Открывает ли Лайтрум RAW файлы в формате NEF?
Всего 17 сообщ. | Показаны 1 - 17
Отсканировал на Никоне 9000 слайды 6x4,5 в формате RAW (в Никоне - NEF), однако в Лайтруме открыть их не могу. В закладке форматов программы этот формат указан наряду с многими другими. Пытался открыть и через Import, и через "открыть с помощью...." - не открывает. Может кто подскажет в чем дело?
С уважением, Геннадий
Re[ГенМор]:
Если я ничего не путаю, то Лайтрум открывает только NEF - фотографии. У файлов со сканера другой формат, отличный от...
Re[Conr]:
Ага, ничего не напутал:
Michael Rubin, Jun 29, 2007; 09:33 a.m.
Please allow me to add some clarity.
A "NEF" file is not necessarily a RAW file. All Nikon RAW files are, however, NEF files.
NEF=Nikon Electronic Format.
The architecture of said file format is a base image (comprised of either RAW, JPEG or TIF data) plus a single or multiple instruction sets.
Many Nikon Digital Cameras produce RAW data (mostly); Nikon Scanners do not. Nikon Scan NEF files are just TIFs with additional instructions (any of the post-scan applications such as levels and curves); a Nikon Scan NEF is designed so that in Nikon Scan, you could go back and make quick changes to your settings.
If you open a Nikon Scan NEF in Capture NX, it is treated as a TIF plus instructions (if you had a levels and curves adjustment it should populate in the Base Adjustments); you won't be able to adjust exposure or white balance because neither of these are post-scan functions.
I hope that makes it a little more clear.
Nikon Capture from at least version 3 onwards to NX allows JPEGs & TIF files to be saved as NEF files with the instruction sets appended. What has changed radically in Capture NX from prior versions are all of the additional tools and adjustments that Capture NX offers. As such the non-destructive nature of a NEF file really goes a long way with a JPEF or TIF file in Capture NX.
Best,
Michael
mrubin (at) nikon (dot) net
Re[Conr]:
Conr, огромное спасибо, хоть что-то прояснилось, но тогда другой вопрос:
На форуме M-format и где-то здесь неоднократно участниками упоминалось, что именно при сканировании , в том числе "крутыми" сканерами Никон 8000/9000, надо сканировать только в РАВ (то бишь в NEF, т.к. Никон сканирует только в этом формате), а потом переводить в программу-конвертор,если надо работать как раз с экспозицией и балансом белого ( что, как видно из ссылки, программа Никон Капчуре как раз и не может делать !), а потом конвертировать уже в ТИФ или JIPEG для дальнейшей обработки (если надо) в ФШ.
Если можно поясните пожалуйста, какая программа -конвертор все-таки работает с РАВ-файлами сканера Никон 9000? И что тогда понимать под его , якобы, РАВ форматом, если он какой-то получается "недоношенный"? Сам сканер-то позиционируется очень высоко, и форумах рекомендуется, и цена не малая.
Re[ГенМор]:
Можно воспользоваться VueScan - она умеет сканить в DNG, который понимает Lightroom.
Насколько я понимаю, NEF, которые делает сканер вообще ни разу не RAW и конвертировать их нет смысла - данные уже интерполированы, именно поэтому и невозможна коррекция.
Кстати, если не сложно, а можно получить приме такого NEF'а (vs на photovit тчк info)? Хочется добавить у себя поддержку таких файлов.
Re[Conr]:
Тогда получается, что надо сканировать просто в тифе и не заморачиваться. Это Никон прекрасно делает. DNG - это РАВовский формат? Если да, то буду доставать Вьюскан, хотя я один раз смотрел его демоверсию и она мне не понравилась - путанная какая-то. Но раз другого пути нет получить более качественное изображение, чем в ТИФе - буду доставать Вьюскан.
Файл пришлю, только точно по латыни напишите свой е-мэйл.
