Помогите подключить Nikon D1 к компьютеру
Как подключить Nikon D1 к компьютеру
есть Nikon D1 есть ноутбук с системой WindosXP sp3
есть шнур Fire Wire
что нужно сделать чтобы комп увидел nikon икак потом скидывать фото
а впоследствии перешить версию
какие программы и драйвера и тд
поподробнее пожалуйста
Спасибо Всем и Сразу
Re[zernas]:
Connecting to a Computer
The D1 can be connected directly to a computer via its IEEE 1394 interface,
when images can be transferred to the computer using Nikon View DX or Nikon
Capture software (available separately). Using Nikon Capture, you can control
your camera from your computer for advanced studio photography.
1 After checking that the camera is off, open the
cover protecting the camera’s IEEE 1394 connector
and connect a six-pin, IEEE 1394 cable (available
separately) to the camera.
Connections: Connecting to a Computer
2 Check that the other end of the cable is connected
to your computer’s IEEE 1394 connector. For
information on connecting IEEE 1394 peripherals
to your computer, refer to the documentation
provided with your computer, or with your IEEE
1394 card or expansion board.
3 Turn the camera on. Then, holding down the mode dial lock release, turn
the mode dial to PC (PC mode).
If the camera is properly connected and Nikon Capture is running on your
computer, the letters “PC” will be displayed in the control panel on top of
the camera (“PC” is not displayed when Nikon View DX is running). Refer
to your software manual for information concerning the operations that can
be performed while the camera is connected to a computer.
If the camera is not connected to a computer, or if it is connected when
neither Nikon View DX nor Nikon Capture is installed, the camera will
function as it would in single-frame shooting or continuous shooting
modes. The only differences are that the frame advance mode (single or
continuous) is set using Custom Setting item 30, and that photographs are
not displayed on the monitor in capture-preview mode, record-and-review
mode, or in single-image playback.
4 Before disconnecting the IEEE 1394 cable from the camera, turn the
camera off. Do not turn the camera off or disconnect the camera when data
transfer is in progress.
Notes
Do not use the camera with the computer while battery power is low or the batteries
are exhausted. If the battery indicator changes to low or starts to flash while the
camera and computer are connected, wait for data transfer to terminate, then
disconnect the camera and replace the batteries or connect the EH-4 AC adapter (sold
separately).
It is recommended that the camera be powered by the EH-4 AC adapter (available
separately) when you are using the Nikon digital camera D1 with Nikon View DX.
When using an EN-4 battery pack, be aware that leaving the camera connected when
the battery is exhausted may shorten battery life. Should the battery become
exhausted, insert a fully charged spare battery without delay or disconnect the camera
from the computer. The amount of charge remaining is shown by the battery indicator
in the control panel on top of the camera.
Only photographs that conform to the Design Rule for Camera File Systems (DCF) can
be transferred from the camera to the computer in PC mode while Nikon Capture is
running on the computer.
Re[zernas]:
Гугл это перевёл так:
Подключение к компьютеру
D1 могут быть подключены непосредственно к компьютеру через ее IEEE 1394 интерфейс,
, когда изображение может быть передано к компьютеру с помощью Nikon View DX или Nikon
Захват ПО (поставляется отдельно). Использование Nikon Capture, вы можете контролировать
камеры с вашего компьютера для продвинутых фотографии студии.
1 Убедившись, что камера выключена, откройте
крышкой, которая предохраняет IEEE камеры 1394 разъем
и подключить шесть-контактный, IEEE 1394 кабель (приобретается
отдельно) к камере.
Подключение: Подключение к компьютеру
2 Убедитесь, что другой конец кабеля
IEEE для компьютера 1394 разъем. Для
Информация о подключении IEEE 1394 периферия
на компьютер, обратитесь к документации
предоставляется вместе с компьютером, или с IEEE
1394-карты или расширения.
3 Включите камеру. Затем, удерживая клавишу блокировки режимов освобождения, поверните
режимов для подключения к ПК (PC режим).
Если камера правильно подключена и Nikon Capture работает на
компьютер, буквы "PC" будет отображаться в панели управления в верхней части
камеры ("PC" не отображается, когда Nikon View DX работает). Сослаться
к вашему руководству по программному обеспечению для информации, касающейся операций, которые могут
быть выполнены при подключении камеры к компьютеру.
Если камера не подключена к компьютеру, или если он подключен при
ни Nikon View DX, ни Nikon Capture установлен, камера
функции, как это было бы в покадровом или непрерывной съемки
режимах. Единственное различие в том, что режим покадровый просмотр вперед (одно-или
непрерывным) устанавливается с помощью пользовательского Настройка пункт 30, и фотографии
не отображается на экране монитора при захвате-режиме предварительного просмотра, записи и обзора
режиме, или в единичных снимков воспроизведения.
4 Перед отключением IEEE 1394 кабель от камеры, включите
камеру. Не включайте камеру или отключиться камеры, когда данные
передачи работ.
Примечания
Не пользуйтесь камерой с компьютера при низком заряде батареи или аккумуляторы
будут исчерпаны. Если индикатор аккумулятора изменения с низким или начинает мигать, а
камеры и подсоединен к компьютеру, подождите для передачи данных прекратить, а затем
отключить камеру и заменить батарейки или подключите EH-4 сетевой адаптер (продается
отдельно).
Рекомендуется, что камера питается от 4 EH-адаптер переменного тока (доступно
отдельно), когда вы используете цифровую камеру Nikon D1 с Nikon View DX.
При использовании EN-4 аккумулятора, знайте, что оставить, когда камера подключена
аккумулятор исчерпал может сократить срок службы батарей. Если аккумулятор стал
исчерпаны, вставить полностью заряженный запасной аккумулятор, без задержек или отключить камеру
от компьютера. Количество заряда остальные показывает индикатор батареи
в панели управления на верхней панели камеры.
Только фотографии, которые соответствуют проектная норма для файловых систем камер (DCF) могут
быть переведен из камеры на компьютер в режиме ПК в то время как Nikon Capture является
работает на компьютере.
Re[zernas]:
А скидывать фото через картридер не будет проще?
Re[Гена 2]:
Это я все делал
Я спрашивал какая версия Windos должна стоять на компе
и какие драйвера и программы дожны стоять и где их взять
Спасибо что привели выдержки из инструкции
я их уже проштудировал и попробовал не горит надпись PC и не видит комп камеру
Re[zernas]:
по-моему все разжевано - дальше некуда.
- выключить камеру, воткнуть шнур в комп и камеру
- убедится, что в биосе включен IEEE и в диспетчере устройств винды он присутствует
- включить камеру и перевести ее в режим РС-связи
- на компе должна стоять Nikon View DX и Nikon Capture
ПС. операционка пофиг какая (винда).
Re[zernas]:
IEEE никаких особых дров не требует.
Может у тебя винда кривая? Переустанови свежий дистрибутив. Мне всегда этот метод помогает, когда непонятно куда копать.
Ты сколько уже винду не переустанавливал? Если год и больше, то всё ясно.
Re[zernas]:
Не знаю включен ли он в Биосе на всякий случай скажите где там включать Но в в диспетчере устройств он присутствет
А вот Nikon View DX и Nikon Capture у меня не стоят
Они должны быть обе сразу включены?
Где их качнуть и какие версии по XP SP3 идут?
Re[zernas]:
от: zernas
прояви смекалку. www.nikon.ru Там одна, последняя версия, которая идёт на любой винде.
