Panasonic Lumix DMC-GM1
Всего 1898 сообщ. | Показаны 641 - 660
Re[another.82]:
Re[mwebmaster]:
Вот человек снимает классные кратинки на GM1 и leica 15/1.7
Много фотографий на 1/16000 выдержку
https://www.flickr.com/photos/onemanban/sets/72157645360957537
 GM1+Panasonic15mm/F1.7 by onemanban, on Flickr
Re[sonera]:
Весьма!
Re[sonera]:
от:sonera
правильно ли я понимаю , что это джипег и снято со вспышкой?
ƒ/1.7
15.0 mm
1/13000
200
Flash (off, did not fire)
EXIF
Make - Panasonic
Orientation - Horizontal (normal)
X-Resolution - 180 dpi
Y-Resolution - 180 dpi
Software - Ver.1.0
Date and Time (Modified) - 2014:08:21 16:20:32
YCbCr Positioning - Co-sited
ISO Speed - 200
Sensitivity Type - Standard Output Sensitivity
Exif Version - 0230
Date and Time (Original) - 2014:08:21 16:20:32
Date and Time (Digitized) - 2014:08:21 16:20:32
Components Configuration - Y, Cb, Cr, -
Compressed Bits Per Pixel - 4
Exposure Bias - 0 EV
Max Aperture Value - 1.7
Metering Mode - Multi-segment
Light Source - Unknown
Flashpix Version - 0100
Color Space - sRGB
Sensing Method - One-chip color area
File Source - Digital Camera
Scene Type - Directly photographed
Custom Rendered - Custom
Exposure Mode - Auto
White Balance - Auto
Digital Zoom Ratio - 0
Focal Length (35mm format) - 30 mm
Scene Capture Type - Standard
Gain Control - Low gain up
Contrast - High
Saturation - High
Sharpness - Hard
Image Quality - High
Firmware Version - 0.1.0.0
Focus Mode - AF-S
AFArea Mode - Face Detect
Image Stabilization - Off
Macro Mode - Off
Shooting Mode - Aperture Priority
Audio - No
Data Dump - (Binary data 8200 bytes, use -b option to extract)
Flash Bias - 0
Internal Serial Number - (X02) 2013:12:11 no. 0278
Panasonic Exif Version - 0406
Color Effect - Off
Time Since Power On - 00:00:10.83
Burst Mode - Off
Sequence Number - 0
Contrast Mode - Low
Noise Reduction - Unknown (65531)
Self Timer - Off
Rotation - Horizontal (normal)
AFAssist Lamp - Disabled and Not Required
Color Mode - Normal
Baby Age - (not set)
Optical Zoom Mode - Standard
Conversion Lens - Off
Travel Day - n/a
Contrast - +4
World Time Location - Home
Text Stamp - Off
Program ISO - n/a
Advanced Scene Type - 1
Faces Detected - 1
Saturation - +2
Sharpness - +3
Color Temp Kelvin - 5600
Bracket Settings - No Bracket
WBShift AB - 0
WBShift GM - 0
Flash Curtain - n/a
Long Exposure Noise Reduction - Off
Panasonic Image Width - 0
Panasonic Image Height - 0
AFPoint Position - 0.53 0.45
Num Face Positions - 1
Face1 Position - 170 107 31 31
Lens Type - LEICA DG SUMMILUX 15/F1.7
Lens Serial Number - 04FIC11G030N
Accessory Type - NO-ACCESSORY
Accessory Serial Number - 0000000
Lens Firmware Version - 0.1.0.0
Faces Recognized - 0
Intelligent Resolution - Off
Burst Speed - 0
Intelligent D- Range - Off
Clear Retouch - Off
Photo Style - Standard or Custom
Shading Compensation - Off
Accelerometer Z - 268
Accelerometer X - 12
Accelerometer Y - 56
Camera Orientation - Normal
Roll Angle - 1.7
Pitch Angle - -8.8
Timer Recording - Off
Internal NDFilter - 0
HDR - Off
Shutter Type - Electronic
Clear Retouch Value - undef
Touch AE - Off
Maker Note Version - 0146
Scene Mode - Off
WBRed Level - 2419
WBGreen Level - 1056
WBBlue Level - 1624
Flash Fired - No
Interop Index - R98 - DCF basic file (sRGB)
Interop Version - 0100
Print IMVersion - 0250
Compression - JPEG (old-style)
Thumbnail Offset - 14848
Thumbnail Length - 7533
MPFVersion - 0100
Number Of Images - 2
MPImage Flags - Dependent parent image
MPImage Format - JPEG
MPImage Type - Baseline MP Primary Image
MPImage Length - 7665985
MPImage Start - 0
Dependent Image1 Entry Number - 2
Dependent Image2 Entry Number - 0
MPImage Flags - Dependent child image
MPImage Type - Large Thumbnail (full HD equivalent)
MPImage Length - 988944
MPImage Start - 7666176
Dependent Image1 Entry Number - 0
Camera ID - 72157636441932224
Camera Type - Mirrorless Camera
Contrast - +4
Program ISO - n/a
Faces Detected - 1
Saturation - +2
Sharpness - +3
WBShift AB - 0
WBShift GM - 0
Flash Curtain - n/a
если в эхиф -Flash (off, did not fire) то откуда -Color Temp Kelvin - 5600
вообще интересно как 1/10000-1/16000??
