Прошивка Д700 и галюники (пятницо)...
Перепрошил д700... прошивка 1.01...
Вроде как автоББ "поправился".... у кого-то подобные впечатления были после обновления прошивки?
Или ну ее нафиг - такую траву..? :D
Re[KLM_UA]:
мы пьем только науральный морковный сок!
сегодня тоже прошьюсь и посмотрим
Re[KLM_UA]:
Морковный - это жесть!!!
Походу , изваял ок 30 кадров, в доме, освещение типа "шо попало"...
ИМХО , автоББ покузявее стал.
Наверное , правильная практика - вносить исправления в новые прошивки, не афишируя проблем из-за которых изменения вносились.....
ЗЫ: Резинка тоже самоприклеилась после прошивки.....
Re[KLM_UA]:
Ссыль дадите?
Али я сам поищу)
Потестируем чичас
Re[KLM_UA]:
Аэ...По моему про ББ в описаниях не слова..Хотя очень хотелось бы..
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/26608
[quot]This service provides software for upgrading D700 firmware to v1.01.
The following improvements have been made in version 1.01
- When Custom Setting a4 Focus tracking with lock-on was set to Off in Continuous-servo AF, the lens drive moved gradually without achieving focus. This issue has been resolved.
- When the Speedlight SB-800 was mounted on the camera with flash mode set to Distance-priority manual (GN) mode, and then the exposure meters were reactivated or the camera was turned on, the distance information displayed on the SB-800 changed. This issue has been resolved.
- When the Multi-Power Battery Pack MB-D10 was mounted on the camera and an EN-EL3e battery inserted in the camera but no batteries inserted in the MB-D10, and SB-900 flash mode set to TTL auto flash mode, the flash mode changed to A mode when the exposure meters turned off or were reactivated, or the camera was turned off or on. This issue has been resolved. (This issue has also been resolved with SB-900 firmware Ver. 5.02.)
- An issue that, in extremely rare cases, resulted in noticeable black dots in images captured with Long exp. NR in the shooting menu set to On has been resolved.
- Manamah, displayed in the Time zone options for the World time item in the setup menu, has been changed to Manama.[/quot]
Перевод на русский :
http://photogenius.ru/firmware/5144/
[quot]Nikon D700: обновление прошивки до версии 1.01
В данной версии внутрикамерного программного обеспечения:
При установке для собственных настроек «Следящ. АФ a4 с функц. Lock-On» значения «Выкл.» в режиме непрерывного следящего АФ привод объектива постепенно двигался, не фокусируясь при этом. Эта ошибка исправлена.
При установке на фотокамере вспышки SB-800 с выбором режима ручной вспышки с приоритетом расстояния (ведущее число) и последующим включением экспонометра или камеры, информация о расстоянии, отображаемая на дисплее вспышки SB-800, изменялась. Эта ошибка исправлена.
Когда универсальный батарейный блок MB-D10 устанавливался в фотокамеру, а батарея EN-EL3e вставлялась в фотокамеру, но в MB-D10 не было батареи, и режим вспышки SB-900 был установлен в режим автоматической вспышки TTL, режим вспышки изменялся на режим А, когда экспонометр выключался или включался снова, или включалась либо выключалась фотокамера. Эта проблема устранена. (Эта ошибка также исправлена для прошивки SB-900 версии 5.02.)
Проблема, возникающая крайне редко и заключающаяся в видимых черных точках на изображениях, снятых с опцией «Подавление шума для длинных. выдержек» установленной в позицию «Вкл.» в меню съемки, устранена.
Пункт «Manamah»,отображаемое в параметрах часового пояса для пункта «Часовые пояса мира» в меню настройки, изменено на «Manama»[/quot]
Re[NesteR]:
В описании ни слова, да.
Но автоББ с тараканами на Д700 как бы не мог остаться незамеченным изготовителем.
А признать существование - не по "пацански" , чай не Кэнон.. :D :D
Кроме того, та проблема, исправление которой указано в новой прошивке, как бы сказать...ее существование стало новостью для большинства пользователей Д700 :D :D :D
Ну не стали бы так упираццо ради практически незаметной ошибки , не затронув исправление видимой.
Ради чего-то эту прошивку делали? :?:
Ну и кроме того - это практикуемый ход, "скрытое исправление ошибок"
ЗЫ: Тутачки пробегал некий ЧКФР , каковой и упомянул на ссылу на некий ресурс, где факт скрытого исправления некоторых "неровностей" в прошивке Д700 был признан и обсосан....
Собственно , ради этого и прошивался заново.
Re[NesteR]:
Бубль..
Re[KLM_UA]:
Никогда не замечал казусов с ББ ни на 1.0 ни на 1.1 :D Это камерный джпег кривой, а ББ практически идеален (в С1)
Re[NesteR]:
Непростая прошивка
Коллега SilentRed ghjibkcz прошился, и тут же...удумал Пятачки в водке топить ( о чем и тему завел)....
Ох!
Re[KLM_UA]:
Прошивка уже давным давно вышла, а вы только вспомнили...
Re[frAme]:
Ну только потому и вспомнил, что инфа такая проскочила. Я как правило, не сильно спешу менять прошивки на очередные версии без особой на то мотивации. Что в смартфонах, что в компе, что в фотоаппарате.....
Re[KLM_UA]:
ну как в итоге? с лампами накаливания подружились мозги с новой прошивокой?
Раньше авто бб имел предел в 3000 к,а лампа накаливания в среднем дает ~2700к
на новой прошивке в авто бб таки опускается ниже 3000 к?
Re[NesteR]:
Никогда не задумывался в плане именно цифрового выражения.... Хотя в С1 практически во всех снимках снятых дома при эл.освещении выставляю 2650..
Как проверить в цифре, что именно дает автоББ?
Попробую.....
Re[KLM_UA]:
ну можно тупо снять рав с авто бб,а потом в любом конвертере посмотреть в графе as a shot что камера проставила
Re[NesteR]:
У меня 1.01 и если в кельвинах с камеры выставлять, можно 2500 поставить.
Re[frAme]:
от: frAme
Все верно! но в режиме авто БеБе - камера ниже 3000 не опускается
Re[NesteR]:
Да ей просто западло ниже опускаться, настоящая пацанячая камера так низко не должна опускаться и все тут. Она ж не кэнон какой нить.
Re[NesteR]:
от: NesteR
Дануна
