Просочилась первая информация:
Camera Effective pixels: 8,000,000 pixels
Image sensor: 1/1.8" CCD
Появился RAW!
Фотографии:
http://img351.imageshack.us/img351/2638/fz30hood8ri.jpg
http://img257.imageshack.us/img257/9580/fz30bl8my.jpg
Документация к фотоаппарату:
http://s3.11mbit.de/j4xCM7LegzIxm1F8Et4E2Le381k4s2qAyd1l3N7h6p81cvj7h6K8Ib0j/Hk29o392
Panasonic FZ30 скоро!
Всего 13 сообщ.
Показаны 1 - 13
Re: Panasonic FZ30 скоро!
Этож какого размера он будет.
Re: Re: Panasonic FZ30 скоро!
вот спецификация, выдранная из документации, скачанной с британского сайта:
Specifications
Digital Camera: Information for your safety
Power Source: DC 8.4V
Power Consumption: 2.1W (When recording with LCD Monitor)
2.0W (When recording with Viewfinder)
1.2W (When playing back with LCD Monitor)
1.1W (When playing back with Viewfinder)
Camera Effective pixels:8,000,000pixels
Image sensor: 1/1.8qCCD, total pixel number 8,320,000pixels
Primary color filter
Lens: Optical 12kzoom, fl7.4mm to 88.8mm (35mm film camera
equivalent:35mm to 420mm)/F2.8 to F3.7
Digital zoom: Max. 4k
Focus: Normal/AF MACRO/Manual/Macro, 9-area-focusing/
3-area-focusing (High speed)/1-area-focusing (High speed)/
1-area-focusing/Spot-focusing
Focus range: AF:30cm (0.98feet) (Wide)/2m (6.56feet) (Tele) to inf
AFMACRO/MF:5cm (0.16feet) (Wide)/
Shutter system: Electronic shutteriMechanical shutter
Burst recording
Burst speed: 3frames/second (High speed), 2frames/second (Low speed),
Approx. 2frames/second (Unlimited)
Number of recordable
pictures: Max. 9frames (Standard), max. 5frames (Fine), Depends on
the remaining capacity of the card. (Unlimited)
(Performance in burst recording is only with SD Memory Card.
MultiMediaCard performance will be less.)
Motion picture recording:640k480pixels/320k240pixels
(30 or 10frames/second with audio. The maximum recording
time depends on the capacity of the card.)
ISO sensitivity: AUTO/80/100/200/400
Shutter speed: 60 to 1/2000th
[STARRY SKY] mode:15seconds, 30seconds, 60seconds
White balance: AUTO/Daylight/Cloudy/Halogen/Flash/White set1/White set2
Exposure (AE): Program AE (P)/Aperture-priority AE (A)/
Shutter-priority AE (S)/Manual exposure (M)
Exposure compensation (1/3 EV Step, j2 EV to i2EV)
Metering mode: Multiple/Center weighted/Spot
LCD monitor: 2.0qlow-temperature polycrystalline TFT LCD
(235,000pixels) (field of view ratio about 100%)
Viewfinder: Color LCD Viewfinder (235,000pixels)
(with diopter adjustment j4 to i4diopter)
Flash: Built-in pop up flash
Flash range:(ISO AUTO)
Approx. 30cm (0.98feet) to 7.0m (23.0feet) (Wide)
AUTO, AUTO/Red-eye reduction, Forced ON (Forced ON/
Red-eye reduction), Slow sync./Red-eye reduction,
ForcedOFF
Microphone: Monaural
Speaker: Monaural
Recording media: SD Memory Card/MultiMediaCard
Picture size
Still picture: When the aspect ratio setting is [4:3 ]
3264k2448pixels, 2560k1920pixels, 2048k1536pixels,
1600k1200pixels, 1280k960pixels
When the aspect ratio setting is [16:9 ]
3072k1728pixels, 1920k1080pixels
When the aspect ratio setting is [3:2 ]
3248k2160pixels, 2560k1712pixels, 2048k1360pixels,
Motion pictures: 640k480pixels/320k240pixels
Quality: Fine/Standard/TIFF/RAW
Recording file format
Still Picture: JPEG (Design rule for Camera File system, based on Exif2.2
standard)/TIFF (RGB), DPOF corresponding
Picture with audio: JPEG (Design rule for Camera File system, based on Exif2.2
standard)i640k480pixels
QuickTime (picture with audio)
Motion pictures: QuickTime Motion JPEG (motion pictures with audio)
Interface
Digital: USB2.0 (Full Speed)
Analog video/audio: NTSC/PAL Composite (Switched by menu),
Audio line output (monaural)
Terminal
REMOTE: ? 2.5mm jack
AV OUT/DIGITAL: Dedicated jack (8 pin)
DC IN: type 3 jack
Dimensions: 140.75mm (W) x 85.5mm (H) x 138.1mm (D) (5 9/16 in (W) x 3 3/8 in (H) x 5 7/16 in (D)) (excluding the projection part)
Mass: Approx. 674g/23.8oz
(excluding Memory Card and battery)
Approx. 740g/26.1oz (with Memory Card and battery)
Operating Temperature: 0oC to 40oC (32oF to 104oF)
Operating Humidity: 10% to 80%
Battery Charger
(Panasonic DE-993B): Information for your safety
Input: 110 to 240V 50/60Hz, 0.15A
Output: CHARGE 8.4V 0.43A
Equipment mobility: Movable
Battery Pack (lithium-ion)
(Panasonic CGR-S006A):Information for your safety
Voltage/capacity: 7.2V, 710mAh
Specifications
Burst recording
ForcedOFF
Speaker: Monaural
Picture size
Interface
Terminal
DC IN: type 3 jack
Battery Charger
Главную фишку ФЗ-20 убили - обьектив стал темноват !
чёво?? в перещёте на старый размер матрицы это f/2.0 - 2.7
а вот стоить будет за штуку баксов
Re: Re: Re: Panasonic FZ30 скоро!
от: L4m3r
это не важно
а вот это существенно. за такие деньги никаких 2.0 не захочется. Откуда дровишки, кстати?
Re: Re: Re: Re: Panasonic FZ30 скоро!
Что ты имеешь ввиду под "дровишками"?
Re: Re: Re: Re: Re: Panasonic FZ30 скоро!
от: zaff
информацию я имею в виду под дровишками
Re: Re: Re: Re: Re: Re: Panasonic FZ30 скоро!
Отрыл на другом фото-форуме. Но про цену ничего не сказано.
Re: Re: Re: Re: Re: Re: Re: Re: Panasonic FZ30 скоро!
от: Fodis
8мп на 1/8? Не на 2/3? дожили....
Да нет, это стандартная проблема панасоника - маленький размер матрицы, приличная оптика. После fz10 ни одной нормальной модели уже нет(
Я сам удивился! Но посмотрим, что у Матсушиты получится... Хотя я надеюсь, что это ошибка...
Re: Re: Re: Re: Re: Re: Re: Re: Re: Panasonic FZ30 скоро!
размер пикселя-то вроде получается примерно такой же по величине? А откуда 8Мп - понятно, Самсунг на пятки дышит.
