The K-1 takes greatness to the next level. As the first full frame DSLR engineered under the PENTAX brand, the K-1 brings outstanding performance, operability and affordability to photographers. With its large 36.4 megapixel CMOS image sensor, the K-1 incorporates all of the performance of a high-resolution full frame 35mm digital camera as well as all of the unique PENTAX-original features and technologies that photographers have become accustomed to, in a compact, rugged, weather-resistant body.
High-resolution, fine-gradation images supported by approximately 36.4 effective megapixels
The K-1 features an AA filterless design that prioritizes image resolution. Coupled with the new PRIME IV imaging engine, capable of 14-bit RAW-format image recording. The K-1’s unique full frame sensor and imaging engine design also allows for super-high-sensitivity shooting up to ISO 204800, producing beautiful, high-resolution images.
overview
specs
in the box
support
media
In-body SR mechanism assures optimal shake reduction performance
The SR II five-axis mechanism enables accurate control of the large full-frame image sensor with all compatible PENTAX interchangeable lenses.* In addition to camera shake caused by pitch and yaw, it effectively compensates for camera shake caused by horizontal and vertical shift, as well as camera shake caused by roll, which is difficult to deal with by lens-installed shake reduction mechanisms. Even when taking a panning shot, this system automatically detects the direction of the camera’s movement, and efficiently controls the SR unit to always produce the best image possible.
Pixel Shift Resolution System with a new motion correction function
The K-1 uses the latest super-resolution technology, which captures four images of the same scene by shifting the image sensor by a single pixel for each image, and then synthesizes them into a single composite image. Since the K-1’s SR unit has a flexible design that tilts the image sensor unit in all directions, it provides a host of handy shooting functions, including auto level compensation, image-composition fine-adjustment, and ASTRO TRACER, which simplifies advanced astronomical photography using a built-in GPS module.
