прошивка canon5d mark2
Всего 17 сообщ.
Показаны 1 - 17
На камере стоит прошивка версии 1.06. Если сейчас прошивать самой последней версией, включает ли последняя исправления из всех преждыдущих версий?
Re[Виктор Михайлович]:
Несколько дней такая же тема болталась на 1 странице ;)
Похоже что все включено,
С сайта canon japan.
Are the previous versions of firmware included in version 1.2.4?
Yes, the following improvements from the previous versions are included:
(Previous) Version 1.1.0 improvements:
Firmware Version 1.1.0 includes the following improvements and fixes:
1.Includes a function to enable the manual exposure setting when shooting movies.
*When shooting movies in manual (M) mode, the shutter speed *1, the lens aperture value *2, and the ISO speed *3 can be freely set to allow a greater flexibility.
Notes:
*1 Shutter speed range: 1/30 sec. to 1/4000 sec.
*2 Lens aperture range: maximum to minimum aperture value of the lens used
*3 ISO speed range:
Auto: ISO 100 to 6400 set automatically
Manual: ISO 100 to 6400, H1
2.Disables the function of the depth-of-field preview button when images are played back or when the menu screen is displayed on the LCD panel.
*There are indications that images being reviewed or the menu screen may suddenly disappear from the LCD panel. As this phenomenon may be caused by accidentally pressing the depth-of-field preview button, this firmware update disables the function of the depth of field preview to address this issue.
3.Fixes a phenomenon where the peripheral illumination of images cannot be properly corrected, even if the images were captured with the lens Peripheral Illumination Correction function set to Enable.
*Firmware Version 1.1.0 fixes a phenomenon where peripheral illumination may not be properly corrected due the type of lens used and shooting conditions.
4.Fixes the algorithms of the Auto Lighting Optimizer function when Custom Function C.Fn II-3 Highlight tone priority is enabled.
5.Fixes incorrect indications on the Arabic, Romanian, Spanish, and Ukrainian menu screens.
6.Changes the battery information displayed on the camera when using the optional Battery Grip BG-E6.
*If only one LP-E6 battery pack is installed in the Battery Grip BG-E6, the battery information for the empty battery slot shows the error message, Cannot communicate with battery. However, with this firmware update, this error message no longer appears, even if only one LP-E6 battery pack is installed.
(Previous) Version 1.0.7 improvements:
Firmware Version 1.0.7 improves and mitigates the following image quality phenomena.
1."Black dot" phenomenon (the right side of point light sources becomes black)
When shooting night scenes, the right side of point light sources (such as lights from building windows) may become black. The phenomenon may become visible if the images are enlarged to 100% or greater on a monitor or if extremely large prints of the images are made. This firmware improves and mitigates this phenomenon.
2.Vertical banding noise
If the recording format is set to sRAW1, vertical banding noise may become visible depending on the camera settings, subject, and background. The firmware improves and mitigates this phenomenon
Notes:
When updating to Firmware Version 1.0.7, please also update the DigitaI Photo Professional and Picture Style Editor software *4 to the following versions or later. These software updates can be downloaded from our Web site.
*4 DigitaI Photo Professional: Version 3.5.2 or later (for Windows and Macintosh)
Picture Style Editor: Version 1.4.2 or later (for Windows and Macintosh)
If the existing software applications are used to display sRAW1 and sRAW2 images that were captured by a camera with Firmware Version 1.0.7, dark, low-contrast areas in the images may appear slightly magenta. If the updated software applications are used to display sRAW1 and sRAW2 images, the color of the images will appear normal, regardless of the camera firmware version.
Notes:
*3 ISO speed range:
Notes:
Лучше уж дождитесь следующей 17 марта выходит тогда трех зайцев убьете
Анонс - "Canon adds 24 and 25fps HD Movie recording to the EOS 5D Mark II with Firmware 2.0.3"
http://www.dpreview.com/news/1003/10030201canoneos5dmkiifirmware.asp
Ух ты, анонс новой прошивки на 5дм2 официально, и никому неинтересно
Re[akferun]:
[Удалено]
Re[Drunkster]:
[сообщения клопов удаляются вместе с клопами]
Re[Изрекающий Истину]:
[Удалил]
http://news.ferra.ru/hard/2010/03/02/96404/?from=rhead&rand=1&slot=2
анонс по русски
анонс по русски
Re[Sergey Taran]:
от: Sergey Taran
анонс по русски
киношедевры сразу попрут
Re[joeh]:
А то! 24 к/с это вам не 30к/с
Re[Sergey Taran]:
Чего-то я совсем не понял последнюю фразу из анонса:
"Кроме того, улучшению подвергнется и алгоритм взаимодействия камеры с объективом при использовании функции ручной очистки сенсора."
Мне всегда казалось, что ручная чистка сенсора подразумевает отсутствие объектива на байонете. А иначе как же руками до матрицы добираться? Или как раз это и улучшили: объектив снимать не придется, просто из него в режиме ручной чистки сенсора будут линзы выпадать?
Re[Фото.Нуб]:
Наверное там диафрагма будет открываться так, что кисточка пролезет, поэтому объектив снимать не нужно.
Re
http://www.canon-europe.com/For_Home/Product_Finder/Cameras/Digital_SLR/EOS_5D_Mark_II/EOS5DMkII_sample_movies/index.asp
Re[Фото.Нуб]:
В анонсе на dpreview такой хрени вообще нет, наши видать что-то додумали уже с потолка.
Re[SunnyPanth]:
Notes:
*3 ISO speed range:
Перепрошил в 1.2.4 и у меня iso в режиме P, Tv, Av, M работает от 100 до 3200, а не до 6400. У вас также или как надо настроить? Ничего не понял.
*3 ISO speed range:
