
This manual focus lens has a non-rotating 62mm front filter mount to better enable the use of polarizing, graduated ND, and other filter types that require precise positioning.