Re[ГенМор]:
Да, DND - это RAW. Но не думаю, что будет какая-то кардинальная разница между DNG и TIF - смысла, скорее всего нет.
vs@photovit.info
Re[Conr]:
от:Conr
не совсем так - судя по описанию, это-таки данные с матрицы сканера (RGB-отсчеты, инкапсулированные в формат tiff) + отдельно параметры обработки (например, уровни и кривые), которые были бы применены к этим данным при непосредственном сохранении в формате tiff:
[quot]Nikon Scan NEF files are just TIFs with additional instructions (any of the post-scan applications such as levels and curves); a Nikon Scan NEF is designed so that in Nikon Scan, you could go back and make quick changes to your settings.[/quot]
Т.е. имея Scan NEF "можно вернуться и поменять установки", в т.ч., например, откорректировать баланс белого, что труднее/хуже делать с данными, которые уже были как-то обработаны при сохранении в tiff. Кстати, думаю, что в DNG будут записаны точно те же данные с матрицы - что железо сканера дает.
Кстати, не понял, что значит "данные уже интерполированы, именно поэтому и невозможна коррекция"?
Re[ГенМор]:
Не открывает. У Никона 2 НЕФа: один с камер,который нормально открывается Лайтрумом, другой со сканеров, для работы с ним нужна Nikon Capture.
Re[Conr]:
от:Conr
Vuescan, кажется, не поддерживает Digital ICE. Что сильно снижает его привлекательность.
Re[ГенМор]:
от:ГенМор
А че его доставать?
hamrick.com
Полная версия, без регистрации рисует знак доллара поверх фото перед записью на диск фотографии - но для ознакомления достаточно.
А чтобы получить доступ к настройкам - нужно внизу справа нажать кнопку "Advanced", а затем "More".
Но интерфейс - действительно - путанный.
Re[ГенМор]:
от: ГенМор
RAW - это то что снято непосредственно с сенсора и подверглось минимальной обработке внутри устройства.
RAW - это не формат, а куча форматов - у каждой фирмы свой, да и частенько у разных моделей одной и той же фирмы - свой.
DNG - это стандартизованный формат, предназначенный для сохранения то же информации что и RAW + дополнительных данных (описание файла, описание способа обработки файла и пр.).
Фактически DNG - это RAW, хотя данное утверждение и не совсем грамотно.
Re[now and zen]:
от: now and zen
Поддерживает. Только по другому называется. "Infra Red чего-то там" или "IR чего-то там"
Re[Дык]:
от:Дык
А че его доставать?
hamrick.com
А если понравиться - то стоит совсем недорого
Re[now and zen]:
от: now and zen
+1
Мой совет, основанный на личном опыте, на 9000 - лучше сканировать в TIF не менее, чем в 16 бит! Правда при хорошем скане объем файла получается от 200 до 400 Мб, но ЭТО цена за получаемое качество.
Если хочется меньших размеров - тогда NEF с последующей обработкой в Nikon Capture 4.4, поскольку ЛУЧШЕ, чем родной никоновский софт информацию из NEF мало что может вытащить.
Удачи. :D
Re[Conr]:
Разница между DNG и TIF есть. Первое - чистая инфа со сканера без вычитания маски пленки, без применения гаммы и без обрезания светов и теней (автомат при сканировании в TIF часто обрезает слишком много). DNG, и скорее всего NEF тоже - это линейный TIF файл в световом пространстве сканера. Только обрабатывать DNG после скана негатива в Lightroom будет невозможно.
Я обычно сканирую в линейный TIF в родной программе сканера, затем присваиваю файл цветовой профиль, который скорее всего поставляется со сканером и имеет в названии что-то вроде "linear posi". Из этого уже получаю результат либо в самом Фотошопе вручную (как это делается можно найти в инете), либо открываю файл в Vuescan (как если бы это был raw файл, сделанный самой Vuescan) и перевожу в фото. Исходные файлы сохраняю, на случай если потом потребуется сконвертировать по-другому.
Re[Дык]:
от: Дык
Точно. Просто когда VueScan не видит сканера, он эту опцию и не показывает... Несмотря на путанность, программа оказалась поудобнее NikonScan, купил.