да ешё во многих фото - 0,33
Re[mwebmaster]:
Вспышки нет - видно по фото. К тому же при электронном затворе я даже не знаю работает ли вспышка у этого фотика?
Экспозиция в минус у него часто. Так цвета насыщеннее. НУ и стиль соответственно. Я так понял это камерный джпег везде.
1/16000 элементарно при такой дырке f1,7 и солнечной погоде.
Кельвины не знаю - но 5600 это бизко или рядом с температурой при солнечной погоде. Скорее всего автомат ставит.
Смущает контраст +4 думается это перебор, хотя фото интересные.
Re[Ygrek -(Игорь)]:
там еще
[quot]Contrast - High
Saturation - High
Sharpness - Hard [/quot]
на лейку Т по цвету похожи немного крайние кадры
К5600 это плюс-минус daylight
Re[mwebmaster]:
Первая камера, где джипег мне нравится больше чем рав. Ощущение, что их поменяли местами, ибо рав выглядит с корявыми замыленными цветами, хоть и все шумодавы отключены. Да и детализация сильно падает по сравнению с джипег.
Re[TORT]:
хм. Что то не верится. Неужто сильно отличается от того же GX7.
Мож есть пару файлов посмотреть?
Re[sonera]:
От GX7 то вряд ли отличается, начинка то одна. Но сравнить их в лоб у меня есть возможность. Заодно и рав с джипегом выложу для сравнения.
На днях сделал пробную выгулку малышу, снимал только в джипег - меня в принципе устроило, с равом возиться смысла не вижу.
45/1.8 + 12-32
Re[mwebmaster]:
Тоже купил на днях. Брал в дополнение к 5Dm2. Подскажите будет ли работать акб стороннего производителя на 1000 mah (китай)
И будет ли она заряжаться от штатной зарядки?
Re[mwebmaster]:
ну вот -портретник для ГМ серии
Hot!!!
Panasonic announces two new MFT lenses: 42,5mm f/1.7 and 30mm f/2.8 macro!
Re[Ygrek -(Игорь)]:
f/1.7?
Re[Ygrek -(Игорь)]:
С первого взгляда подумал что это 25/1,8 или 45/1,8
Re[Ygrek -(Игорь)]:
от:Ygrek -(Игорь)
Hot!!!
Со стабом однако
Re[mwebmaster]:
от: mwebmaster
Со стабом однако
На цене, думаю, неплохо отразиться!
Re[beer_jack]:
от: beer_jack
на олимпусовскую 45-ку похоже.... только вот с о стабом!
Re[TORT]:
от: TORT
думаю не дороже лейки 15/1,7....
а это в 3-4 раза дешевле, чем 42,5/1,2
The macro lens has a 1:1 magnification and 10,5cm close focusing distance. Price is 399 Euro.
The 42,5mm f/1.7 has a 31cm close focusing distance and also costs 399 Euro. It comes in Black and Silver.
Both will ship from May!
Re[Ygrek -(Игорь)]:
от:Ygrek -(Игорь)
Ну 399 Euro на старте вполне нормальная цена
А если учитывать сколько 45/2.8 стоит ))
С другой стороны 45/1,8 щас 249 Euro повсеместно почти.
А макрик новый конечно хорошо что 1:1, но 35/3,5 все равно по цене в не конкуренции
Re[mwebmaster]:
от: Ygrek -(Игорь)
Согласен. Но и в 2 раза дороже 45/1.8.
Возьмут ли владельцы 45-ки его? Думаю вряд ли. Кто хочет брать 45/1.8, станут ли переплачивать? Тем более владельцы оликов - даже не знаю.
А вот кто хотел 42.5/1.2 - думаю неплохая альтернатива, правда это не 1.2, что ценно в этом стекле.
ИМХО, лучше б сделали 42.5 (45) f/1.4 и без стаба.
от: mwebmaster
В Москве 249, только долларов. Я смог найти за 200$
Re[TORT]:
от:TORT
думаю владельцы панасов с вами не согласяться....
у меня было 3 45-ки олимпуса....продал
с первой сначала думал -бракованная....
но купив вторую - убедился , что она такая и есть - ужасно софили...
третья попалась случайно и то же самое .
а вот панас - точно куплю и сигму 60 и олик 75 -продам....
ну и цена 200 долларов за 45 -ку ...говорит о том, что люди массово избавляются....
