В отличном состоянии, незначительные следы использования и потертости. Небольшая вмятинка на одной из плоскостей. Оптика имеханика в порядке. Находится в Киеве. Отправка в любую точку мира за ваш счет.
Причина продажи: у меня таких 2, один в работе, другой лежит без дела.
View your entire 4x5 image area unencumbered and right-side-up. This convenient and lightweight viewing hood is great for composing and focusing your view camera anywhere, but it is a particular pleasure if you're working in the field, wearing glasses or with an art director who only sees things right side up. Its bright 1.5x magnification diopters are housed within a rubber hood for comfortable, precise viewing with both eyes without extraneous light. May be mounted horizontally or vertically.
A sharp, front-surface adjustable mirror covers the entire image area, so you are always viewing the brightest possible image, even when you're checking focus in critical, isolated areas, such as corners of the frame.
Designed for use on standard 4 x 5" camera backs and provides a right-side-up image for recognizable composition and focusing control. It features an angled design and can be mounted in horizontal or vertical orientation for viewing from a variety of angles. The binocular design is especially easy for viewing in a range of lighting situations and is also ideally suited to glasses-wearers.
The finder incorporates dual 1.5x-magnification diopters within a the rubber hood for critical viewing and the adjustable front surface mirror provides a bright display for complete accuracy across the entire image frame.
